pushme ou Prowl sous linknx
regarde la doc lua ici
http://www.lua.org/manual/5.1/manual.html#pdf-io.open
peut-être utiliser io.open en non io.popen
et inverser les ' et "
résultat :
io.open('curl -d "message=PC_Status_POMPE OFF&signature=Maison"
http://pushme.to/arnaud/');
cela va peut-être mieux marcher ...
Anthony.
> Merci Anthony encore 1 fois,
> j'ai implémenté tout ca, au + simple, sur 1 PC.
> voici la regle
> <rule id="push">
> <!--condition type="or">
> <condition type="object" id="PC_Status_POMPE" value="off"
> trigger="true"/-->
> <condition type="object" id="PC_Status_Bureau" value="off"
> trigger="true"/>
> <!--/condition-->
> <actionlist>
> <action type="script">
> io.popen("curl -d 'message=PC_Status_POMPE
> OFF&signature=Maison' http://pushme.to/arnaud/");
> </action>
> </actionlist>
> </rule>
> et voici la trace.
> Send request
> 2011-02-28 23:55:19 [ INFO] Object: New value on for object PC_BUREAU
> (type: 1.001)
> 2011-02-28 23:55:19 [ INFO] FilePersistentStorage: Writing 'on' for
> object 'PC_BUREAU'
> 2011-02-28 23:55:19 [ INFO] FilePersistentStorage: Writing log'on' for
> object 'PC_BUREAU'
> Write from 0.0.0 to 2/1/3: 01
> Write from 1.1.4 to 2/6/3: 01
> PC_Status_Bureau (type: 1.001)
> 2011-02-28 23:55:19 [ INFO] SwitchingObject: SwitchingObject
> (id=PC_Status_Bureau): Compare value_m='1' to value='0'
> 2011-02-28 23:55:19 [ INFO] Condition: ObjectCondition
> (id='PC_Status_Bureau') evaluated as '0'
> 2011-02-28 23:55:20 [ INFO] KnxConnection: write(gad=9215, buf,
> len=2):
> Send request
> Read from 0.0.0 to 4/3/255
> 2011-02-28 23:55:20 [ INFO] KnxConnection: write(gad=4355, buf,
> len=2):
> Send request
> 2011-02-28 23:55:20 [ INFO] Object: New value off for object PC_BUREAU
> (type: 1.001)
> 2011-02-28 23:55:20 [ INFO] FilePersistentStorage: Writing 'off' for
> object 'PC_BUREAU'
> 2011-02-28 23:55:20 [ INFO] FilePersistentStorage: Writing log'off'
> for object 'PC_BUREAU'
> Write from 0.0.0 to 2/1/3: 00
> Write from 1.1.4 to 2/6/3: 00
> 2011-02-28 23:55:20 [ INFO] SwitchingObject: SwitchingObject
> (id=PC_Status_Bureau): Compare value_m='0' to value='0'
> 2011-02-28 23:55:20 [ INFO] Condition: ObjectCondition
> (id='PC_Status_Bureau') evaluated as '1'
> 2011-02-28 23:55:20 [ INFO] Action: Execute LuaScriptAction
> % Total % Received % Xferd Average Speed Time Time
> Time Current
> Dload Upload Total Spent
> Left Speed
> 0 43 0 0 0 43 0 192 --:--:-- --:--:--
> --:--:-- 1922011-02-28 23:55:21 [ INFO] KnxConnection:
> write(gad=2560, buf, len=2):
> Send request
> Read from 0.0.0 to 1/2/0
> 100 4012 0 3969 0 43 7328 79 --:--:-- --:--:--
> --:--:-- 12345
> 2011-02-28 23:55:22 [ INFO] KnxConnection: write(gad=2561, buf,
> len=2):
> Send request
> A noter que curl -d 'message=PC_Status_POMPE OFF&signature=Maison'
> http://pushme.to/arnaud/ en ligne de commande fonctionne super bien...
> j'ai essayé en virant les " etc, mais non, ca ne sort rien. des
> idées ?
> Arnaud
> On 28 fév, 20:40, Anthony PENHARD <a.penh...@gmail.com> wrote:
>> Salut,
>> ça doit être possible avec un script lua dans un rule
>> un truc du genre : (pas testé)
>> <rule id="push">
>>   <condition type="and">
>>     <condition type="object" id="Arnaud_dors" value="on"
>> trigger="true"/>
>>     <condition type="or">
>>        <condition type="object" id="porte_grarage" value="on"
>> trigger="true"/>
>>        <condition type="object" id="lumiere_salon" value="on"
>> trigger="true"/>
>>     </condition>
>>   </condition>
>>   <actionlist>
>>         io.popen("curl -d "message=Votre
>> message&signature=Maison"http://pushme.to/YOUR_ID_PUSHME/");
>>     </action>
>>   </actionlist>
>> </rule>
>> Anthony.
>> Le 28 février 2011 19:01, chitloft <arnaud.cogn...@laposte.net> a écrit
>> > bjr a tous,
>> > q1 aurait il intégré cette fonction de push dans linknx ? j''aimerai
>> > etre orienté pour démarrer sur le choix du socle technique.
>> > L'idée est d'envoyer 1 notification vers l'iphone sur des alertes
>> > éventuelles, basées sur 1 logique. Ex : si je dors et que la porte du
>> > garage, push sur l'iphone (ouais, il dort avec moi) ou si porte
>> > ouverte durant mon abscence et alarme activée, etc.
>> > j'ai trouvé des solutions, notamment ici (http://www.poulpy.com/tag/
>> > domotique/) en xPL...
>> > J'attends vos opinions sur la manière d'aborder le bazard dans
>> > linknx .
>> > Merci a vous.
>> > Arnaud
pushme ou Prowl sous linknx - par chitloft - 28/02/2011, 19:01:27
pushme ou Prowl sous linknx - par Anthony PENHARD - 28/02/2011, 20:40:35
pushme ou Prowl sous linknx - par chitloft - 28/02/2011, 23:58:18
pushme ou Prowl sous linknx - par Anthony PENHARD - 01/03/2011, 10:05:56
pushme ou Prowl sous linknx - par Arnaud Cognard - 01/03/2011, 13:02:34
