KNX Kit - Problem in Detecting KNX interface
#15
computer --> crossover cable --> knx router
I installed dhcp server on the ethernet interface. And I made connections in earlier time through cisco router 2611xm with no good .. i made port forwarding setting. I do have an old hub and a cisco mediator that I ve never used.
One observation is that ETS reads device info, unload configuration, sometimes monitor bus shows activity.
Anyhow, I will try the old hub. I will try also the mediator. Slow connection information is totally new for me thanks for that and thanks for all.
I believe knx in need for thorough learning resources in English.
Regards
I also tried a switch but i believe it's new i.e. gigabit ethernet with no good!
RE: KNX Kit - Problem in Detecting KNX interface - par labkhan - 13/01/2016, 08:38:36
