KnxConnection: Failed to open knxConnection url. - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Archives eib-domotique (https://www.knx-fr.com/forumdisplay.php?fid=8) +--- Sujet : KnxConnection: Failed to open knxConnection url. (/showthread.php?tid=909) |
KnxConnection: Failed to open knxConnection url. - chitloft - 25/10/2010 bonjour à tous. voila, ca fait 1 semaine que j'essaie de refaire une VM debian en suivant le tuto. Mais voila, j'ai une erreur : 2010-10-25 20:02:39 [ INFO] main: Config file loaded: /var/www/knxweb/ linknx.xml 2010-10-25 20:02:39 [ERROR] KnxConnection: Failed to open knxConnection url. Quelqu'un pourrait m'aider ? Merci Arnaud voici le modop : cd /home mkdir linknx apt-get install gcc apt-get install g++ make apt-get install php5 php5-cgi php5-mysql mysql-server phpMyAdmin apt-get install libpthsem20 apt-get install bcusdk apt-get install liblog4cpp5 liblog4cpp5-dev lua5.1 apt-get install libmysqlclient15-dev cd linknx wget http://downloads.sourceforge.net/sourceforge/bcusdk/pthsem_2.0.8.tar.gz wget http://downloads.sourceforge.net/sourceforge/bcusdk/bcusdk_0.0.4.tar.gz wget http://downloads.sourceforge.net/sourceforge/linknx/linknx-0.0.1.27.tar.gz wget http://sourceforge.net/projects/linknx/files/knxweb/knxweb-0.6/knxweb-0.6.1.tar.gz tar -xzf linknx-0.0.1.27.tar.gz tar -xzf bcusdk_0.0.4.tar.gz tar -xzvf pthsem_2.0.8.tar.gz cd /home/linknx/pthsem-2.0.8/ ./configure make make test make install export LD_LIBRARY_PATH=/usr/local/lib cd ../bcusdk-0.0.4/ ./configure --enable-onlyeibd --enable-eibnetiptunnel --enable-usb -- enable-eibnetipserver --enable-ft12 make make install vi /opt/linknx/cle -----BEGIN PGP PUBLIC KEY BLOCK----- Version: GnuPG v1.4.6 (GNU/Linux) mQGiBEXPVPkRBACwcKSAeUo+rK3ZVRy0cfKVsShbPcB9SlviBaagi5qLqduSKeGU UX+r2UO+UTaS8Btj8zP+J5cLBtqUah/wVIIz72t8Mxo9Wmdl3EJenFghPaKrHrMp eUktVgKGdIjo62YSABPtD7ffX8lTJBFoSvXFeoz3BddYIXQZOsOK//PEpwCg2cBQ AmbNbDix8zB2GBJWhx3MBuUEAJzQ+Yv206A5qPulgC54NrSMlU9ZXYimEtok4cq2 zxpY4ZiEtXpmcVhXGmVowRrPl9lNP5E2LMAxg5lFkyOkScJxUMkdh/QnJfrmldCH M+moHDAopK6OPNeNMYpQGOpsG/iIunoLSrrQtYJ17HY4Lk1oT3g9S6Wkd10VGTJP r/P/A/9OvsfRWz69gm6lOotidFtLhUXovO8DttmfMZWp0MQ1V8lYmh0KdC4rwMGF QlRQl1Zb1ulDwarGJYhnpC4jSf1IliqlRmcS3Upoo9SbjxXWpEjVbAx71ImA69rG