12/11/2021, 17:29:09
et dans le fichier .xml tu ne modifie pas le project 11???
avec mon numero de version d'ETS5 c'est avec project 14 que cela fonctionne
<?xml version="1.0" encoding="utf-8"?>
<KNX xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" CreatedBy="KNX MT" ToolVersion="5.6.407.26745" xmlns="http://knx.org/xml/project/11">
<ManufacturerData>
<Manufacturer RefId="M-00FA">
<Catalog>
<CatalogSection Id="M-00FA_CS-1" Name="Geräte" Number="1" DefaultLanguage="en-US">
<CatalogItem Id="M-00FA_H-0124-0_HP-ABCE-79-0000_CI-IA4313-1" Name="Temperatursensor TP" Number="1" ProductRefId="M-00FA_H-0124-0_P-IA4313" Hardware2ProgramRefId="M-00FA_H-0124-0_HP-ABCE-79-0000" DefaultLanguage="en-US" />
</CatalogSection>
</Catalog>
<ApplicationPrograms>
<ApplicationProgram Id="M-00FA_A-ABCE-79-0000" ApplicationNumber="43982" ApplicationVersion="121" ProgramType="ApplicationProgram" MaskVersion="MV-07B0" Name="TK TEMP TP" LoadProcedureStyle="MergedProcedure" PeiType="0" DefaultLanguage="en-US" DynamicTableManagement="false" Linkable="false" MinEtsVersion="4.0">
<Static>
<Code>
<RelativeSegment Id="M-00FA_A-ABCE-79-0000_RS-04-00000" Name="Parameters" Offset="0" Size="8" LoadStateMachine="4" />
</Code>
<ParameterTypes>
<ParameterType Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout" Name="startupTimeout">
<TypeRestriction Base="Value" SizeInBit="8">
<Enumeration Text="0 s" Value="0" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-0" />
<Enumeration Text="1 s" Value="1" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-1" />
<Enumeration Text="2 s" Value="2" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-2" />
<Enumeration Text="3 s" Value="3" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-3" />
<Enumeration Text="4 s" Value="4" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-4" />
<Enumeration Text="5 s" Value="5" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-5" />
<Enumeration Text="6 s" Value="6" Id="M-00FA_A-ABCE-79-0000_PT-startupTimeout_EN-6" />
</TypeRestriction>
</ParameterType>
<ParameterType Id="M-00FA_A-ABCE-79-0000_PT-TempChange" Name="TempChange">
<Enumeration Text="Disabled" Value="0" Id="M-00FA_A-ABCE-79-0000_PT-TempChange_EN-0" />
<Enumeration Text="0.1 K" Value="1" Id="M-00FA_A-ABCE-79-0000_PT-TempChange_EN-1" />
<Enumeration Text="0.2 K" Value="2" Id="M-00FA_A-ABCE-79-0000_PT-TempChange_EN-2" />
<Enumeration Text="0.3 K" Value="3" Id="M-00FA_A-ABCE-79-0000_PT-TempChange_EN-3" />
</TypeRestriction>
</ParameterType>
<ParameterType Id="M-00FA_A-ABCE-79-0000_PT-TempCycle" Name="TempCycle">
<Enumeration Text="Disabled" Value="0" Id="M-00FA_A-ABCE-79-0000_PT-TempCycle_EN-0" />
<Enumeration Text="1 min" Value="1" Id="M-00FA_A-ABCE-79-0000_PT-TempCycle_EN-1" />
<Enumeration Text="2 min" Value="2" Id="M-00FA_A-ABCE-79-0000_PT-TempCycle_EN-2" />
<Enumeration Text="3 min" Value="3" Id="M-00FA_A-ABCE-79-0000_PT-TempCycle_EN-3" />
</TypeRestriction>
</ParameterType>
<ParameterType Id="M-00FA_A-ABCE-79-0000_PT-TempAbgleich" Name="TempAbgleich">
<TypeNumber SizeInBit="32" Type="signedInt" minInclusive="-50" maxInclusive="50" />
</ParameterType>
