Domovéa 3.6
petite news en passant pour indiquer que depuis hier la version 3.6 de Domovéa est disponible. C'est quand même casse bonbons qu'ils n'aient pas de liste de diffusion pour l'apprendre.
Pas une grande révolution en soit mais pas mal de petites choses en plus et de corrections.
Voila la release note :
V3.6.0.0
New fonctions
• The TXA100 import function has been improved and is now able to compare the TXA100 installation file with the domovea project file and to proceed to an incremental import
• The doorphone feature (ELCOM Modesta) can now be used on our Windows touch panels (WDI101 & WDI161)
Bug fix
• General
o Improvements on the software update process
o Improvements on the sequence and energy measure engines (the sequences and energy measures were stopped)
o The system detects that the OS is Windows 10
o Improvements on the clock sending feature to the KNX bus
• PC client
o Improvements on TXA100 import process
o Harmonization on measure feature (scales, axis, units, rouding, trend)
o Adding of sequences actions for the ventilation device
o Improvements on the energy widget (automatic refresh on the dashboard)
o Improvements on the camera widget (automatic refresh when deleting a camera)
o Improvement with automatic sorting
• Configuration tool
o Improvements on the doorphone device
o Improvements on the profile feature
o Exception on copy attempt on a device category
o Improvements on energy measure export feature
o Improvements on the RGB device (multiple orders sending)
o Improvements on ‘bus trigger’ sequence feature
• Web configuration tool
o Improvements on the alarm device
o Improvements on the thermostat device (with + and – buttons for temperature setpoint)
o Improvements on the week templates and calendar features (when trying to modify the calendar)
• Touch panel
o Harmonization of the doorphone feature
o Improvements of the camera stream on dashboard when staying more than 10 minutes on the dashboard
o Improvements on camera archive (crash when using filters)
o Improvements on KNX scene device (the record feature can now be hidden)
o Improvements on the thermostat device (switch between current temperature and temperature setpoint)
Je vais tester ça sur mon Domovéa de test ce week-end je pense. je ferai des retours au besoin
Domovéa 3.6 - par Joffrey - 05/04/2016, 10:39:34
RE: Domovéa 3.6 - par NicNac - 18/12/2017, 17:59:30
RE: Domovéa 3.6 - par lales67 - 18/12/2017, 20:17:36
