FALCON - Version imprimable +- Forum KNX francophone / English KNX forum (https://www.knx-fr.com) +-- Forum : Français (https://www.knx-fr.com/forumdisplay.php?fid=3) +--- Forum : Archives eib-domotique (https://www.knx-fr.com/forumdisplay.php?fid=8) +--- Sujet : FALCON (/showthread.php?tid=98) |
FALCON - kervy - 20/10/2008 Bonjour, ect ce quelqu'un peut m'explique a quoi sert E FALCON, comme on l'utilise . Il paraitrai qu'un licence gratuite serait sorti. ++ FALCON - Steven - 21/10/2008 Falcon is a COM-component for accessing the KNX installation from a PC. "Falcon offers an API (Application Program Interface) for sending and receiving telegrams across the KNX network." In the 80's, we would have called it a driver, but it is much more than only a driver for supporting the KNX frame exchange on RS232 or USB... You can have a look at : http://www.knx.org/knx-tools/falcon/description/ If you do not license it, it works for 5 min. On 20 okt, 14:47, kervy <kervyw...@hotmail.com> wrote: > Bonjour, > > ect ce quelqu'un peut m'explique a quoi sert E FALCON, comme on > l'utilise . > > Il paraitrai qu'un licence gratuite serait sorti. > > ++ FALCON - Alexandre Tichit - 21/10/2008 Bonjour, Je croyais à tort il me semble maintenant, que Falcon permettait de faire du reverse ingéniering sur des installations EIB/KNX afin de retrouver une config lorsque qu'un ancien installateur n'a pas laissé au client le .prX Si ce n'est point Falcon qui permet cela, existe t'il un soft à cet usage ? Merci Alexandre 2008/10/21 Steven <steven.debruyne@konnex.org> > > Falcon is a COM-component for accessing the KNX installation from a > PC. > "Falcon offers an API (Application Program Interface) for sending and > receiving telegrams across the KNX network." > In the 80's, we would have called it a driver, but it is much more > than only a driver for supporting the KNX frame exchange on RS232 or > USB... > > You can have a look at : http://www.knx.org/knx-tools/falcon/description/ > > If you do not license it, it works for 5 min. > > On 20 okt, 14:47, kervy <kervyw...@hotmail.com> wrote: > > Bonjour, > > > > ect ce quelqu'un peut m'explique a quoi sert E FALCON, comme on > > l'utilise . > > > > Il paraitrai qu'un licence gratuite serait sorti. > > > > ++ > FALCON - Marc Assin - 21/10/2008 On 21 oct, 16:35, "Alexandre Tichit" <tical1...@gmail.com> wrote: > Si ce n'est point Falcon qui permet cela, existe t'il un soft à cet usage ? Schlaps & Partner http://www.bb-steuerungstechnik.de/english/index.html FALCON - Alexandre Tichit - 21/10/2008 Merci Marc....Une encyclopédie à vous seul :o) 2008/10/21 Marc Assin <raymond@warichet.com> > > On 21 oct, 16:35, "Alexandre Tichit" <tical1...@gmail.com> wrote: > > Si ce n'est point Falcon qui permet cela, existe t'il un soft à cet usage > ? > > Schlaps & Partner > http://www.bb-steuerungstechnik.de/english/index.html FALCON - mickg - 21/10/2008 Une autre solution chez le développeur d'ETS, c'est "reconstruction" chez IT http://www.it-gmbh.de/en/products/ittools.htm C'est un plugin pour ETS Même la version démo est pratique si on "bricole" bien... Nota : la license "Reconstruction" est plus chère que celle d'ETS On 21 oct, 19:36, "Alexandre Tichit" <tical1...@gmail.com> wrote: > Merci Marc....Une encyclopédie à vous seul :o) > > 2008/10/21 Marc Assin <raym...@warichet.com> > > > > > On 21 oct, 16:35, "Alexandre Tichit" <tical1...@gmail.com> wrote: > > > Si ce n'est point Falcon qui permet cela, existe t'il un soft à cet usage > > ? > > > Schlaps & Partner > >http://www.bb-steuerungstechnik.de/english/index.html > > -- > Cordialement. > > Tichit Alexandre > > CIDEL FRANCE SA > > 13, rue Rosenwald > 75015 Paris > > 33 1 45 30 09 60 Tél > 33 1 42 50 87 07 Fax > 33 6 61 63 62 55 Mob > 216 98 42 65 12 Tunisie > 216 71 77 70 09 Tunisie > > Skype ID : tical1969 > > Pensez ENVIRONNEMENT : n'imprimez que si nécessaire. > Please consider the environmental impact before printing this e-mail. FALCON - mickg - 21/10/2008 Cette solution vient du développeur d'ETS, c'est "reconstruction" chez IT http://www.it-gmbh.de/en/products/ittools.htm C'est un plugin pour ETS Même la version démo est pratique si on "bricole" bien... Nota : la license "Reconstruction" est plus chère que celle d'ETS On 21 oct, 19:36, "Alexandre Tichit" <tical1...@gmail.com> wrote: > Merci Marc....Une encyclopédie à vous seul :o) > > 2008/10/21 Marc Assin <raym...@warichet.com> > > > > > On 21 oct, 16:35, "Alexandre Tichit" <tical1...@gmail.com> wrote: > > > Si ce n'est point Falcon qui permet cela, existe t'il un soft à cet usage > > ? > > > Schlaps & Partner > >http://www.bb-steuerungstechnik.de/english/index.html > > -- > Cordialement. > > Tichit Alexandre > > CIDEL FRANCE SA > > 13, rue Rosenwald > 75015 Paris > > 33 1 45 30 09 60 Tél > 33 1 42 50 87 07 Fax > 33 6 61 63 62 55 Mob > 216 98 42 65 12 Tunisie > 216 71 77 70 09 Tunisie > > Skype ID : tical1969 > > Pensez ENVIRONNEMENT : n'imprimez que si nécessaire. > Please consider the environmental impact before printing this e-mail. FALCON - mickg - 21/10/2008 Cette solution vient du développeur d'ETS, c'est "reconstruction" chez IT http://www.it-gmbh.de/en/products/ittools.htm C'est un plugin pour ETS Même la version démo est pratique si on "bricole" bien... On 21 oct, 19:36, "Alexandre Tichit" <tical1...@gmail.com> wrote: > Merci Marc....Une encyclopédie à vous seul :o) > > 2008/10/21 Marc Assin <raym...@warichet.com> > > > > > On 21 oct, 16:35, "Alexandre Tichit" <tical1...@gmail.com> wrote: > > > Si ce n'est point Falcon qui permet cela, existe t'il un soft à cet usage > > ? > > > Schlaps & Partner > >http://www.bb-steuerungstechnik.de/english/index.html > > -- > Cordialement. > > Tichit Alexandre > > CIDEL FRANCE SA > > 13, rue Rosenwald > 75015 Paris > > 33 1 45 30 09 60 Tél > 33 1 42 50 87 07 Fax > 33 6 61 63 62 55 Mob > 216 98 42 65 12 Tunisie > 216 71 77 70 09 Tunisie > > Skype ID : tical1969 > > Pensez ENVIRONNEMENT : n'imprimez que si nécessaire. > Please consider the environmental impact before printing this e-mail. |
