KNX vs IP - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Archives eib-domotique (https://www.knx-fr.com/forumdisplay.php?fid=8) +--- Sujet : KNX vs IP (/showthread.php?tid=715) |
KNX vs IP - airliner - 07/09/2008 http://www.maison-domotique.com/edito.php?edito=19 bonne lecture... ps : connaissez vous des produits? KNX vs IP - Steven - 08/09/2008 IP is only a medium. It only specifies the Network Layer of a communication, and not a complete communication system. For reference: KNX specifies everything from the lowest Physical Layer to the highest Application Layer. That being said, it is thus clear that with IP, you can transfer a telegram along a network and route it, but nothing else. IP furst of all does not define a medium. It runs on radio waves (RF WLAN), Ethernet, optical fibre. That is the first choice that the author has to make: do you install 10 MBit/s, 100 MBits (Cate 5, Cate 5e ....). But that is more a power of IP than a weakness. But for the higher levels of the communication stack, IP does not define anything. That is why we all know higher level protocols on top of IP, like: - http to transfer text - ftp to transfer files - POP and SMTP for e-mail.... So, IP is not enough. To be able to do something (read the internet, send/receive e-mails), you need additional protocols. Also for doing home and building automation on IP, you will thus need additional protocols on top of and using IP. This can for instance be KNX IP, we all the good things of KNX from Twisted Pair: an open protocol, a standard, Interworking, only a single tool to learn and more than one provider. On 8 sep, 00:21, airliner <fbourg...@gmail.com> wrote: > http://www.maison-domotique.com/edito.php?edito=19 > > bonne lecture... > > ps : connaissez vous des produits? KNX vs IP - Marc Assin - 08/09/2008 On 8 sep, 00:21, airliner <fbourg...@gmail.com> wrote: > ps : connaissez vous des produits? C'est peut-être une bonne question à poser à Patrice ROGEMONT, modérateur du forum LMD ? Il faut juste cliquer sur sa signature et remplir le formulaire. Et puis lancer une idée sans information concrète de mise en service, j'apelle çà "pétroler". Est-ce la faim qui pousse le loup hors du bois ? X10 a montré ses limites et commence à s'essoufler, faut bien trouver une autre "solution". Alors ? pendant des années LMD a fait la promotion et a vendu du X10, à tiré à boulet rouge sur EIB, alors on peut difficilement faire marche arrière. PS: Est-ce une bonne idée sur le forum "domotique-EIB" de faire l'apanage de solutions autres ? alors que le même Patrice ROGEMONT a refusé de publier la création du forum "domotique-EIB" ??? Il me semble que le forum "fr.sci.techniques.domotique", qui est plus domotique générique, est plus approprié pour ce genre de discussion. KNX vs IP - stephane.herraiz@gmail.com - 08/09/2008 Je viens de voir cet éditorial et je voulais poster un mesage réactionnaire à ce sujet mais apparemment je me suis fait devancer ;-). Je trouvais déjà ce site mal fait.... Là on est en plein délire : - "enfermement protocolaire (Konnex) " : normal c'est un protocole comme IPV6 au fait!!! - IPV6 demanderait de gros investissement dans les uC de chaque élément. - Côté pratique : Le câble cat 5e voir 6 est difficile à mettre en place, fragile , rayon de courbure important... - Je ne vois pas l'intérêt d'avoir une IP "externe" pour chaque interrupteur. Et le routage c'est pas pour les chiens et question sécurité ça protège. Je vois bien ricané quelques pirates : pour noël ville guirlande au programme!!! La LMD est encore, en 2008, en train de chercher un protocole domotique... C'est pas gagner!!! Le protocole KNX a certes des défauts mais une très grande qualité : LUI IL MARCHE ET IL EXISTE! C'est vrai que l'IPv6 permet d'avoir qu'un seul câble pour faire passer commandes, voix, image, café ;-) mais comme je l'ai dit plus haut il y a des inconveniants. Alors LMD c'est pour quand la domotique... 