Nouvelle version de Linknx 0.0.1.28
Pour info jean-François a validé une nouvelle release de linknx il y a
quelques jours ...
voici joint la liste des nombreuses évolutions de cette version, fruit de
nombreuses heures de travail ...
et un lien pour la télécharger :
http://sourceforge.net/projects/linknx/f...-0.0.1.28/
merci encore à lui pour sont travail
Anthony
Release 0.0.1.28:
* Add conditional actions (skip executions of a group of actions based
on a given condition)
* Do not execute stateless rules at init (problem with object conditions
because EIBD connection not yet established)
* Avoid use of tmpfile() function in XML parser (not supported on
FritzBox)
* Allow to insert object values in some actions (shell, e-mail, SMS,
io-port, set-string)
* Add condition to compare 2 objects (requires complete refactoring of
Object and ObjectValue classes)
* Fix for exportXML with Object-Conditions without value (michael111)
* Add "toggle-value" action that will toggle value of a switching object
* Allow millisecond delays in actions
* Add "repeat" action that repeats a list of actions periodically a
specified number of times
* Add "cancel" action to cancel all ongoing actions of a rule
* Add "send-read-request" action that will force sending of a read
request on the bus
* Add attribute read="true" for listener address which is used to send
read request on the bus
* Initial schedule for timers with at and *during* fixed (michael111)
* Support for serial IO port
* Support for variable length string objects (DPT 28.001)
* Allow multiple messages in receive buffer (Mike Pieper)
* Add command to Register/Unregister all objects for notification (Mike
Pieper)
* Better command-line parameter error reporting (Mike Pieper)
* Fixes the XML for a notification message (Mike Pieper)
* Avoid linknx crash in case of mysql error
* Time-counter bugfix and 0-threshold support (Auto-Mate)
* Fix bug on x64 due to size_t != unsigned int
* Add command to query rules/timers status
* Add support for DPT 29.xxx (signed 64bit value)
* Fix TimeCounter condition not removed from timer queue when
rescheduled
Nouvelle version de Linknx 0.0.1.28 - par Anthony PENHARD - 11/03/2011, 11:42:59
Nouvelle version de Linknx 0.0.1.28 - par jef2000 - 11/03/2011, 16:56:20
Nouvelle version de Linknx 0.0.1.28 - par frederic Gilliard - 11/03/2011, 17:02:41
Nouvelle version de Linknx 0.0.1.28 - par jef2000 - 11/03/2011, 21:12:49
Nouvelle version de Linknx 0.0.1.28 - par sprint95 - 12/03/2011, 10:13:21
Nouvelle version de Linknx 0.0.1.28 - par Ben - 12/03/2011, 11:05:32
Nouvelle version de Linknx 0.0.1.28 - par Arnaud Cognard - 12/03/2011, 15:31:55
Nouvelle version de Linknx 0.0.1.28 - par jef2000 - 12/03/2011, 17:50:06
Nouvelle version de Linknx 0.0.1.28 - par Ben - 12/03/2011, 18:23:47
Nouvelle version de Linknx 0.0.1.28 - par Jupin Yannick - 12/03/2011, 19:43:21
Nouvelle version de Linknx 0.0.1.28 - par jef2000 - 12/03/2011, 22:21:52
Nouvelle version de Linknx 0.0.1.28 - par Arnaud Cognard - 13/03/2011, 19:11:15
Utilisateur(s) parcourant ce sujet : 17 visiteur(s)
