27/03/2017, 12:47:45
(06/11/2016, 12:47:20)regnak2016 a écrit : Well, I finally got it working - rookie error when setting up the Project I selected IP instead of TP. Common problem I was told! Thanks for all the suggestions.
Hello,
I'm also building a workbench and would like to use the EIB markt Ip interface N000401 to connect to the bus through LAN.
Can you please tell me all the steps you needed to get it to work?
I have more or less the same problems.
I can add the device in ETS5, I can add the interface and see that it gets an IP address from DHCP. But then I think I need to set up the bus address, since I cannot see any of the devices from the bus, and I'm also receiveing a message about exceding the total amount ou available connections.
Any help is appreciated.
Regards,
