31/05/2010, 22:37:50
hey, j'étais pas root
, mais bon, c pas beaucoup mieux
pceib:/usr/local/bin# eibd -t65535 -D -S -T -i usb:1:2:1:0
Layer 1(080A18F8,4C042B22) Detect
Layer 1(080A18F8,4C042B22) Using 2 (1:2:1:0) (2:129)
Layer 1(080A18F8,4C042B22) Open
Layer 1(080A18F8,4C042B22) Claimed
Layer 1(080A18F8,4C042B22) Opened
Layer 1(080A18F8,4C042B22) Send(064): 01 13 09 00 08 00 01 0F 01 00 00
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Layer 0(080A18F8,4C042B22) StartRecv
Layer 0(080A18F8,4C042B22) Send(064): 01 13 09 00 08 00 01 0F 01 00 00
Layer 0(080A18F8,4C042B22) StartSend
Layer 0(080A18F8,4C042B22) SendComplete 64
Layer 0(080A18F8,4C042B22) RecvComplete 64
Layer 0(080A18F8,4C042B22) RecvUSB(064): 01 13 0B 00 08 00 03 0F 02 00
00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Layer 1(080A18F8,4C042B22) Recv(064): 01 13 0B 00 08 00 03 0F 02 00 00
Layer 1(080A18F8,4C042B22) Unsupported EMI 00 00
Layer 1(080A18F8,4C042B22) Close
Layer 1(080A18F8,4C042B22) Release
initialisation of the backend failed
any idea ?
On 31 mai, 23:25, chitloft <arnaud.cogn...@laposte.net> wrote:
> ach, j y suis presque...
> bzhchti@pceib:/usr/local/bin$ eibd -t65535 -D -S -T -i usb:1:2:1:0
> Layer 1(080A18F8,4C042940) Detect
> Layer 1(080A18F8,4C042940) Using 2 (1:2:1:0) (2:129)
> Layer 1(080A18F8,4C042940) Open
> Layer 1(080A18F8,4C042940) Close
> Layer 1(080A18F8,4C042940) Release
> 1 dernier cout de main ?
> Merci
> On 31 mai, 22:20, chitloft <arnaud.cogn...@laposte.net> wrote:
> > bonsoir,
> > j'ai abandonné la solution vm pour le mement.
> > donc oui, le modop de Kraven fonctionne.
> > j'ai ajouté ceci
> > ln -s /root/linknx/linknx-0.0.1.27 /var/lib/linknx
> > cd /var/lib/linknx
> > mkdir persist
> > configurer le fichier linknx.xml sous /var/lib/linknx/linknx-0.0.1.27/
> > conf
> > y a plus qu a utiliser tout ca.
> > Merci a vous.
> > On 30 mai, 21:38, chitloft <arnaud.cogn...@laposte.net> wrote:
> > > Salut Jeff, oui, j'avias pirs connaissance de tout ca, merci quand
> > > meme !
> > > en fait, je pense que ca vient de la manière de construire la VM.
> > > je vais remonter de plusieurs facon , soit en choisisant directement l
> > > usb jung, soit seulement en activant l usb, et le montant après (je ne
> > > sais plus comment jai construit la vm).
> > > Merci.
> > > Arnaud
> > > On 28 mai, 20:25, jef2000 <jef2...@ouaye.net> wrote:
> > > > Regarde si tu as un fichier /proc/bus/usb/devices dans ton ubuntu et
> > > > si il contient bien une entrée concernant ton interface KNX usb.
> > > > Si le fichier n'existe pas (probablement parce que /proc/bus/usb est
> > > > vide), il faut peut-être monter usbfs avec la commande:
> > > > mount -t usbdevfs none /proc/bus/usb
> > > > Ou bien lire ceci:http://doc.ubuntu-fr.org/utilisateurs/brazz/virtualbox_gestion_usb
> > > > A+
> > > > Jean-François
> > > > On 27 mai, 23:27, chitloft <arnaud.cogn...@laposte.net> wrote:
> > > > > Bonsoir les amis, je suis largué la !
> > > > > dans la vm, j'ai bien activé via les préférence le controleur usb,
> > > > > trouvé dans les filtres mon usb jung.via clic droit sur la ligne qui
> > > > > représente l usb, j'ai meme essayé en activant / desactivant le choix
> > > > > 'a distance'
> > > > > je démarre la vm ubuntu et on voit clignoter l'icone en bas qui
> > > > > représente l usb.
> > > > > le menu contextuel affiche bien les propriétés de mon usb jung.
