Alarme KNX
#28
Pluscom est plus que réactif et a priori de bon conseil. Voici leur réponse:
<<Hi,
I checked your cart and ETHM-2 module can work with Integra but better choice is ETHM-1 Plus.
If you would like to connect every reed contractor separately you should have 30 inputs + 4 for TSD-1 + 2 for tamper switches (enclosure and siren).
Tamper switches you can connect to any expander but in case of violation you'll get log e.g. sabotage of expander line.
Sometimes it is better to connect it to zone.
Integra 128 Plus + 2 INT-E expanders have 32 zones in total.
You need one INT-E expander more or you can connect some reed contractors together (in serial).
You can use simple Satel's GSM module, GPRS-T1 that emulate standard telephone line, or GPRS-T2 or GPRS-T4 that should be connected to control panel's outputs.
Those 2 last modules allow to control system by SMS or CLIP (as much functions as number of outputs on module and it require additional zones on control panel).
You can also choose Integra 128-WRL instead od 128 Plus that have GSM module onboard.
You should know that if you buy a control panel in our store you can use it in English language only (possibility of firmware change is blocked).
If you have any further queries please do not hesitiate in contacting me.
Best regards
Marcin>>
Ceds_BE, est ce que tu confirmes que tous les soft sont en anglais?
Si oui, est-ce facilement compréhensible/paramètrable?
Alarme KNX - par PITP2 - 13/07/2015, 21:52:37
RE: Alarme KNX - par Ceds_BE - 14/07/2015, 08:28:49
RE: Alarme KNX - par steweid - 30/08/2015, 12:09:58
RE: Alarme KNX - par rcmrco - 19/05/2016, 22:55:35
RE: Alarme KNX - par Ceds_BE - 06/06/2016, 06:53:31
RE: Alarme KNX - par PITP2 - 14/07/2015, 08:33:50
RE: Alarme KNX - par Ceds_BE - 14/07/2015, 09:18:07
RE: Alarme KNX - par steweid - 14/03/2016, 19:46:27
RE: Alarme KNX - par bernard007 - 31/07/2016, 22:08:35
RE: Alarme KNX - par PITP2 - 14/07/2015, 09:23:59
RE: Alarme KNX - par Ceds_BE - 14/07/2015, 09:38:18
RE: Alarme KNX - par PITP2 - 14/07/2015, 09:52:37
RE: Alarme KNX - par Ceds_BE - 14/07/2015, 10:08:37
RE: Alarme KNX - par PITP2 - 14/07/2015, 10:25:57
RE: Alarme KNX - par Ceds_BE - 14/07/2015, 12:40:01
RE: Alarme KNX - par PITP2 - 14/07/2015, 13:11:35
RE: Alarme KNX - par Faelwee - 15/07/2015, 09:58:46
RE: Alarme KNX - par PITP2 - 15/07/2015, 12:29:06
RE: Alarme KNX - par HDsolution - 31/08/2015, 09:35:03
RE: Alarme KNX - par Ceds_BE - 01/09/2015, 13:32:12
RE: Alarme KNX - par steweid - 03/09/2015, 13:36:50
RE: Alarme KNX - par steweid - 01/09/2015, 20:22:45
RE: Alarme KNX - par Ceds_BE - 01/09/2015, 21:58:41
RE: Alarme KNX - par steweid - 03/09/2015, 09:42:17
RE: Alarme KNX - par PITP2 - 03/09/2015, 09:47:58
RE: Alarme KNX - par steweid - 03/09/2015, 10:17:29
RE: Alarme KNX - par PITP2 - 03/09/2015, 12:08:59
RE: Alarme KNX - par steweid - 03/09/2015, 12:34:23
RE: Alarme KNX - par Ceds_BE - 03/09/2015, 12:46:38
RE: Alarme KNX - par Ceds_BE - 03/09/2015, 14:50:56
RE: Alarme KNX - par steweid - 03/09/2015, 14:58:39
RE: Alarme KNX - par steweid - 04/09/2015, 08:52:30
RE: Alarme KNX - par Ceds_BE - 04/09/2015, 10:37:04
RE: Alarme KNX - par abnaxus - 19/01/2020, 19:06:34
RE: Alarme KNX - par steweid - 04/09/2015, 12:38:06
RE: Alarme KNX - par lemano - 29/11/2015, 14:43:51
RE: Alarme KNX - par steweid - 13/03/2016, 14:21:35
RE: Alarme KNX - par lemano - 14/03/2016, 10:09:34
RE: Alarme KNX - par celmas - 13/04/2016, 19:59:11
RE: Alarme KNX - par PITP2 - 14/04/2016, 13:33:33
RE: Alarme KNX - par celmas - 14/04/2016, 17:10:29
RE: Alarme KNX - par Ceds_BE - 18/04/2016, 11:14:39
RE: Alarme KNX - par Ryuma - 24/05/2016, 14:41:52
RE: Alarme KNX - par moustic999 - 25/05/2016, 08:46:40
RE: Alarme KNX - par Ryuma - 25/05/2016, 08:59:09
RE: Alarme KNX - par moustic999 - 27/05/2016, 07:25:19
RE: Alarme KNX - par mil3d - 25/05/2016, 10:57:08
RE: Alarme KNX - par Du21 - 25/05/2016, 18:30:59
RE: Alarme KNX - par Ryuma - 26/05/2016, 07:48:15
RE: Alarme KNX - par Ryuma - 25/05/2016, 11:03:01
RE: Alarme KNX - par mil3d - 25/05/2016, 11:05:27
RE: Alarme KNX - par Ceds_BE - 16/08/2016, 10:35:49
RE: Alarme KNX - par vano - 09/02/2017, 23:22:10
RE: Alarme KNX - par ultraxa - 10/02/2017, 22:51:05
RE: Alarme KNX - par thenikoos - 15/11/2017, 12:15:05