c7UG7E5jYPOTpARt4PvDY/ZubDwD+B2bWKCiqgSBbjZdV06BUbQxTWFydGluIEtv ZWdsZXIgKEFQVCkgPG1rb2VnbGVyQGF1dG8udHV3aWVuLmFjLmF0PohgBBMRAgAg BQJFz1T5AhsDBgsJCAcDAgQVAggDBBYCAwECHgECF4AACgkQfcT/RZkb82GC4QCd EVYs5uqhWOjYWWT5xIJBTIrj8WIAoLtV4sYwpzxDD7yqXXicHELUNZFZiEYEEBEC AAYFAkXPWTIACgkQoXeJnTy1y1iZZACdEs/tivUZKNrAAduspDq5FjO2MgIAn0Nz 85W6JFjMRlzX+Og8elioeAD+uQQNBEXPVXMQEADKTndElLepjtldq/6Rwhi4YlmG zi1GyswXuqRiTJHvmTA9M7TjRgFPeluafs6hfQYgTMXguM9nPF4cSz5x+G5nDxtL 4EPy+RhoupTwp0JEJwcnic9sE5UXnIUTYTdAG0C15eQ/DTOqj7VY/DeYA1kEgc+6 Hj2zSlEyBYOferRNERPju4QVoIUwBnp8XW0kB8DI646WwOx5inutGXeH4tLfEKB/ JHYMb4QyYKSAxeMVaxsacHvgWYmtZpM0Z6wyE56K9mixtcOijHFMHpkhX73OJfz5 tq4K8XxpbLU4o1ClbFa3f1cCv/nBCcT6AeykZiW2irXhGwFa33aRk+5Js7vmeWPX U7ZpU5c7jhVwRUPNQW74FIiw7q1rtloBWJ3L81m4/UEhH4aCz/Ef/+rogVGiHW6K KVzgggkBsHGtKwcVjgqmBLQdhDjNl7hnM48lJSpcC3NpwWMYgRBlo6STyWdtvHqh 6I46ULtQLDCzH2l18nsWRVPzLC/bu+shM7ExseRiCMOMe2gxSxW/e/QvTSrmetdZ YiWVWHUJptLpNFwEs32a8S1+Wn81T7MDHyHugt/hmrHyuyt9NP4/EdZTlxdvEX8x To6mh6H8Ngvvrq6wRpEtVaKuICwbnh6UGTVj/I31G+QdJzg+gE17GhFd2jqq7Xx5 RI5DTdUvXNfK1gZ/MwADBQ//ZvpptIYg28NNtxxn7Z0gTBpLN5LHSoM3wlQNWx3M 1bxaJZQHozqljscydhjFQbHTd5OYSvAQ1wDlwRhTHePJGuhj9BsumCTDTsRMOiyw MAe5CUqyxygB+Cj7tMvYI9X9JtHrnz94zHbZ3rhXBHtcD8ZhdYEeISkqdJvdY3z7 V3zIQ9fapUC6MMrMMo6i6eu2zO6gHPHT0hYAWRbAkorNbePnPAXM5VeaoAEHWeKq wgHclaj86zFj0/K0LJr6m4t9uAZS6xbGjf0DNbDUN5NBB8C6tYnlhsWslr9nQ/6Q Y5x3plVny9woyntgz79pDpiR8k8Q8AZWGgVybUvX737rWkTa7JpgiD4/DCC/spZf QoAt/nFv1I53FuQOfp/KNZAWJDE3LBB+4u/N5fWg4Yp5Lwy5seIoeTtNAY4Wwo7b rdIHbcDW1AZddADOlPn0Xx4PlL8X/+vo68gEWCVX1o9hx3xELkmMTmhIgug/pJgE XYiCUp3UIs+QU2sKnRLFNBeKHzMqklPh0Ep32NYHGO70mphLk52MQcY5eK6mouta WV080y14A6hL1kktWF1S7e8LAYVEgfIKpr+C6Lv/KRwWZSCC1X6mdr+60jBqxyBI jan5mdYrIVQ2eL9RpnVk0HizREdeqE8D/fHv6S2U/ufcUrkVxno9vYmh4LF1Fppp SJqISQQYEQIACQUCRc9VcwIbDAAKCRB9xP9FmRvzYee6AJ0TiiG8/dM4ppd0dXNT gIiDW8wHbACeO11PFfwbx51XEx0+kW81XDVxHPg= =ztcU -----END PGP PUBLIC KEY BLOCK----- apt-key add cle vi /etc/apt/sources.list deb http://www.auto.tuwien.ac.at/~mkoegler/debian eib main deb-src http://www.auto.tuwien.ac.at/~mkoegler/debian eib main apt-get update apt-get install bcusdk cd ../linknx-0.0.1.27/ ./configure --without-log4cpp --without-lua --with-mysql=/usr/bin/ mysql_config make make install cd /var/www tar -xzf /home/linknx/knxweb-0.6.1.tar.gz vi /etc/network/interfaces # Configuration derière une FREEBOX HD auto eth0 iface eth0 inet static address 192.168.0.17 netmask 255.255.255.0 gateway 192.168.0.254 /etc/init.d/networking restart vi /etc/mysql/my.cnf Remplacer bind-address = 127.0.0.1 par bind-address = [192.168.0.17] sauver, puis redémarrer le serveur mysql /etc/init.d/mysql restart CREATE TABLE `log` ( `ts` timestamp NOT NULL default CURRENT_TIMESTAMP, `object` varchar(256) NOT NULL, `value` varchar(256) NOT NULL, KEY `object` (`object`,`ts`) ) ENGINE=MyISAM DEFAULT CHARSET=utf8; CREATE TABLE `persist` ( `object` varchar(256) NOT NULL, `value` varchar(256) NOT NULL, `ts` timestamp NOT NULL default CURRENT_TIMESTAMP on update CURRENT_TIMESTAMP, PRIMARY KEY (`object`) ) ENGINE=MyISAM DEFAULT CHARSET=utf8; cd /home/linknx/bcusdk-0.0.4/eibd/usb findknxusb eibd -t1023 -i usb:1:3:1:0 linknx -c/var/www/knxweb/linknx.xml KnxConnection: Failed to open knxConnection url. - jef2000 - 25/10/2010 Salut, Ce message se produit lorsque linknx n'arrive pas à se connecter à EIBD. Si eibd et linknx tournent sur la même machine, il te faut la ligne suivante dans la partie "services" du fichier /var/www/knxweb/ linknx.xml: <knxconnection url="ip:127.0.0.1" /> Si ça ne fonctionne toujours pas, il faut chercher du côté d'EIBD. Par exemple essayer les commandes du style: groupswrite ip:127.0.0.1 1/1/5 1 Pour voir si EIBD l'accepte. Jean-François On 25 oct, 20:09, chitloft <arnaud.cogn...@laposte.net> wrote: > bonjour à tous. > voila, ca fait 1 semaine que j'essaie de refaire une VM debian en > suivant le tuto. Mais voila, j'ai une erreur : > 2010-10-25 20:02:39 [ INFO] main: Config file loaded: /var/www/knxweb/ > linknx.xml > 2010-10-25 20:02:39 [ERROR] KnxConnection: Failed to open > knxConnection url. > > Quelqu'un pourrait m'aider ? > Merci > > Arnaud > voici le modop : > cd /home > mkdir linknx > apt-get install gcc > apt-get install g++ make > apt-get install php5 php5-cgi php5-mysql mysql-server phpMyAdmin > apt-get install libpthsem20 > apt-get install bcusdk > apt-get install liblog4cpp5 liblog4cpp5-dev lua5.1 > apt-get install libmysqlclient15-dev > cd linknx > > wgethttp://downloads.sourceforge.net/sourceforge/bcusdk/pthsem_2.0.8.tar.gz > wgethttp://downloads.sourceforge.net/sourceforge/bcusdk/bcusdk_0.0.4.tar.gz > wgethttp://downloads.sourceforge.net/sourceforge/linknx/linknx-0.0.1.27.t... > wgethttp://sourceforge.net/projects/linknx/files/knxweb/knxweb-0.6/knxweb... > > tar -xzf linknx-0.0.1.27.tar.gz > tar -xzf bcusdk_0.0.4.tar.gz > tar -xzvf pthsem_2.0.8.tar.gz > > cd /home/linknx/pthsem-2.0.8/ > ./configure > make > make test > make install > export LD_LIBRARY_PATH=/usr/local/lib > cd ../bcusdk-0.0.4/ > ./configure --enable-onlyeibd --enable-eibnetiptunnel --enable-usb -- > enable-eibnetipserver --enable-ft12 > make > make install > vi /opt/linknx/cle > -----BEGIN PGP PUBLIC KEY BLOCK----- > Version: GnuPG v1.4.6 (GNU/Linux) > > mQGiBEXPVPkRBACwcKSAeUo+rK3ZVRy0cfKVsShbPcB9SlviBaagi5qLqduSKeGU > UX+r2UO+UTaS8Btj8zP+J5cLBtqUah/wVIIz72t8Mxo9Wmdl3EJenFghPaKrHrMp > eUktVgKGdIjo62YSABPtD7ffX8lTJBFoSvXFeoz3BddYIXQZOsOK//PEpwCg2cBQ > AmbNbDix8zB2GBJWhx3MBuUEAJzQ+Yv206A5qPulgC54NrSMlU9ZXYimEtok4cq2 > zxpY4ZiEtXpmcVhXGmVowRrPl9lNP5E2LMAxg5lFkyOkScJxUMkdh/QnJfrmldCH > M+moHDAopK6OPNeNMYpQGOpsG/iIunoLSrrQtYJ17HY4Lk1oT3g9S6Wkd10VGTJP > r/P/A/9OvsfRWz69gm6lOotidFtLhUXovO8DttmfMZWp0MQ1V8lYmh0KdC4rwMGF > QlRQl1Zb1ulDwarGJYhnpC4jSf1IliqlRmcS3Upoo9SbjxXWpEjVbAx71ImA69rG > c7UG7E5jYPOTpARt4PvDY/ZubDwD+B2bWKCiqgSBbjZdV06BUbQxTWFydGluIEtv > ZWdsZXIgKEFQVCkgPG1rb2VnbGVyQGF1dG8udHV3aWVuLmFjLmF0PohgBBMRAgAg > BQJFz1T5AhsDBgsJCAcDAgQVAggDBBYCAwECHgECF4AACgkQfcT/RZkb82GC4QCd > EVYs5uqhWOjYWWT5xIJBTIrj8WIAoLtV4sYwpzxDD7yqXXicHELUNZFZiEYEEBEC > AAYFAkXPWTIACgkQoXeJnTy1y1iZZACdEs/tivUZKNrAAduspDq5FjO2MgIAn0Nz > 85W6JFjMRlzX+Og8elioeAD+uQQNBEXPVXMQEADKTndElLepjtldq/6Rwhi4YlmG > zi1GyswXuqRiTJHvmTA9M7TjRgFPeluafs6hfQYgTMXguM9nPF4cSz5x+G5nDxtL > 4EPy+RhoupTwp0JEJwcnic9sE5UXnIUTYTdAG0C15eQ/DTOqj7VY/DeYA1kEgc+6 > Hj2zSlEyBYOferRNERPju4QVoIUwBnp8XW0kB8DI646WwOx5inutGXeH4tLfEKB/ > JHYMb4QyYKSAxeMVaxsacHvgWYmtZpM0Z6wyE56K9mixtcOijHFMHpkhX73OJfz5 > tq4K8XxpbLU4o1ClbFa3f1cCv/nBCcT6AeykZiW2irXhGwFa33aRk+5Js7vmeWPX > U7ZpU5c7jhVwRUPNQW74FIiw7q1rtloBWJ3L81m4/UEhH4aCz/Ef/+rogVGiHW6K > KVzgggkBsHGtKwcVjgqmBLQdhDjNl7hnM48lJSpcC3NpwWMYgRBlo6STyWdtvHqh > 6I46ULtQLDCzH2l18nsWRVPzLC/bu+shM7ExseRiCMOMe2gxSxW/e/QvTSrmetdZ > YiWVWHUJptLpNFwEs32a8S1+Wn81T7MDHyHugt/hmrHyuyt9NP4/EdZTlxdvEX8x > To6mh6H8Ngvvrq6wRpEtVaKuICwbnh6UGTVj/I31G+QdJzg+gE17GhFd2jqq7Xx5 > RI5DTdUvXNfK1gZ/MwADBQ//ZvpptIYg28NNtxxn7Z0gTBpLN5LHSoM3wlQNWx3M > 1bxaJZQHozqljscydhjFQbHTd5OYSvAQ1wDlwRhTHePJGuhj9BsumCTDTsRMOiyw > MAe5CUqyxygB+Cj7tMvYI9X9JtHrnz94zHbZ3rhXBHtcD8ZhdYEeISkqdJvdY3z7 > V3zIQ9fapUC6MMrMMo6i6eu2zO6gHPHT0hYAWRbAkorNbePnPAXM5VeaoAEHWeKq > wgHclaj86zFj0/K0LJr6m4t9uAZS6xbGjf0DNbDUN5NBB8C6tYnlhsWslr9nQ/6Q > Y5x3plVny9woyntgz79pDpiR8k8Q8AZWGgVybUvX737rWkTa7JpgiD4/DCC/spZf > QoAt/nFv1I53FuQOfp/KNZAWJDE3LBB+4u/N5fWg4Yp5Lwy5seIoeTtNAY4Wwo7b > rdIHbcDW1AZddADOlPn0Xx4PlL8X/+vo68gEWCVX1o9hx3xELkmMTmhIgug/pJgE > XYiCUp3UIs+QU2sKnRLFNBeKHzMqklPh0Ep32NYHGO70mphLk52MQcY5eK6mouta > WV080y14A6hL1kktWF1S7e8LAYVEgfIKpr+C6Lv/KRwWZSCC1X6mdr+60jBqxyBI > jan5mdYrIVQ2eL9RpnVk0HizREdeqE8D/fHv6S2U/ufcUrkVxno9vYmh4LF1Fppp > SJqISQQYEQIACQUCRc9VcwIbDAAKCRB9xP9FmRvzYee6AJ0TiiG8/dM4ppd0dXNT > gIiDW8wHbACeO11PFfwbx51XEx0+kW81XDVxHPg= > =ztcU > -----END PGP PUBLIC KEY BLOCK----- > apt-key add cle > vi /etc/apt/sources.list > debhttp://www.auto.tuwien.ac.at/~mkoegler/debianeib main > deb-srchttp://www.auto.tuwien.ac.at/~mkoegler/debianeib main > apt-get update > apt-get install bcusdk > > cd ../linknx-0.0.1.27/ > ./configure --without-log4cpp --without-lua --with-mysql=/usr/bin/ > mysql_config > make > make install > > cd /var/www > tar -xzf /home/linknx/knxweb-0.6.1.tar.gz > vi /etc/network/interfaces > # Configuration derière une FREEBOX HD > auto eth0 > iface eth0 inet static > address 192.168.0.17 > netmask 255.255.255.0 > gateway 192.168.0.254 > > /etc/init.d/networking restart > > vi /etc/mysql/my.cnf > Remplacer bind-address = 127.0.0.1 par bind-address = > [192.168.0.17] > sauver, > puis redémarrer le serveur mysql > > /etc/init.d/mysql restart > CREATE TABLE `log` ( > `ts` timestamp NOT NULL default CURRENT_TIMESTAMP, > `object` varchar(256) NOT NULL, > `value` varchar(256) NOT NULL, > KEY `object` (`object`,`ts`) > ) ENGINE=MyISAM DEFAULT CHARSET=utf8; > > CREATE TABLE `persist` ( > `object` varchar(256) NOT NULL, > `value` varchar(256) NOT NULL, > `ts` timestamp NOT NULL default CURRENT_TIMESTAMP on update > CURRENT_TIMESTAMP, > PRIMARY KEY (`object`) > ) ENGINE=MyISAM DEFAULT CHARSET=utf8; > > cd /home/linknx/bcusdk-0.0.4/eibd/usb > findknxusb > eibd -t1023 -i usb:1:3:1:0 > linknx -c/var/www/knxweb/linknx.xml KnxConnection: Failed to open knxConnection url. - chitloft - 25/10/2010 salut JF. ecoute, ca fonctionne, j'avais pas la bonne ip, certes. Mais je me demande s'il y a compatibilité avec pthsem_2.0.8. je suis entre temps passé sur la pthsem_2.0.7... c'est à rien comprendre ! Merci en tout cas... je vais pouvoir passer à la suite ![]() sinon, je t'ai envoyé 1 mail il y a qqe temps pour ouvrir un peu plus linknx vers ma russound... on pourrait echanger la dessus ? Merci. Arnaud On 25 oct, 20:30, jef2000 <jef2...@ouaye.net> wrote: > Salut, > > Ce message se produit lorsque linknx n'arrive pas à se connecter à > EIBD. > Si eibd et linknx tournent sur la même machine, il te faut la ligne > suivante dans la partie "services" du fichier /var/www/knxweb/ > linknx.xml: > <knxconnection url="ip:127.0.0.1" /> > > Si ça ne fonctionne toujours pas, il faut chercher du côté d'EIBD. Par > exemple essayer les commandes du style: > groupswrite ip:127.0.0.1 1/1/5 1 > Pour voir si EIBD l'accepte. > > Jean-François > > On 25 oct, 20:09, chitloft <arnaud.cogn...@laposte.net> wrote: > > > bonjour à tous. > > voila, ca fait 1 semaine que j'essaie de refaire une VM debian en > > suivant le tuto. Mais voila, j'ai une erreur : > > 2010-10-25 20:02:39 [ INFO] main: Config file loaded: /var/www/knxweb/ > > linknx.xml > > 2010-10-25 20:02:39 [ERROR] KnxConnection: Failed to open > > knxConnection url. > > > Quelqu'un pourrait m'aider ? > > Merci > > > Arnaud > > voici le modop : > > cd /home > > mkdir linknx > > apt-get install gcc > > apt-get install g++ make > > apt-get install php5 php5-cgi php5-mysql mysql-server phpMyAdmin > > apt-get install libpthsem20 > > apt-get install bcusdk > > apt-get install liblog4cpp5 liblog4cpp5-dev lua5.1 > > apt-get install libmysqlclient15-dev > > cd linknx > > > wgethttp://downloads.sourceforge.net/sourceforge/bcusdk/pthsem_2.0.8.tar.gz > > wgethttp://downloads.sourceforge.net/sourceforge/bcusdk/bcusdk_0.0.4.tar.gz > > wgethttp://downloads.sourceforge.net/sourceforge/linknx/linknx-0.0.1.27.t... > > wgethttp://sourceforge.net/projects/linknx/files/knxweb/knxweb-0.6/knxweb... > > > tar -xzf linknx-0.0.1.27.tar.gz > > tar -xzf bcusdk_0.0.4.tar.gz > > tar -xzvf pthsem_2.0.8.tar.gz > > > cd /home/linknx/pthsem-2.0.8/ > > ./configure > > make > > make test > > make install > > export LD_LIBRARY_PATH=/usr/local/lib > > cd ../bcusdk-0.0.4/ > > ./configure --enable-onlyeibd --enable-eibnetiptunnel --enable-usb -- > > enable-eibnetipserver --enable-ft12 > > make > > make install > > vi /opt/linknx/cle > > -----BEGIN PGP PUBLIC KEY BLOCK----- > > Version: GnuPG v1.4.6 (GNU/Linux) > > > mQGiBEXPVPkRBACwcKSAeUo+rK3ZVRy0cfKVsShbPcB9SlviBaagi5qLqduSKeGU > > UX+r2UO+UTaS8Btj8zP+J5cLBtqUah/wVIIz72t8Mxo9Wmdl3EJenFghPaKrHrMp > > eUktVgKGdIjo62YSABPtD7ffX8lTJBFoSvXFeoz3BddYIXQZOsOK//PEpwCg2cBQ > > AmbNbDix8zB2GBJWhx3MBuUEAJzQ+Yv206A5qPulgC54NrSMlU9ZXYimEtok4cq2 > > zxpY4ZiEtXpmcVhXGmVowRrPl9lNP5E2LMAxg5lFkyOkScJxUMkdh/QnJfrmldCH > > M+moHDAopK6OPNeNMYpQGOpsG/iIunoLSrrQtYJ17HY4Lk1oT3g9S6Wkd10VGTJP > > r/P/A/9OvsfRWz69gm6lOotidFtLhUXovO8DttmfMZWp0MQ1V8lYmh0KdC4rwMGF > > QlRQl1Zb1ulDwarGJYhnpC4jSf1IliqlRmcS3Upoo9SbjxXWpEjVbAx71ImA69rG > > c7UG7E5jYPOTpARt4PvDY/ZubDwD+B2bWKCiqgSBbjZdV06BUbQxTWFydGluIEtv > > ZWdsZXIgKEFQVCkgPG1rb2VnbGVyQGF1dG8udHV3aWVuLmFjLmF0PohgBBMRAgAg > > BQJFz1T5AhsDBgsJCAcDAgQVAggDBBYCAwECHgECF4AACgkQfcT/RZkb82GC4QCd > > EVYs5uqhWOjYWWT5xIJBTIrj8WIAoLtV4sYwpzxDD7yqXXicHELUNZFZiEYEEBEC > > AAYFAkXPWTIACgkQoXeJnTy1y1iZZACdEs/tivUZKNrAAduspDq5FjO2MgIAn0Nz > > 85W6JFjMRlzX+Og8elioeAD+uQQNBEXPVXMQEADKTndElLepjtldq/6Rwhi4YlmG > > zi1GyswXuqRiTJHvmTA9M7TjRgFPeluafs6hfQYgTMXguM9nPF4cSz5x+G5nDxtL > > 4EPy+RhoupTwp0JEJwcnic9sE5UXnIUTYTdAG0C15eQ/DTOqj7VY/DeYA1kEgc+6 > > Hj2zSlEyBYOferRNERPju4QVoIUwBnp8XW0kB8DI646WwOx5inutGXeH4tLfEKB/ > > JHYMb4QyYKSAxeMVaxsacHvgWYmtZpM0Z6wyE56K9mixtcOijHFMHpkhX73OJfz5 > > tq4K8XxpbLU4o1ClbFa3f1cCv/nBCcT6AeykZiW2irXhGwFa33aRk+5Js7vmeWPX > > U7ZpU5c7jhVwRUPNQW74FIiw7q1rtloBWJ3L81m4/UEhH4aCz/Ef/+rogVGiHW6K > > KVzgggkBsHGtKwcVjgqmBLQdhDjNl7hnM48lJSpcC3NpwWMYgRBlo6STyWdtvHqh > > 6I46ULtQLDCzH2l18nsWRVPzLC/bu+shM7ExseRiCMOMe2gxSxW/e/QvTSrmetdZ > > YiWVWHUJptLpNFwEs32a8S1+Wn81T7MDHyHugt/hmrHyuyt9NP4/EdZTlxdvEX8x > > To6mh6H8Ngvvrq6wRpEtVaKuICwbnh6UGTVj/I31G+QdJzg+gE17GhFd2jqq7Xx5 > > RI5DTdUvXNfK1gZ/MwADBQ//ZvpptIYg28NNtxxn7Z0gTBpLN5LHSoM3wlQNWx3M > > 1bxaJZQHozqljscydhjFQbHTd5OYSvAQ1wDlwRhTHePJGuhj9BsumCTDTsRMOiyw > > MAe5CUqyxygB+Cj7tMvYI9X9JtHrnz94zHbZ3rhXBHtcD8ZhdYEeISkqdJvdY3z7 > > V3zIQ9fapUC6MMrMMo6i6eu2zO6gHPHT0hYAWRbAkorNbePnPAXM5VeaoAEHWeKq > > wgHclaj86zFj0/K0LJr6m4t9uAZS6xbGjf0DNbDUN5NBB8C6tYnlhsWslr9nQ/6Q > > Y5x3plVny9woyntgz79pDpiR8k8Q8AZWGgVybUvX737rWkTa7JpgiD4/DCC/spZf > > QoAt/nFv1I53FuQOfp/KNZAWJDE3LBB+4u/N5fWg4Yp5Lwy5seIoeTtNAY4Wwo7b > > rdIHbcDW1AZddADOlPn0Xx4PlL8X/+vo68gEWCVX1o9hx3xELkmMTmhIgug/pJgE > > XYiCUp3UIs+QU2sKnRLFNBeKHzMqklPh0Ep32NYHGO70mphLk52MQcY5eK6mouta > > WV080y14A6hL1kktWF1S7e8LAYVEgfIKpr+C6Lv/KRwWZSCC1X6mdr+60jBqxyBI > > jan5mdYrIVQ2eL9RpnVk0HizREdeqE8D/fHv6S2U/ufcUrkVxno9vYmh4LF1Fppp > > SJqISQQYEQIACQUCRc9VcwIbDAAKCRB9xP9FmRvzYee6AJ0TiiG8/dM4ppd0dXNT > > gIiDW8wHbACeO11PFfwbx51XEx0+kW81XDVxHPg= > > =ztcU > > -----END PGP PUBLIC KEY BLOCK----- > > apt-key add cle > > vi /etc/apt/sources.list > > debhttp://www.auto.tuwien.ac.at/~mkoegler/debianeibmain > > deb-srchttp://www.auto.tuwien.ac.at/~mkoegler/debianeibmain > > apt-get update > > apt-get install bcusdk > > > cd ../linknx-0.0.1.27/ > > ./configure --without-log4cpp --without-lua --with-mysql=/usr/bin/ > > mysql_config > > make > > make install > > > cd /var/www > > tar -xzf /home/linknx/knxweb-0.6.1.tar.gz > > vi /etc/network/interfaces > > # Configuration derière une FREEBOX HD > > auto eth0 > > iface eth0 inet static > > address 192.168.0.17 > > netmask 255.255.255.0 > > gateway 192.168.0.254 > > > /etc/init.d/networking restart > > > vi /etc/mysql/my.cnf > > Remplacer bind-address = 127.0.0.1 par bind-address = > > [192.168.0.17] > > sauver, > > puis redémarrer le serveur mysql > > > /etc/init.d/mysql restart > > CREATE TABLE `log` ( > > `ts` timestamp NOT NULL default CURRENT_TIMESTAMP, > > `object` varchar(256) NOT NULL, > > `value` varchar(256) NOT NULL, > > KEY `object` (`object`,`ts`) > > ) ENGINE=MyISAM DEFAULT CHARSET=utf8; > > > CREATE TABLE `persist` ( > > `object` varchar(256) NOT NULL, > > `value` varchar(256) NOT NULL, > > `ts` timestamp NOT NULL default CURRENT_TIMESTAMP on update > > CURRENT_TIMESTAMP, > > PRIMARY KEY (`object`) > > ) ENGINE=MyISAM DEFAULT CHARSET=utf8; > > > cd /home/linknx/bcusdk-0.0.4/eibd/usb > > findknxusb > > eibd -t1023 -i usb:1:3:1:0 > > linknx -c/var/www/knxweb/linknx.xml |
