19/01/2008, 10:24:28
Hi Goahead,
Yes it is possible to call different group adresses in using the
'scenes'.
But you need devices that have 'scene function' (example actuator ref
1046-00 by Gira) or buy a special device that performs the scene
function (example 5WG1 300-1AB01 by siemens).
Some push-button have also the scene function inside (triton by bush-
jaeger for example).
The way to proceed depends on the devices.
Hereafter the way if you have an actuator with scene functions...
Your push-button get for example the group adress 1/1/1. You give the
function 'light scene' to this button and have to specify a lightscene
number (for example, 5).
In the actuator, you have to enable the light scene function for the
outputs you want to actuate.
For each one of them, you give the lightscene number 5 and the
switching state you want.
ex
output 1.....lightscene 5.....switchinh on
output 2.....lightscene 5.....switching on
output 3.....no scene
output 4.....ligthscene 5.....switching off
and so on...
so here, when you push the button, output 1 and 2 will go on, output 4
will go off and output 3 doesn't react.
I hope it is clear enough. (for my 1st answer in the group)
Regards
Philippe
On 18 jan, 20:29, Goahead <carlos-m-mon...@ptinovacao.pt> wrote:
> Hi Group
> Once again..sorry for not write in French.
> Is it possible to press one button and call to diferent adresses?..
> Press simple button and send "ON" to adress 0.0.1 and "Off" adress
> 0.0.3? (only one click)
> Example:
> I want to press one button, and it will shut down (off) 22 lights in
> the house (doesnt matter if they where off or ON) and at the same
> time, the command also send ON to 3 diferent lights (doesnt matter if
> they are on already...on must be sent).
> if possible, please sugest how can i do that in a simple way.
> best regards
> Goahead
> GOOGLE TRANSLATION
> Salut Groupe
> Une fois de plus .. désolé de ne pas écrire en français.
> Est-il possible de faire pression sur un bouton et appel à différentes
> adresses? ..
> Appuyez sur le bouton et d'envoyer des simples <<ON>> à l'adresse 0.0.1
> et <<Off>>, l'adresse 0.0.3? (Un seul clic)
> Exemple:
> Je veux appuyer sur un bouton, et il va fermer (off) 22 lumières dans
> la maison (pas question s'ils où décollage ou ON), et en même temps,
> envoyer la commande à 3 SUR différentes lumières (pas d'importance si
> elles Sont déjà sur ... ON doit être envoyé).
> Si possible, sugest s'il vous plaît comment puis-je faire cela d'une
> manière simple.
> Best regards
> Goahead
'scenes'.
ex
and so on...
Regards
Philippe
> Hi Group
> Example:
> best regards
> Goahead
> GOOGLE TRANSLATION
> Salut Groupe
> adresses? ..
> Exemple:
> manière simple.
> Best regards
> Goahead
