BON JE ME LANCE - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Matériel KNX (https://www.knx-fr.com/forumdisplay.php?fid=5) +--- Sujet : BON JE ME LANCE (/showthread.php?tid=4657) |
BON JE ME LANCE - hadjadji - 09/04/2017 BONJOUR, Voilà compromis signer, PC ok ![]() Alors je me lance premier achat domotique. Dites moi se que vous pensés de ma platine de test? 1 KNX Touch Sensor Glass unit, quadruble, UP 213/01, 5WG1213-2DB01 for Glass button Product No.: N062105 Manufacturer: Siemens Indus.Sector Manufacturer no.: 5WG1213-2DB01 1 Touch Sensor Glass cover, quadruble, black, UP 213/21, 5WG1213-8DB21 for KNX Glass button unit Product No.: N062111 Manufacturer: Siemens Indus.Sector Manufacturer no.: 5WG1213-8DB21 1 Touch sensor for home automation 4-fold 617219, special offer Product No.: N810103101 Manufacturer: MERTEN Manufacturer no.: 617219 1 Binary input for home automation 16-ch 5WG1263-1EB11 Product No.: NS0835042 Manufacturer: Siemens Indus.Sector Manufacturer no.: 5WG1263-1EB11 1 Switch actuator for home automation 8-ch 5WG1511-1AB02 Product No.: NS6508249 Manufacturer: Siemens Indus.Sector Manufacturer no.: 5WG1511-1AB02 236,19 EUR 236,19 EUR 1 LAN-systems interface for bus system 5WG1148-1AB22 Product No.: NS6508760 Manufacturer: Siemens Indus.Sector Manufacturer no.: 5WG1148-1AB22 1 Power supply for home automation 640mA 5WG1125-1AB22 Product No.: NS6514458 Manufacturer: Siemens Indus.Sector Manufacturer no.: 5WG1125-1AB22 1 Movement sensor for home automation 3361-1 M WW Product No.: NS6516047 Manufacturer: JUNG Manufacturer no.: 3361-1 M WW Merci pour votre retour RE: BON JE ME LANCE - NicNac - 09/04/2017 Pour quelle raison veux-tu utiliser du binary input? Tu vas mélanger le conventionnel et KNX? J'ai fait comme toi et je le regrette. Tu peux toujours mettre un bouton ou interrupteur conventionnel devant un petit module US/X.X qui pourra par après être remplacé. Mais au moins tu auras posé le bon cable. RE: BON JE ME LANCE - filou59 - 09/04/2017 Salut Perso j'ai du mal avec siemens que ce soit dans le monde de l'automatisme ou du KNX ^^. Un conseil regarde si tu arrives a récupérer toutes les doc, manuel et application et regarde si ca te convient. (Ca m'ai deja arrivé de chercher en vain de la doc sur des produits KNX) Il me semble que le BCU (Bus Coupler Unit) n'est pas intégré dans tes boutons. Il faut ajouter un truc du style UP117 Le BCU c'est la partie que tu connectes au bus. Il y a les produits avec BCU Intégré (c'est la tendance actuelle avec une majorité de fabriquant), et les produit avec BCU Séparé. Le BCU est le meme pour plusieurs produits, on vient l'emboiter au produit spécifique. (C'est une technique qui date du temps ou un ou 2 fabriquant faisait des BCU pour tous le monde et qui visait a reduire les cout, maintenant chaque fabriquant le fait lui meme sont BCU ou du moins l'intégre directement). Pour le detecteur de présence fait bien attention a bien prendre la référence que tu as mis, car si tu enleves le "-1" tu as le meme detecteur en version standard avec des fonction en moins RE: BON JE ME LANCE - hadjadji - 09/04/2017 (09/04/2017, 17:08:28)NicNac a écrit : Pour quelle raison veux-tu utiliser du binary input? Tu vas mélanger le conventionnel et KNX? Tu as complètement raison je vais modifier je me suis dit au cas où. RE: BON JE ME LANCE - hadjadji - 09/04/2017 (09/04/2017, 17:15:49)filou59 a écrit : Salut Salut j'ai fait avec siemens parce que je vais faire le stage chez eux et tu a raison je vais voir pour des produits avec BCU intégré. Pour le détecteur j'ai bien le "1" version universel. merci pour ces conseil. A+ RE: BON JE ME LANCE - hadjadji - 10/04/2017 Hello j'ai trouve ca. lien KNX siemens. https://www.hqs.sbt.siemens.com/cps_product_data/data/search_find_fr.htm |