<ParameterType Id="M-00FA_A-ABCE-79-0000_PT-TempSendMinMax" Name="TempSendMinMax">
<Enumeration Text="Disabled" Value="0" Id="M-00FA_A-ABCE-79-0000_PT-TempSendMinMax_EN-0" />
<Enumeration Text="Send Enable" Value="1" Id="M-00FA_A-ABCE-79-0000_PT-TempSendMinMax_EN-1" />
</TypeRestriction>
</ParameterType>
</ParameterTypes>
<Parameters>
<Parameter Id="M-00FA_A-ABCE-79-0000_P-1" Name="startupTimeout" ParameterType="M-00FA_A-ABCE-79-0000_PT-startupTimeout" Text="Startup delaytime" Value="0">
<Memory CodeSegment="M-00FA_A-ABCE-79-0000_RS-04-00000" Offset="0" BitOffset="0" />
</Parameter>
<Parameter Id="M-00FA_A-ABCE-79-0000_P-2" Name="Aender Senden" ParameterType="M-00FA_A-ABCE-79-0000_PT-TempChange" Text="Send actual value after change of" Value="0">
<Memory CodeSegment="M-00FA_A-ABCE-79-0000_RS-04-00000" Offset="1" BitOffset="0" />
</Parameter>
<Parameter Id="M-00FA_A-ABCE-79-0000_P-3" Name="ZyklSenden" ParameterType="M-00FA_A-ABCE-79-0000_PT-TempCycle" Text="Send actual temperature cyclically" Value="0">
<Memory CodeSegment="M-00FA_A-ABCE-79-0000_RS-04-00000" Offset="2" BitOffset="0" />
</Parameter>
<Parameter Id="M-00FA_A-ABCE-79-0000_P-4" Name="MinMaxSenden" ParameterType="M-00FA_A-ABCE-79-0000_PT-TempSendMinMax" Text="Send min/max value" Value="0">
<Memory CodeSegment="M-00FA_A-ABCE-79-0000_RS-04-00000" Offset="3" BitOffset="0" />
</Parameter>
<Parameter Id="M-00FA_A-ABCE-79-0000_P-5" Name="Abgleich" ParameterType="M-00FA_A-ABCE-79-0000_PT-TempAbgleich" Text="Internal sensor correction value (value * 0.1 K)" Value="0">
<Memory CodeSegment="M-00FA_A-ABCE-79-0000_RS-04-00000" Offset="4" BitOffset="0" />
</Parameter>
</Parameters>
<ParameterRefs>
<ParameterRef Id="M-00FA_A-ABCE-79-0000_P-1_R-1" RefId="M-00FA_A-ABCE-79-0000_P-1" />
<ParameterRef Id="M-00FA_A-ABCE-79-0000_P-2_R-2" RefId="M-00FA_A-ABCE-79-0000_P-2" />
<ParameterRef Id="M-00FA_A-ABCE-79-0000_P-3_R-3" RefId="M-00FA_A-ABCE-79-0000_P-3" />
<ParameterRef Id="M-00FA_A-ABCE-79-0000_P-4_R-4" RefId="M-00FA_A-ABCE-79-0000_P-4" />
<ParameterRef Id="M-00FA_A-ABCE-79-0000_P-5_R-5" RefId="M-00FA_A-ABCE-79-0000_P-5" />
</ParameterRefs>
<ComObjectTable>
<ComObject Id="M-00FA_A-ABCE-79-0000_O-1" Name="Current temperature value" Text="Current temperature value" Number="1" FunctionText="Transmit temperature value" ObjectSize="2 Bytes" ReadFlag="Enabled" WriteFlag="Disabled" CommunicationFlag="Enabled" TransmitFlag="Enabled" UpdateFlag="Disabled" ReadOnInitFlag="Disabled" DatapointType="" />
<ComObject Id="M-00FA_A-ABCE-79-0000_O-2" Name="Max memory value" Text="Max memory value" Number="2" FunctionText="Read memory" ObjectSize="2 Bytes" ReadFlag="Enabled" WriteFlag="Disabled" CommunicationFlag="Enabled" TransmitFlag="Enabled" UpdateFlag="Disabled" ReadOnInitFlag="Disabled" DatapointType="" />
<ComObject Id="M-00FA_A-ABCE-79-0000_O-3" Name="Min memory value" Text="Min memory value" Number="3" FunctionText="Read memory" ObjectSize="2 Bytes" ReadFlag="Enabled" WriteFlag="Disabled" CommunicationFlag="Enabled" TransmitFlag="Enabled" UpdateFlag="Disabled" ReadOnInitFlag="Disabled" DatapointType="" />
