KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Archives eib-domotique (https://www.knx-fr.com/forumdisplay.php?fid=8) +--- Sujet : KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) (/showthread.php?tid=922) |
KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - chitloft - 09/03/2011 http://www.knx.org/knx-tools/falcon/description/ The Falcon Driver Library is the high performance DCOM based library for Windows from KNX. DCOM (Microsoft Distributed Component Object Model) allows the use of Falcon across the LAN. Falcon offers an API (Application Program Interface) for sending and receiving telegrams across the KNX network. Supported are the access through RS 232, USB and Internet. Especially programmers are exceptionally well served with the Falcon Driver Library. It lays the tracks for the access to KNX. Aside from the comfortable API, it offers access management for bus devices, for telegrams (group address), physical addresses, device states and much more. The bus access allows the programing of languages like Visual C+ +, Delphi, Visual Basic and others. Falcon is used as network connection library for ETS 3 and EITT. Since version 1.23 Falcon offers the IConectionManager, a simple and esay-to-use user interface for the integrator to make and configure the conection between KNX and other media. For technical information, please download the pdf file. Available in English. Mais le lien vers le PDF ne fonctionne pas ![]() Arnaud KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - Anthony PENHARD - 09/03/2011 le lien en français http://www.knx.org/fr/knx-tools/falcon/description/ le pdf fonctionne mais ne donne rien de plus ... @+ Anthony. > http://www.knx.org/knx-tools/falcon/description/ > > The Falcon Driver Library is the high performance DCOM based library > for Windows from KNX. DCOM (Microsoft Distributed Component Object > Model) allows the use of Falcon across the LAN. Falcon offers an API > (Application Program Interface) for sending and receiving telegrams > across the KNX network. Supported are the access through RS 232, USB > and Internet. > > Especially programmers are exceptionally well served with the Falcon > Driver Library. It lays the tracks for the access to KNX. Aside from > the comfortable API, it offers access management for bus devices, for > telegrams (group address), physical addresses, device states and much > more. The bus access allows the programing of languages like Visual C+ > +, Delphi, Visual Basic and others. Falcon is used as network > connection library for ETS 3 and EITT. Since version 1.23 Falcon > offers the IConectionManager, a simple and esay-to-use user interface > for the integrator to make and configure the conection between KNX and > other media. > > > For technical information, please download the pdf file. Available in > English. > > Mais le lien vers le PDF ne fonctionne pas ![]() > > Arnaud KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - kraven - 14/03/2011 Une idée du prix de la librairie pour une utilisation personnelle? A+ On 9 mar, 12:22, "Anthony PENHARD" <a.penh...@gmail.com> wrote: > le lien en fran aishttp://www.knx.org/fr/knx-tools/falcon/description/ > > le pdf fonctionne mais ne donne rien de plus ... > > @+ > Anthony. > > > > > > > > >http://www.knx.org/knx-tools/falcon/description/ > > > The Falcon Driver Library is the high performance DCOM based library > > for Windows from KNX. DCOM (Microsoft Distributed Component Object > > Model) allows the use of Falcon across the LAN. Falcon offers an API > > (Application Program Interface) for sending and receiving telegrams > > across the KNX network. Supported are the access through RS 232, USB > > and Internet. > > > Especially programmers are exceptionally well served with the Falcon > > Driver Library. It lays the tracks for the access to KNX. Aside from > > the comfortable API, it offers access management for bus devices, for > > telegrams (group address), physical addresses, device states and much > > more. The bus access allows the programing of languages like Visual C+ > > +, Delphi, Visual Basic and others. Falcon is used as network > > connection library for ETS 3 and EITT. Since version 1.23 Falcon > > offers the IConectionManager, a simple and esay-to-use user interface > > for the integrator to make and configure the conection between KNX and > > other media. > > > For technical information, please download the pdf file. Available in > > English. > > > Mais le lien vers le PDF ne fonctionne pas ![]() > > > Arnaud KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - kraven - 16/03/2011 > Une idée du prix de la librairie pour une utilisation personnelle? > > A+ Je me répond. C'est apparemment gratuit ![]() La disponibilité du nouvel ETS4 le 20.10.2010 a été le début d'une nouvelle ère pour KNX en terme de convivialité et d'interfaces ouvertes. ETS4 est ouvert! Ceci se reflète dans le nouveau format d'échange de données basé sur XML et utilisé par ETS4 pendant l'exportation/importation. KNX Association va pousser l'utilisation de KNX encore plus loin en tant que Standard Européen pour le Contrôle de la Maison et du Bâtiment. Pour cette raison, l'interface d'accès au bus Falcon 2.0, ne sera plus sujette à des frais de licence.. KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - Charles Delorme - 16/03/2011 Le 16/03/2011 11:26, kraven a écrit : >> Une idée du prix de la librairie pour une utilisation personnelle? >> >> A+ > > Je me répond. C'est apparemment gratuit ![]() > > La disponibilité du nouvel ETS4 le 20.10.2010 a été le début d'une > nouvelle ère pour KNX en terme de convivialité et d'interfaces > ouvertes. ETS4 est ouvert! Ceci se reflète dans le nouveau format > d'échange de données basé sur XML et utilisé par ETS4 pendant > l'exportation/importation. KNX Association va pousser l'utilisation de > KNX encore plus loin en tant que Standard Européen pour le Contrôle de > la Maison et du Bâtiment. > > Pour cette raison, l'interface d'accès au bus Falcon 2.0, ne sera plus > sujette à des frais de licence.. Ce qui pourrait ouvrir la porte à d'autres outils qu'ETS ? |