2015!? a++ On 8 sep, 09:16, Marc Assin <raym...@warichet.com> wrote: > On 8 sep, 00:21, airliner <fbourg...@gmail.com> wrote: > > > ps : connaissez vous des produits? > > C'est peut-être une bonne question à poser à Patrice ROGEMONT, > modérateur du forum LMD ? Il faut juste cliquer sur sa signature et > remplir le formulaire. > > Et puis lancer une idée sans information concrète de mise en service, > j'apelle çà "pétroler". > > Est-ce la faim qui pousse le loup hors du bois ? X10 a montré ses > limites et commence à s'essoufler, faut bien trouver une autre > "solution". Alors ? pendant des années LMD a fait la promotion et a > vendu du X10, à tiré à boulet rouge sur EIB, alors on peut > difficilement faire marche arrière. > > PS: Est-ce une bonne idée sur le forum "domotique-EIB" de faire > l'apanage de solutions autres ? alors que le même Patrice ROGEMONT a > refusé de publier la création du forum "domotique-EIB" ??? > > Il me semble que le forum "fr.sci.techniques.domotique", qui est plus > domotique générique, est plus approprié pour ce genre de discussion. KNX vs IP - Alexandre Tichit - 08/09/2008 Bonjour, Avis aux installateurs qui connaissent bien les problèmes de "rayonnement" Quel cable faudra t'il donc utiliser pour ne pas risquer la moindre "pollution" du système full IP ? - Du CAT 6 SFTP...? Et quel est le prix de ce cable pour 500M ? Il faudra certainement attendre la "super" démocratisation du "fiber chanel multimode" pour atteindre le myte de la maison ultra communicante...? Bonne journée. Le 8 septembre 2008 11:25, stephane.herraiz@gmail.com < stephane.herraiz@gmail.com> a écrit : > > Je viens de voir cet éditorial et je voulais poster un mesage > réactionnaire à ce sujet mais apparemment je me suis fait > devancer ;-). > Je trouvais déjà ce site mal fait.... Là on est en plein délire : > - "enfermement protocolaire (Konnex) " : normal c'est un protocole > comme IPV6 au fait!!! > - IPV6 demanderait de gros investissement dans les uC de chaque > élément. > - Côté pratique : Le câble cat 5e voir 6 est difficile à mettre en > place, fragile , rayon de courbure important... > - Je ne vois pas l'intérêt d'avoir une IP "externe" pour chaque > interrupteur. Et le routage c'est pas pour les chiens et question > sécurité ça protège. Je vois bien ricané quelques pirates : pour noël > ville guirlande au programme!!! > > La LMD est encore, en 2008, en train de chercher un protocole > domotique... C'est pas gagner!!! > Le protocole KNX a certes des défauts mais une très grande qualité : > LUI IL MARCHE ET IL EXISTE! > C'est vrai que l'IPv6 permet d'avoir qu'un seul câble pour faire > passer commandes, voix, image, café ;-) mais comme je l'ai dit plus > haut il y a des inconveniants. > > Alors LMD c'est pour quand la domotique... 2015!? > a++ > > On 8 sep, 09:16, Marc Assin <raym...@warichet.com> wrote: > > On 8 sep, 00:21, airliner <fbourg...