  • Moyenne : 5 (1 vote(s))
Elausys une idée originale et compétitive pour le prix
#8
ci joint la liste des canaux pour elausys pour onduleur HUAWEI
C'est quand même pas mal en triphasé avec 2 batteries différentes!!
Je ne connais rien de semblable.
Nom Fonction d'objet Adresse de Groupe Numéro Longueur C R W Description U T Priorité Type de données
Module status Status code 1 1 byte C R - - T Bas system error class
Firmware version Text string 2 14 bytes C R - - - Bas Character String (ASCII)
AC Total Current Actual value 3 4 bytes C R - - T Bas electric current (A)
AC Current phase A Actual value 4 4 bytes C R - - T Bas electric current (A)
AC Current phase B Actual value 5 4 bytes C R - - T Bas electric current (A)
AC Current phase C Actual value 6 4 bytes C R - - T Bas electric current (A)
AC Total voltage Actual value 7 4 bytes C R - - T Bas electric potential (V)
AC Voltage Phase AB Actual value 8 4 bytes C R - - T Bas electric potential (V)
AC Voltage Phase BC Actual value 9 4 bytes C R - - T Bas electric potential (V)
AC Voltage Phase CA Actual value 10 4 bytes C R - - T Bas electric potential (V)
AC Voltage Phase A-Neutral Actual value 11 4 bytes C R - - T Bas electric potential (V)
AC Voltage Phase B-Neutral Actual value 12 4 bytes C R - - T Bas electric potential (V)
AC Voltage Phase C-Neutral Actual value 13 4 bytes C R - - T Bas electric potential (V)
DC Total Current Actual value 14 4 bytes C R - - T Bas electric current (A)
DC Total voltage Actual value 15 4 bytes C R - - T Bas electric potential (V)
PV1 Voltage Actual value 16 4 bytes C R - - T Bas electric potential (V)
PV1 Current Actual value 17 4 bytes C R - - T Bas electric current (A)
PV2 Voltage Actual value 18 4 bytes C R - - T Bas electric potential (V)
PV2 Current Actual value 19 4 bytes C R - - T Bas electric current (A)
PV3 Voltage Actual value 20 4 bytes C R - - T Bas electric potential (V)
PV3 Current Actual value 21 4 bytes C R - - T Bas electric current (A)
PV4 Voltage Actual value 22 4 bytes C R - - T Bas electric potential (V)
PV4 Current Actual value 23 4 bytes C R - - T Bas electric current (A)
AC Power Actual value 24 4 bytes C R - - T Bas power (W)
DC Power Actual value 25 4 bytes C R - - T Bas power (W)
AC Frequency Actual value 26 4 bytes C R - - T Bas frequency (Hz)
AC Apparent power Actual value 27 4 bytes C R - - T Bas power (W)
AC Reactive power Actual value 28 4 bytes C R - - T Bas power (W)
AC power factor Actual value 29 4 bytes C R - - T Bas power factor (cos Φ)
AC Total Energy Actual value 30 4 bytes C R - - T Bas active energy (kWh)
Inverter efficiency Actual value 31 2 bytes C R - - T Bas percentage difference (%)
Inverter resistance Actual value 32 4 bytes C R - - T Bas resistance (Ω)
Cabinet Temperature Actual value 33 2 bytes C R - - T Bas temperature (°C)
AC Daily Energy Yield Actual value 40 4 bytes C R - - T Bas active energy (kWh)
Battery 1 - Running Status Status code 41 2 bytes C R - - T Bas
Battery 1 - Charge/Discharge Power (>0: charging / <0:discharging) Actual value 42 4 bytes C R - - T Bas power (W)
Battery 1 - State of Charge Actual value 43 1 byte C R - - T Bas percentage (0..100%)
Battery 1 - Current day charge capacity Actual value 44 4 bytes C R - - T Bas active energy (kWh)
Battery 1 - Current day discharge capacity Actual value 45 4 bytes C R - - T Bas active energy (kWh)
Battery 1 - Total charge capacity Actual value 46 4 bytes C R - - T Bas active energy (kWh)
Battery 1 - Total discharge capacity Actual value 47 4 bytes C R - - T Bas active energy (kWh)
Battery 2 - Running Status Status code 48 2 bytes C R - - T Bas
Battery 2 - Charge/Discharge Power (>0: charging / <0:discharging) Actual value 49 4 bytes C R - - T Bas power (W)
Battery 2 - State of Charge Actual value 50 1 byte C R - - T Bas percentage (0..100%)
Battery 2 - Current day charge capacity Actual value 51 4 bytes C R - - T Bas active energy (kWh)
Battery 2 - Current day discharge capacity Actual value 52 4 bytes C R - - T Bas active energy (kWh)
Battery 2 - Total charge capacity Actual value 53 4 bytes C R - - T Bas active energy (kWh)
Battery 2 - Total discharge capacity Actual value 54 4 bytes C R - - T Bas active energy (kWh)
Powermeter - Active Power (>0: producing to grid / <0:consuming from grid) Actual value 55 4 bytes C R - - T Bas power (W)
RE: Elausys une idée originale et compétitive pour le prix - par richardpub - 26/02/2022, 18:32:43
