Projet KNX, programmation c#
Peut-être utile : voici une capture sur mon pc. Je l'ai renommée en .txt mais c'est bien un .cap de tcpdump - ou wireshark.
Cela correspond aux évènements suivants dans linknx :
[ INFO] Action: SetValueAction: Configured for object P2L6 with value on
[ INFO] Action: Execute SetValueAction: set P2L6 with value on
[ INFO] KnxConnection: write(gad=1/1/3, buf, len=2)
[ INFO] Object: New value on for object P2L6 (type: 1.001)
[ INFO] Action: SetValueAction: Configured for object P2L6 with value off
[ INFO] Action: Execute SetValueAction: set P2L6 with value off
[ INFO] Object: New value off for object P2L6 (type: 1.001)
[ INFO] Object: New value 20.6 for object TempJu (type: 9.xxx)
[ INFO] MysqlPersistentStorage: Writing log '20.6' for object 'TempJu'
[ INFO] Object: New value 20.3 for object TempVmcVicie (type: 9.xxx)
[ INFO] MysqlPersistentStorage: Writing log '20.3' for object 'TempVmcVicie'
[ INFO] Object: New value 14.1 for object TempVmcNeuf (type: 9.xxx)
[ INFO] MysqlPersistentStorage: Writing log '14.1' for object 'TempVmcNeuf'
Les objets dans mon linknx.xml de test :
<objects>
<object type="1.001" id="P2L6" gad="1/1/3" init="request">Palier Biblio</object>
<object type="1.001" id="Pluie" gad="0/1/2" init="request" log="true">Pluie</object>
<object type="9.xxx" id="TempCy" gad="3/0/2" init="request" log="true">Temperature Cyril</object>
<object type="9.xxx" id="TempJu" gad="3/0/3" init="request" log="true">Temperature Julien</object>
<object type="9.xxx" id="TempSa" gad="3/0/4" init="request" log="true">Temperature Salon</object>
<object type="9.xxx" id="TempVmcInsuflation" gad="3/0/6" init="request" log="true">Temperature VMC Insuflation</object>
<object type="9.xxx" id="TempVmcNeuf" gad="3/0/5" init="request" log="true">Temperature VMC Neuf</object>
<object type="9.xxx" id="TempVmcRejet" gad="3/0/8" init="request" log="true">Temperature VMC Rejet</object>
<object type="9.xxx" id="TempVmcVicie" gad="3/0/7" init="request" log="true">Temperature VMC Vicie</object>
<object type="9.xxx" id="TempYo" gad="3/0/1" init="request" log="true">Temperature Yoann</object>
<object type="1.001" id="VoletTest" gad="2/4/1" init="request">TV stop</object>
<object type="1.001" id="VoletTestBougre" gad="2/4/2" init="request">TV Bouge</object>
<object type="5.xxx" id="VoletTestPosition" gad="2/4/4" init="request">TV position</object>
<object type="11.001" id="cur_date" gad="0/0/1" init="now" flags="cwtus">Current Date</object>
<object type="10.001" id="cur_time" gad="0/0/2" init="now">Current Time</object>
<object type="1.001" id="test_on_off" gad="1/1/2" init="request" log="true">NoL1</object>
</objects>
Pièces jointes
.txt   linknx.cap.txt (Taille : 4,05 Ko / Téléchargements : 8)
Projet KNX, programmation c# - par Jonathan02 - 12/11/2012, 23:55:49
RE: Projet KNX, programmation c# - par Oo stephan oO - 22/03/2013, 22:15:15
RE: Projet KNX, programmation c# - par Suricat - 23/03/2013, 11:27:54