@gmail.com> wrote: > > > > > ps : connaissez vous des produits? > > > > C'est peut-être une bonne question à poser à Patrice ROGEMONT, > > modérateur du forum LMD ? Il faut juste cliquer sur sa signature et > > remplir le formulaire. > > > > Et puis lancer une idée sans information concrète de mise en service, > > j'apelle çà "pétroler". > > > > Est-ce la faim qui pousse le loup hors du bois ? X10 a montré ses > > limites et commence à s'essoufler, faut bien trouver une autre > > "solution". Alors ? pendant des années LMD a fait la promotion et a > > vendu du X10, à tiré à boulet rouge sur EIB, alors on peut > > difficilement faire marche arrière. > > > > PS: Est-ce une bonne idée sur le forum "domotique-EIB" de faire > > l'apanage de solutions autres ? alors que le même Patrice ROGEMONT a > > refusé de publier la création du forum "domotique-EIB" ??? > > > > Il me semble que le forum "fr.sci.techniques.domotique", qui est plus > > domotique générique, est plus approprié pour ce genre de discussion. > KNX vs IP - domotiqa.com - 08/09/2008 passons tout en cat 7 et utilisons uniquement deux paires pour le knx! KNX vs IP - jef2000 - 08/09/2008 Impressionnant comme l'auteur arrive à glisser "à la mine-de-rien" 2 liens vers la centrale domotique varuna3 vendue sur son site. Si ça c'est un point de vue objectif et désintéressé sur le marché de la domotique, moi je suis le pape.... Ensuite il y a ce magistral: "Pour ma part et sur la quantité de chantiers que je vois passer, nous constatons aujourd’hui que dans 8 cas sur 10 et « à fonctionnalité égale » avec certain matériels, une installation EIB/KNX est susceptible de coûter de 10 à 40% plus chère que certains systèmes qui joueront « l’ouverture et la compatibilité full IP » à court terme !" Donc le monsieur nous explique que sur les chantiers, il constate aujourd'hui qu'un produit qui n'existe pas encore est 10 à 40% moins cher que de l'EIB/KNX.... C'est Chuck Norris le monsieur?? Tout ceci bien sûr avec les précautions d'usage du style "avec certains matériels" ou "est susceptible de". Je peux faire pareil en affirmant qu'a fonctionnalité égale, avec certains matériels, une installation KNX peut coûter 10 à 40% plus cher qu'une autre installation KNX. Quand à l'"enfermement protocolaire", il à l'air d'oublier que comme expliqué plus haut dans ce fil de discussion, IPv6 n'est qu'une seule des nombreuses couches nécessaires pour constituer un système domotique complet. Pour ce qui concerne les couches supérieures, je suppose que le même processus va se répéter encore et encore. Chaque fabricant va développer son propre protocole propriétaire utilisant IPv6 comme moyen de communication et ce n'est que des années plus tard qu'émergera un protocole standardisé définissant ce qui doit être envoyé sur IPv6 pour allumer une lampe ou modifier la température d'un thermostat. (si ça se trouve, ce protocole s'appellera KNXnet/IPv6 ... LOL) Pour ce qui est des couches inférieures, la compétition est ouverte. Ethernet ? Avec un cable réseau depuis le coffret jusqu'à chaque interrupteur et une armoire complète de switch dans le coffret? J'imagine bien le foutoir.... Ou alors chaque interrupteur serait un hub pour le suivant? On peut également imaginer du wifi, mais vu le faible nombre de canaux disponibles, la saturation rend déjà sa mise en oeuvre hasardeuse en milieu urbain. Et rien n'empècherait un voisin de paralyser toute votre installation électrique en allumant simplement quelques points d'accès wifi. Un autre candidat? La fibre optique? Dans ce cas on oublie les solutions du type power-over-ethernet et on double le réseau données d'un réseau d'alimentation pour les appareils connectés. (Pour alimenter tous les interrupteurs, je propose un cable 2x0,8mm2 torsadé avec un fil rouge et un noir.... Et pourquoi pas une gaine verte autour LOL ) Bref, IPv6 dans les interrupteurs ce n'est pas pour demain, et les gens qui attendent la solution miracle décideront probablement d'en attendre une autre encore