linknx - pb compile avec lua - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Logiciels libres (linknx, knxweb, pKNyX,...) (https://www.knx-fr.com/forumdisplay.php?fid=10) +--- Sujet : linknx - pb compile avec lua (/showthread.php?tid=1411) |
linknx - pb compile avec lua - chitloft - 10/04/2011 salut j'ai 1 soucis sur mon Dockstar avec debian squeeze # dpkg -l lua5.1 5.1.4-5 Simple, extensible, embeddable programming language # ./configure --without-log4cpp --with-lua --with-mysql=/usr/bin/ mysql_config checking for LUA... no checking for LUA... configure: error: in `/home/install/ linknx-0.0.1.28': configure: error: The pkg-config script could not be found or is too old. Make sure it is in your PATH or set the PKG_CONFIG environment variable to the full path to pkg-config. Alternatively, you may set the environment variables LUA_CFLAGS and LUA_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details. To get pkg-config, see <http://pkg-config.freedesktop.org/>. See `config.log' for more details. Any idea ? Merci. Arnaud linknx - pb compile avec lua - chitloft - 10/04/2011 ca fait 3 h que je cherche ! et puis voila , il manquait #apt-get install pkg-config Dsl. Arnaud On 10 avr, 12:16, chitloft <arnaud.cogn...@laposte.net> wrote: > salut > j'ai 1 soucis sur mon Dockstar avec debian squeeze > > # dpkg -l > lua5.1 5.1.4-5 > Simple, extensible, embeddable programming language > > # ./configure --without-log4cpp --with-lua --with-mysql=/usr/bin/ > mysql_config > checking for LUA... no > checking for LUA... configure: error: in `/home/install/ > linknx-0.0.1.28': > configure: error: The pkg-config script could not be found or is too > old. Make sure it > is in your PATH or set the PKG_CONFIG environment variable to the full > path to pkg-config. > > Alternatively, you may set the environment variables LUA_CFLAGS > and LUA_LIBS to avoid the need to call pkg-config. > See the pkg-config man page for more details. > > To get pkg-config, see <http://pkg-config.freedesktop.org/>. > See `config.log' for more details. > > Any idea ? > Merci. > Arnaud |
