28/11/2008, 23:22:15
Bonsoir,
Elsner a de très bons produits, avec un finissage eléctronique super.
KNX T-UP - Thermometer for indoor applications. With 4 limit values
and logic gates
(AND and OR). Output of a mixed value from own and external value. PI
controller for heating/cooling. Configuration with ETS software. With
dis-
play. ---------------- 149€
KNX TH-UP Thermo-Hygrometer for KNX/EIB
Indoor sensor for temperature and humidity (relative and absolute).
Calcu-
lation of dewpoint. With 7 limit values and logic gates (AND and OR).
Out-
put of a mixed value from own and external value. PI controller for
hea-
ting/cooling (temperature) and ventilation (humidity) --------------
189€
KNX T-Objekt-UP Temperature Sensor for KNX/EIB
Sensor for indoor temperature. With 4 limit values and logic gates
(AND
control-
ler for heating/cooling. Configuration with ETS software. For assembly
in a
socket with cover (cover not included in scope of delivery) ---------
89€
KNX AQS Air Quality Sensor for KNX/EIB
Measures the concentration of CO2 in the ambient air. With 4 limit
values
and logic gates (AND and OR). Output of a mixed value from own and
external value. PI controller for one- or two-stage ventilation.
------- 199€
KNX T-AP Temperature Sensor for KNX/EIB
Sensor for indoor and outdoor applications. Output of an overall
tempera-
ture (mixed value from own and external value). 4 limit values. PI
control-
ler for heating and cooling. --------------------- 149€
On 27 nov, 10:59, keldo <kelderm...@ibelgique.com> wrote:
> Bonjour.
> Moeller (= Felten&Guilleaume) propose un petit module "mesure de
> température" à 4 canaux sous la ref. EB-U/TE/04/01, à 175 euros.
> A ce module, se connectent jusqu'à 4 sensors ref. EB-Z/SE/01/01, à 25
> euros pièce.
> Le cable d'un sensor fait 1,5m mais on peut l'allonger avec du cable
> standard jusqu'à 30 mètres.
> Pour un seul canal de mesure, 200 euros, ça fait cher ...
> Mais 275 euros pour 4, cela devient déjà plus raisonnable.
> Ou alors, il te reste aussi l'option "montage personnel" pour moins de
> 100 euros :
> - page principale :http://dehof.de/eib/DE/index.html
> - lien spécifique pour capteur de température (projet "EIB 1-Kanal A/
> D") :http://dehof.de/eib/DE/analog1.htm
> ou, éventuellement, le projet temp+hygro "SHT-Sensor".
> Keldo
and logic gates
dis-
Calcu-
Out-
hea-
189€
(AND
control-
in a
89€
values
------- 199€
tempera-
control-
> Bonjour.
> euros pièce.
> 100 euros :
> Keldo