plus miracle lorsque la première sera disponible et qu'on se rendra compte qu'elle n'est pas si miracle que ça. Et j'ai beaucoup de mal à imaginer un device IPv6 tenir dans un boitier aussi petit qu'un BCU KNX et à un prix compétitif (Actuellement un tel système serait nettement plus cher qu'un BCU et si les progrès technologiques font baisser les prix, ce sera sur les deux tableaux) Par contre, nul doute que si l'IPv6 se généralise, il existera des passerelles IPv6 / KNX. Bien à vous, Jean-François On 8 sep, 12:16, "Alexandre Tichit" <tical1...@gmail.com> wrote: > Bonjour, > > Avis aux installateurs qui connaissent bien les problèmes de "rayonnement" > > Quel cable faudra t'il donc utiliser pour ne pas risquer la moindre > "pollution" du système full IP ? > > - Du CAT 6 SFTP...? > > Et quel est le prix de ce cable pour 500M ? > > Il faudra certainement attendre la "super" démocratisation du "fiber chanel > multimode" pour atteindre le myte de la maison ultra communicante...? > > Bonne journée. > > Le 8 septembre 2008 11:25, stephane.herr...@gmail.com < > stephane.herr...@gmail.com> a écrit : > > > > > > > Je viens de voir cet éditorial et je voulais poster un mesage > > réactionnaire à ce sujet mais apparemment je me suis fait > > devancer ;-). > > Je trouvais déjà ce site mal fait.... Là on est en plein délire : > > - "enfermement protocolaire (Konnex) " : normal c'est un protocole > > comme IPV6 au fait!!! > > - IPV6 demanderait de gros investissement dans les uC de chaque > > élément. > > - Côté pratique : Le câble cat 5e voir 6 est difficile à mettre en > > place, fragile , rayon de courbure important... > > - Je ne vois pas l'intérêt d'avoir une IP "externe" pour chaque > > interrupteur. Et le routage c'est pas pour les chiens et question > > sécurité ça protège. Je vois bien ricané quelques pirates : pour noël > > ville guirlande au programme!!! > > > La LMD est encore, en 2008, en train de chercher un protocole > > domotique... C'est pas gagner!!! > > Le protocole KNX a certes des défauts mais une très grande qualité : > > LUI IL MARCHE ET IL EXISTE! > > C'est vrai que l'IPv6 permet d'avoir qu'un seul câble pour faire > > passer commandes, voix, image, café ;-) mais comme je l'ai dit plus > > haut il y a des inconveniants. > > > Alors LMD c'est pour quand la domotique... 2015!? > > a++ > > > On 8 sep, 09:16, Marc Assin <raym...@warichet.com> wrote: > > > On 8 sep, 00:21, airliner <fbourg...@gmail.com> wrote: > > > > > ps : connaissez vous des produits? > > > > C'est peut-être une bonne question à poser à Patrice ROGEMONT, > > > modérateur du forum LMD ? Il faut juste cliquer sur sa signature et > > > remplir le formulaire. > > > > Et puis lancer une idée sans information concrète de mise en service, > > > j'apelle çà "pétroler". > > > > Est-ce la faim qui pousse le loup hors du bois ? X10 a montré ses > > > limites et commence à s'essoufler, faut bien trouver une autre > > > "solution". Alors ? pendant des années LMD a fait la promotion et a > > > vendu du X10, à tiré à boulet rouge sur EIB, alors on peut > > > difficilement faire marche arrière. > > > > PS: Est-ce une bonne idée sur le forum "domotique-EIB" de faire > > > l'apanage de solutions autres ? alors que le même Patrice ROGEMONT a > > > refusé de publier la création du forum "domotique-EIB" ??? > > > > Il me semble que le forum "fr.sci.techniques.domotique", qui est plus > > > domotique générique, est plus approprié pour ce genre de discussion. > > -- > Cordialement. > > Tichit Alexandre > > CIDEL FRANCE SA > > 13, rue Rosenwald > 75015 Paris > > 33 1 45 30 09 60 Tél > 33 1 42 50 87 07 Fax > 33 6 61 63 62 55 Mob > 216 98 42 65 12 Tunisie > 216 71 77 70 09 Tunisie > > Skype ID : tical1969 > > Pensez ENVIRONNEMENT : n'imprimez que si nécessaire. > Please consider the environmental impact before printing this e-mail. KNX vs IP - Dfrog - 08/09/2008 On 8 sep, 14:05, "domotiqa.com" <cont...