Read alarm contacts what knx need hardware? - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : ETS (https://www.knx-fr.com/forumdisplay.php?fid=9) +--- Sujet : Read alarm contacts what knx need hardware? (/showthread.php?tid=4988) |
Read alarm contacts what knx need hardware? - Williamhawk - 03/11/2017 Hello, INCERT approved alarm system (INIM brand). Using extension modules, I can read contacts, for example: Has the alarm been armed? Does the alarm go off? Are openings of doors / windows open? Now I would like to read these extensions of KNX expansion modules. What do I need for this? Is that a binary input (eg analog input)? Can you give 1 or a few specific examples? Overall, I would like to read 13 numbers of contacts: 10x status windows / doors, 1x fully armed alarm, 1x army alarm, 1x alarm goes off Further, the question of whether to work with relays here. I ask this question because my install swears when using relays as security. For the time being, Omron MY2in-D2 12VDC relay. I did not find the right solution from the internet. References: http://www.knx-forum.be/viewtopic.php?f=5&t=1528&sid=6a420da1aaf54dae0b14bf0f3a775c94 best advertisements |