<ComObject Id="M-00FA_A-ABCE-79-0000_O-4" Name="Min/max memory reseet" Text="Min/max memory reseet" Number="4" FunctionText="Reset memory" ObjectSize="1 Bit" ReadFlag="Disabled" WriteFlag="Enabled" CommunicationFlag="Enabled" TransmitFlag="Disabled" UpdateFlag="Disabled" ReadOnInitFlag="Disabled" DatapointType="" />
</ComObjectTable>
<ComObjectRefs>
<ComObjectRef Id="M-00FA_A-ABCE-79-0000_O-1_R-1" RefId="M-00FA_A-ABCE-79-0000_O-1" />
<ComObjectRef Id="M-00FA_A-ABCE-79-0000_O-2_R-2" RefId="M-00FA_A-ABCE-79-0000_O-2" />
<ComObjectRef Id="M-00FA_A-ABCE-79-0000_O-3_R-3" RefId="M-00FA_A-ABCE-79-0000_O-3" />
<ComObjectRef Id="M-00FA_A-ABCE-79-0000_O-4_R-4" RefId="M-00FA_A-ABCE-79-0000_O-4" />
</ComObjectRefs>
<AddressTable MaxEntries="65000" />
<AssociationTable MaxEntries="65000" />
<LoadProcedures>
<LoadProcedure MergeId="2">
<LdCtrlRelSegment AppliesTo="full" LsmIdx="4" Size="8" Mode="0" Fill="0" />
</LoadProcedure>
<LoadProcedure MergeId="4">
<LdCtrlWriteRelMem ObjIdx="4" Offset="0" Size="8" Verify="true" />
</LoadProcedure>
</LoadProcedures>
<Options />
</Static>
<Dynamic>
<ChannelIndependentBlock>
<ParameterBlock Id="M-00FA_A-ABCE-79-0000_PB-1" Name="ParameterPage" Text="Allgemeine Parameter">
<ParameterRefRef RefId="M-00FA_A-ABCE-79-0000_P-1_R-1" />
<ParameterRefRef RefId="M-00FA_A-ABCE-79-0000_P-2_R-2" />
<ParameterRefRef RefId="M-00FA_A-ABCE-79-0000_P-3_R-3" />
<ParameterRefRef RefId="M-00FA_A-ABCE-79-0000_P-4_R-4" />
<ParameterRefRef RefId="M-00FA_A-ABCE-79-0000_P-5_R-5" />
<ComObjectRefRef RefId="M-00FA_A-ABCE-79-0000_O-1_R-1" />
<ComObjectRefRef RefId="M-00FA_A-ABCE-79-0000_O-2_R-2" />
<ComObjectRefRef RefId="M-00FA_A-ABCE-79-0000_O-3_R-3" />
<ComObjectRefRef RefId="M-00FA_A-ABCE-79-0000_O-4_R-4" />
</ParameterBlock>
</ChannelIndependentBlock>
</Dynamic>
</ApplicationProgram>
</ApplicationPrograms>
<Hardware>
<Hardware Id="M-00FA_H-0124-0" Name="SAMD Random" SerialNumber="0124" VersionNumber="0" BusCurrent="10" HasIndividualAddress="true" HasApplicationProgram="true">
<Products>
<Product Id="M-00FA_H-0124-0_P-IA4313" Text="Temperatursensor TP" OrderNumber="IA4313" IsRailMounted="false" DefaultLanguage="en-US" />
</Products>
<Hardware2Programs>
<Hardware2Program Id="M-00FA_H-0124-0_HP-ABCE-79-0000" MediumTypes="MT-0">
<ApplicationProgramRef RefId="M-00FA_A-ABCE-79-0000" />
</Hardware2Program>
</Hardware2Programs>
</Hardware>
</Hardware>
</Manufacturer>
</ManufacturerData>
</KNX>
uniquement les partie en violet
c'est à dire la version d'ETS5 pour moi en 5.6.241.33672 et project 11 en project 14
<ManufacturerData>
<Catalog>
</CatalogSection>
</Catalog>
<Static>
<Code>
</Code>
<ParameterTypes>
</TypeRestriction>
</ParameterType>
</TypeRestriction>
</ParameterType>
</TypeRestriction>
</ParameterType>
</ParameterType>
</TypeRestriction>
</ParameterType>
</ParameterTypes>
<Parameters>
</Parameter>
</Parameter>
</Parameter>
</Parameter>
</Parameter>
</Parameters>
<ParameterRefs>
</ParameterRefs>
<ComObjectTable>
</ComObjectTable>
<ComObjectRefs>
</ComObjectRefs>
<LoadProcedures>
</LoadProcedure>
</LoadProcedure>
</LoadProcedures>
<Options />
</Static>
<Dynamic>
</ParameterBlock>
</Dynamic>
<Hardware>
<Products>
</Products>
<Hardware2Programs>
</Hardware2Program>
</Hardware>
</Hardware>
</Manufacturer>
</ManufacturerData>
</KNX>