@domotiqa.com> wrote: > passons tout en cat 7 et utilisons uniquement deux paires pour le knx! Le Cat 7 n'existe pas, ou uniquement dans les programmes marketing de certains fabricants ! d'autre part, si vous voulez passer du protocole KNX dans autre chose que dans le câble EIB, il vous faudra vous assurer que la compatiblilté électromagnétique est bien respectée (CAt5 et CAT6 avec un signal en-dessous de 250MHz --> la performance du câble n'est plus garantie, de même pour le blindage, qu'il soit magnétique ou mécanique !). Le câble EIB a été conçu pour ça! Dans un post précédant, il est rappelé que les caractéristiques de ces câbles sont obtenues avec un usage bien précis... KNX vs IP - Marc Assin - 08/09/2008 On 8 sep, 14:05, "domotiqa.com" <cont...@domotiqa.com> wrote: > passons tout en cat 7 et utilisons uniquement deux paires pour le knx! ûûh ?!? Est-ce bien là une recommendation d'un "specialiste knx/eib, domotique, multiroom, home cinéma, informatique, reseaux " ??? KNX vs IP - stephane.herraiz@gmail.com - 08/09/2008 mais non c'était une blague!!!! ;-D On 8 sep, 17:48, Marc Assin <raym...@warichet.com> wrote: > On 8 sep, 14:05, "domotiqa.com" <cont...@domotiqa.com> wrote: > > > passons tout en cat 7 et utilisons uniquement deux paires pour le knx! > > ûûh ?!? > Est-ce bien là une recommendation d'un > "specialiste knx/eib, domotique, multiroom, home cinéma, informatique, > reseaux " ??? KNX vs IP - Marc Assin - 08/09/2008 On 8 sep, 18:13, "stephane.herr...@gmail.com" <stephane.herr...@gmail.com> wrote: > mais non c'était une blague!!!! ;-D Ha ! Tu m'as bien eu ! 1 - 0 KNX vs IP - fred - 09/09/2008 > si vous voulez passer du protocole > KNX dans autre chose que dans le câble EIB, il vous faudra vous > assurer que la compatiblilté électromagnétique est bien respectée > (CAt5 et CAT6 avec un signal en-dessous de 250MHz --> la performance > du câble n'est plus garantie, de même pour le blindage, qu'il soit > magnétique ou mécanique !). Le câble EIB a été conçu pour ça! Je n'ai rien vérifié du tout et il n'y a pas de blindage mais j'ai 2 devices EIB au bout de 2 segments de 30m de cat5 (en point à point) et ca marche nickel chrome ici. 9600 baud, c'est quand même pas trop sensible comme modulation. Le problème est plus avec l'alimentation des devices, en tension et courant, je pense. Fred KNX vs IP - fred - 09/09/2008 > PS: Est-ce une bonne idée sur le forum "domotique-EIB" de faire > l'apanage de solutions autres ? alors que le même Patrice ROGEMONT a > refusé de publier la création du forum "domotique-EIB" ??? Personellement, je pense utile de permettre ici le débat sur les idée du Monsieur - en particulier car cela démontre d'une ouverture d'esprit et d'une tolérance qui lui font apparement défaut. Ensuite, je me réjouis de constater que les avis semblent unanimes (à raison): le Monsieur en question n'a pas tout compris. Enfin, je pense utile de rétablir sinon "la vérité", en tout cas un certain équilibre, sur le web francophone. Donc je serais plutôt d'avis de laisser le thread vivre que de tenter de l'étouffer. Le problème de l''éditorial de Monsieur de Rogemont sur son site La Maison de la Domotique, ce n'est pas tant qu'il affiche son dégout pour KNX, c'est plus qu'il vante les mérites d'un hypothétique système soit qui n'existera jamais, soit