> > > > > si je tape
> > > > > bzhchti@pcknx:~$ lspci
> > > > > 00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma]
> > > > > (rev 02)
> > > > > 00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton
> > > > > II]
> > > > > 00:01.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev
> > > > > 01)
> > > > > 00:02.0 VGA compatible controller: InnoTek Systemberatung GmbH
> > > > > VirtualBox Graphics Adapter
> > > > > 00:03.0 Ethernet controller: Advanced Micro Devices [AMD] 79c970
> > > > > [PCnet32 LANCE] (rev 40)
> > > > > 00:04.0 System peripheral: InnoTek Systemberatung GmbH VirtualBox
> > > > > Guest Service
> > > > > 00:05.0 Multimedia audio controller: Intel Corporation 82801AA AC'97
> > > > > Audio Controller (rev 01)
> > > > > 00:06.0 USB Controller: Apple Computer Inc. KeyLargo/Intrepid USB
> > > > > 00:07.0 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 08)
> > > > > 00:0b.0 USB Controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6
> > > > > Family) USB2 EHCI Controller
> > > > > si je desactive le port usb, la derniere ligne disparait. Je pense
> > > > > donc que le port est bien actif.
> > > > > bzhchti@pcknx:~$ findknxusb
> > > > > Possible addresses for KNX USB devices:
> > > > > bzhchti@pcknx:~$
> > > > > donc pas de progrès ce soir... si qq1 a été confronté a cela ou a des
> > > > > tuyaux, je suis preneur, je seche terriblement.
> > > > > Merci
> > > > > On 26 mai, 23:06, chitloft <arnaud.cogn...@laposte.net> wrote:
> > > > > > Super, merci pour ta réponse : voila mon probleme, l usb n est pas
> > > > > > trouvé via findknxusb. je cherche coté virtualbox...
> > > > > > On 26 mai, 20:42, jef2000 <jef2...@ouaye.net> wrote:
> > > > > > > Salut,
> > > > > > > Si tu lances eibd avec les paramêtres suivant: eibd -t65535 -D -S -T -
> > > > > > > i ipt:127.0.0.1:3671
> > > > > > > Cela veut dire qu'il sera à la fois serveur pour le protocole KnxNet/
> > > > > > > IP tunneling (c'est les paramètres -S -T) et client pour le protocole
> > > > > > > KnxNet/IP tunneling (c'est le paramètre ipt:127.0.0.1:3671 ) et comme
> > > > > > > tu lui donne sa propre adresse IP (127.0.0.1), en fait il se connecte
> > > > > > > sur lui même et se mord la queue. Donc quand tu envoi qqch ça tourne
> > > > > > > en rond. Si tu as une interface usb, il faut remplacer ipt:
> > > > > > > 127.0.0.1:3671 par usb:x:y (x et y sont 2 nombres qui identifient
> > > > > > > l'interface knx sur le bus usb, normalement tu as l'utilitaire
> > > > > > > findknxusb avec eibd qui permet de détecter les interfaces knx usb et
> > > > > > > donner leur x et y )
> > > > > > > A+
> > > > > > > Jean-François
> > > > > > > On 26 mai, 00:54, chitloft <arnaud.cogn...@laposte.net> wrote:
> > > > > > > > Salut, pour moi, la version virtualbox est la bonne. usb a été trouvé
> > > > > > > > dans les préférence, et chargé (maintenant, je n sais pas comment m en
> > > > > > > > assurer)
> > > > > > > > j'ai suivi le tuto et rien dans /var/lib/linknx/
> > > > > > > > par contre eibd semble fonctionner cette fois , (quoique, j n en suis
> > > > > > > > pas certains).
