KNXWEB 2.1 - installation problem - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Logiciels libres (linknx, knxweb, pKNyX,...) (https://www.knx-fr.com/forumdisplay.php?fid=10) +--- Sujet : KNXWEB 2.1 - installation problem (/showthread.php?tid=4379) |
KNXWEB 2.1 - installation problem - martmiwp - 30/09/2016 Hi! I was running knxweb 0.9. with linknx .32 everything fine. Now I tried to install knxweb2. I can see the web frontend, I see parameters etc. But when I want to change a value in "Config Knxweb" or if I want to create a new design - I either get a "loading - please wait" .. or just no reaction with nothing saved. Looking into Apache Log I see: /knx2/design_technique.php?action=createdesign&name=default&nocache=1475001686350 .. I tried to install all php modules - not that easy as I am running Ubuntu 16 I followed your script in setting rights and ownerships of directories ... no success. Please help! Thanks Michael RE: KNXWEB 2.1 - installation problem - fma38 - 30/09/2016 There is a 'java something' option, somewhere; try to toggle it... It may helps. RE: KNXWEB 2.1 - installation problem - Energy01 - 01/10/2016 Hi, trying to change permissions on the folder "knxweb" with $ sudo chmod 777 -R /var/www/html/knxweb2/ @+ Anthony. RE: KNXWEB 2.1 - installation problem - martmiwp - 01/10/2016 Hi! Thanks - I tried both. No improvement. ... ??? RE: KNXWEB 2.1 - installation problem - fma38 - 01/10/2016 What browser are you using? Did you try another one? RE: KNXWEB 2.1 - installation problem - martmiwp - 02/10/2016 Hi! Yes - i tried 3 The problems remain on my ubuntu 16 with php7.... I guess there are either not all php modules installed - or a different apache behavoir. I installed on Raspberry - everything is working fine .... according to installtrio ;-) Michael RE: KNXWEB 2.1 - installation problem - Energy01 - 05/10/2016 Hi, for the moment, i have not testing with php7 it's probably "the" problem look at the log file of php and send me the error in the knxweb script php Anthony. |