qui existera sous une forme qui ne satisfera pas M. de Rogemont. (a) Il n'y a pas de différence de cout entre une interface ethernet IPv4 et IPv6. Le matériel est le même (par définition). Donc ce n'est pas l'arrivée de IPv6 qui va précipiter vers le bas le prix des interfaces et généraliser leur usage dans les cafetières. (b) IPv6 permet en effet d'identifier de manière unique chaque appareil. Aujourd'hui, c'est déjà possible avec l'adresse MAC. Donc ? © Dans quelle mesure l'addressage unique permet la domotique est un mystere, car IPv4 aujourd'hui est parfaitement capable de faire la même chose (routage, NAT) et que je ne pense pas judicieux d'exposer ma cafetiere directement sur le web (ce week-end, j'ai patché ma cafetière, elle avait un virus comme mon four ![]() (d) IP est magnifique, mais pour être "universel", il faudrait également normer la couche physique (cad ethernet, wifi, etc). Je doute que beaucoup de foyer soient dotés d'une prise ethernet dans leur cuisine pres du four. Donc on parlerait de wifi ? (mais ca marche plus quand le micro onde est en fonction), de courant porteur ? (e) Comme mentionné plus haut, IP c'est juste la "plomberie" de transport entre deux devices, mais pas le format des messages. Bref, je ne peux pas juger si M. de Rogemont n'a pas franchement compris son métier ou si il espère tromper l'ennemi, mais cet article est bon à jeter. Fred KNX vs IP - Dfrog - 09/09/2008 > > Je n'ai rien vérifié du tout et il n'y a pas de blindage mais j'ai 2 > devices EIB au bout de 2 segments de 30m de cat5 (en point à point) et > ca marche nickel chrome ici. 9600 baud, c'est quand même pas trop > sensible comme modulation. > > Le problème est plus avec l'alimentation des devices, en tension et > courant, je pense. > > Fred Je précise : la question n'est si ça marche ou pas (j'ai personnellement fait un lien avec du vieux fils téléphone pour un interrupteur parce que je ne pouvais pas retirer un nouveau câble... mais ne le dite à personne... ;-)), le protocole KNX fonctionnera à peu près toujours, du moins dans l'habitat, mais il s'agit d'être conforme à la norme sur la compatibilité électromagnétique ( norme qui définit la capacité d'un câble non seulement de résister aux perturbations électromagnétiques externes, mais aussi et surtout de ne pas être à l'origine de perturbations). Et c'est dans ce dernier point que l'usage d'un câble avec une fréquence et un signal pour lequel il n'a pas été conçu peut être porteur de problèmes, problèmes qui ne seront probablement pas visibles sur KNX, mais qui pourrait l'être sur les ondes radios légales ou la réception TV de votre voisin... C'est la raison pour laquelle une telle réglementation existe (je ne me souvient plus exactement... CEN 55000 et des poussières...). Et c'est pour ça qu'un câble particulier à été développé pour EIB! Pour le CAT7, j'ai bien pensé que, venant de Stéphane, c'était une farce, mais tout le monde n'est pas dans ce cas, et beaucoup d'utilisateurs ne savent pas que la CAT7 est elle aussi une farce ! KNX vs IP - Alexandre Tichit - 09/09/2008 Messieurs, Pourrions nous donc clôturer ce sujet qui reste de l'ordre du fantasme pour encore quelques décennies:o) Cela ressemble "trop" en tout point aux effets d'annonces stériles tels que ceux qui furent annoncés jadis lors du "révolutionnaire" CPL qui finalement affiche à l'usage aujourd'hui bon nombre de limites et de perturbations. Bonne journée. Le 9 septembre 2008 07:16, Dfrog <frossard@fmn.ch> a écrit : > > > > > > > Je n'ai rien vérifié du tout et il n'y a pas de blindage mais j'ai 2 > > devices EIB au bout de 2 segments