> > > > > > > > bzhchti@pcknx:~$ eibd -t65535 -D -S -T -i ipt:127.0.0.1:3671
> > > > > > > > Layer 2(09A5F680,4BFC5467) Open
> > > > > > > > Layer 0(09A5FB70,4BFC5467) Open
> > > > > > > > Layer 0(09A5FB70,4BFC5467) Openend
> > > > > > > > Layer 2(09A5F680,4BFC5467) Opened
> > > > > > > > Layer 3(09A80278,4BFC5467) Open
> > > > > > > > Layer 8(09A90608,4BFC5467) OpenInetSocket 6720
> > > > > > > > Layer 8(09A90608,4BFC5467) InetSocket opened
> > > > > > > > Layer 8(09AA0958,4BFC5467) Open
> > > > > > > > Layer 0(09AA09B8,4BFC5467) Open
> > > > > > > > Layer 0(09AA09B8,4BFC5467) Openend
> > > > > > > > Layer 3(09A80278,4BFC5467) registerBroadcast 09AA0958
> > > > > > > > Layer 3(09A80278,4BFC5467) registerBroadcast 09AA0958 = 1
> > > > > > > > Layer 3(09A80278,4BFC5467) registerGroup 09AA0958
> > > > > > > > Layer 3(09A80278,4BFC5467) registerGroup 09AA0958 = 1
> > > > > > > > Layer 3(09A80278,4BFC5467) registerIndividual 09AA0958 0
> > > > > > > > Layer 3(09A80278,4BFC5467) registerIndividual 09AA0958 = 1
> > > > > > > > Layer 8(09AA0958,4BFC5467) Opened
> > > > > > > > Layer 4(09AC10E0,4BFC5467) GroupCacheInit
> > > > > > > > Layer 1(09A5FB70,4BFC5467) Send(020): 08 01 7F 00 00 01 0E 58 08 01 7F
> > > > > > > > 00 00 01 0E 58 04 04 02 00
> > > > > > > > Layer 0(09A5FB70,4BFC5467) Send(026): 06 10 02 05 00 1A 08 01 7F 00 00
> > > > > > > > 01 0E 58 08 01 7F 00 00 01 0E 58 04 04 02 00
> > > > > > > > Layer 0(09AA09B8,4BFC5467) Recv(026): 06 10 02 05 00 1A 08 01 7F 00 00
> > > > > > > > Layer 1(09AA09B8,4BFC5467) Recv(020): 08 01 7F 00 00 01 0E 58 08 01 7F
> > > > > > > > Layer 1(09AA09B8,4BFC5467) Send(014): 01 00 08 01 7F 00 00 01 0E 57 04
> > > > > > > > 04 00 00
> > > > > > > > Layer 0(09AA09B8,4BFC5467) Send(020): 06 10 02 06 00 14 01 00 08 01 7F
> > > > > > > > 00 00 01 0E 57 04 04 00 00
> > > > > > > > Layer 0(09A5FB70,4BFC5467) Recv(020): 06 10 02 06 00 14 01 00 08 01 7F
> > > > > > > > Layer 1(09A5FB70,4BFC5467) Recv(014): 01 00 08 01 7F 00 00 01 0E 57 04
> > > > > > > > 04 00 00
> > > > > > > > si je lance bzhchti@pcknx:/usr/local/lib$ /usr/local/bin/groupswrite
> > > > > > > > ip:192.168.0.19 0/1/1 1
> > > > > > > > Send request
> > > > > > > > le serveur s emballe.
> > > > > > > > Any more help ?
> > > > > > > > Merci
> > > > > > > > On 25 mai, 08:38, Frédéric <f...@gbiloba.org> wrote:
> > > > > > > > > On mardi 25 mai 2010, kraven wrote:
> > > > > > > > > > Es-tu certain que ton port usb est utilisable dams ta VM?
> > > > > > > > > Il faut la version avec license commerciale, pas la version libre, pour le
> > > > > > > > > suport usb. Cette version commerciale est aussi gratuite, mais pas sur
> > > > > > > > > toutes les plateformes, il me semble (je peux me gourrer, je dis ça de
> > > > > > > > > mémoire).
> > > > > > > > > Frédéric- Masquer le texte des messages précédents -
> > > > > > > - Afficher le texte des messages précédents -- Masquer le texte des messages précédents -
, mais bon, c pas beaucoup mieuxpceib:/usr/local/bin# eibd -t65535 -D -S -T -i usb:1:2:1:0
any idea ?
> Merci
> > bonsoir,
> > j'ai ajouté ceci
> > cd /var/lib/linknx
> > mkdir persist
> > conf
> > Merci a vous.
> > > meme !
> > > Merci.
> > > Arnaud
> > > > A+
> > > > Jean-François
> > > > > 'a distance'
> > > > > représente l usb.
> > > > > si je tape
> > > > > (rev 02)
> > > > > II]
> > > > > 01)
> > > > > Guest Service
> > > > > bzhchti@pcknx:~$
> > > > > Merci
> > > > > > > Salut,
> > > > > > > A+
> > > > > > > Jean-François
> > > > > > > > assurer)
.> > > > > > > > par contre eibd semble fonctionner cette fois , (quoique, j n en suis
> > > > > > > > pas certains).
> > > > > > > > 04 00 00
> > > > > > > > 04 00 00
> > > > > > > > Send request
> > > > > > > > Any more help ?
> > > > > > > > Merci
> > > > > > > > > mémoire).