de 30m de cat5 (en point à point) et > > ca marche nickel chrome ici. 9600 baud, c'est quand même pas trop > > sensible comme modulation. > > > > Le problème est plus avec l'alimentation des devices, en tension et > > courant, je pense. > > > > Fred > > Je précise : la question n'est si ça marche ou pas (j'ai > personnellement fait un lien avec du vieux fils téléphone pour un > interrupteur parce que je ne pouvais pas retirer un nouveau câble... > mais ne le dite à personne... ;-)), le protocole KNX fonctionnera à > peu près toujours, du moins dans l'habitat, mais il s'agit d'être > conforme à la norme sur la compatibilité électromagnétique ( norme qui > définit la capacité d'un câble non seulement de résister aux > perturbations électromagnétiques externes, mais aussi et surtout de ne > pas être à l'origine de perturbations). Et c'est dans ce dernier point > que l'usage d'un câble avec une fréquence et un signal pour lequel il > n'a pas été conçu peut être porteur de problèmes, problèmes qui ne > seront probablement pas visibles sur KNX, mais qui pourrait l'être sur > les ondes radios légales ou la réception TV de votre voisin... C'est > la raison pour laquelle une telle réglementation existe (je ne me > souvient plus exactement... CEN 55000 et des poussières...). Et c'est > pour ça qu'un câble particulier à été développé pour EIB! > > Pour le CAT7, j'ai bien pensé que, venant de Stéphane, c'était une > farce, mais tout le monde n'est pas dans ce cas, et beaucoup > d'utilisateurs ne savent pas que la CAT7 est elle aussi une farce ! > KNX vs IP - stephane.herraiz@gmail.com - 09/09/2008 oula relisez ça vient pas de moi le cat 7 (je savais même pas que ça existait :-D) On 9 sep, 07:16, Dfrog <fross...@fmn.ch> wrote: > > Je n'ai rien vérifié du tout et il n'y a pas de blindage mais j'ai 2 > > devices EIB au bout de 2 segments de 30m de cat5 (en point à point) et > > ca marche nickel chrome ici. 9600 baud, c'est quand même pas trop > > sensible comme modulation. > > > Le problème est plus avec l'alimentation des devices, en tension et > > courant, je pense. > > > Fred > > Je précise : la question n'est si ça marche ou pas (j'ai > personnellement fait un lien avec du vieux fils téléphone pour un > interrupteur parce que je ne pouvais pas retirer un nouveau câble... > mais ne le dite à personne... ;-)), le protocole KNX fonctionnera à > peu près toujours, du moins dans l'habitat, mais il s'agit d'être > conforme à la norme sur la compatibilité électromagnétique ( norme qui > définit la capacité d'un câble non seulement de résister aux > perturbations électromagnétiques externes, mais aussi et surtout de ne > pas être à l'origine de perturbations). Et c'est dans ce dernier point > que l'usage d'un câble avec une fréquence et un signal pour lequel il > n'a pas été conçu peut être porteur de problèmes, problèmes qui ne > seront probablement pas visibles sur KNX, mais qui pourrait l'être sur > les ondes radios légales ou la réception TV de votre voisin... C'est > la raison pour laquelle une telle réglementation existe (je ne me > souvient plus exactement... CEN 55000 et des poussières...). Et c'est > pour ça qu'un câble particulier à été développé pour EIB! > > Pour le CAT7, j'ai bien pensé que, venant de Stéphane, c'était une > farce, mais tout le monde n'est pas dans ce cas, et beaucoup > d'utilisateurs ne savent pas que la CAT7 est elle aussi une farce ! KNX vs IP - Fabrice Cizeron - 09/09/2008 Bonjour, Il me semble moi aussi tout à fait opportun de discuter ici d'un article qui compare d'autres solutions à EIB surtout si ça permet de mettre à jour des erreurs dedans. Si en plus il y a censure envers nous par ailleurs il ne faut pas ce mettre à leur niveau... En en plus il vient d'en prendre pour son grade ! tant mieux... KNXement, Fabrice Marc Assin a écrit : > On 8 sep, 00:21, airliner <fbourg...@gmail.com> wrote: > > PS: Est-ce une bonne idée sur le forum "domotique-EIB" de faire > l'apanage de solutions autres ? alors que le même Patrice ROGEMONT a > refusé de publier la création du forum "domotique-EIB" ??? > KNX vs IP - stephane.herraiz@gmail.com - 23/09/2008 http://www.usinenouvelle.com/article/machine-to-machine-l-ipso-alliance-prone-l-ip.147104 Encore une initiative malheureuse pour l'IPv6. Que d'énergie dépensée... de dollars investie... Ou s'arrêteront ils? Encore un complot du grand capital (CISCO cette fois)! a+ KNX vs IP - airliner - 24/09/2008 Pendant ce temps chez KNX ....La sieste continue... F. Bzzzzzzzzz Rhoôôôoôoo Bzzzzzz On 23 sep, 09:39, "stephane.herr...@gmail.com" <stephane.herr...@gmail.com> wrote: > http://www.usinenouvelle.com/article/machine-to-machine-l-ipso-allian... > > Encore une initiative malheureuse pour l'IPv6. Que d'énergie > dépensée... de dollars investie... > Ou s'arrêteront ils? > Encore un complot du grand capital (CISCO cette fois)! > a+ KNX vs IP - fred - 24/09/2008 > Pendant ce temps chez KNX ....La sieste continue... Les bienheureux... Que jugerais-tu plus judicieux ? KNX vs IP - airliner - 25/09/2008 Je sais pas moi je suis pas marketeux mais il faut un plan de com. S'inspirer de ce que font les grand de l'informatique... 1/ de la communication, promouvoir le protocole !! => Imposer aux constructeurs d'apposer le logo KNX partout facon Intel. de telle sorte que les particulier en entende parler, que les professionnels identifie l'ensemble des produits de chacun des constructeurs ! => relayer au sein des médias les innovations du secteur. Démonstrations aux journalistes, présence dans les salons, conférences etc... => Donner envie aux clients finaux => Investir dans la formation, packages de formation dans les écoles d'électriciens, d'ingénieurs etc.. 2/ Faire évoluer le protocole => montrer que la communauté est active et va de l'avant. => avoir un groupe de recherche qui fais évoluer le protocole vers l'avenir ! => promouvoir les initiatives opensource et la com vers les développeurs car la communauté est tres interessée par les nlles techno 3/ Avoir une politique commerciale => demander aux constructeurs d'avoir une politique commerciale aggressive => faire du lobbiing autour de l'ecologie. => faire en sorte que ces produits soient accessibles du grand public et des bricoleurs (politique de diffusion) Bref en un mot etre omni présent, occuper la scéne. Y croire ! Ce ne sont que des pistes. Fabrice On 25 sep, 00:03, fred <frederic.thomas...@gmail.com> wrote: > > Pendant ce temps chez KNX ....La sieste continue... > > Les bienheureux... > > Que jugerais-tu plus judicieux ? KNX vs IP - fred - 26/09/2008 Je pense qu'ils font tout ca! 1/ Il existe un bus EIB avec tous les derniers gadgets qui se balade dans les expos grand public. Il n'existe peut-etre plus, mais il existait en 2002 et il était présent à Maison & Jardins à Lausanne. La même année, j'ai aussi vu un équivalent dans une expo à Vienne. Peut-être qu'ils sont moins présent en France? 2/ Le dernier développement est exactement ce dont on parle dans ce thread: du pur EIB-over-IP-over-Ethernet. 3/ KNX est compétitif par rapport à des solutions équivalentes (en terme de qualité, de complétude, de support, de normes) - et est probablement le seul à proposer une interopérabilité entre vendeurs. Fred |
