Linknx sur un NAS QNAP.
#16
J'ai mon Ts-109 de QNAP, j'ai tout installé et voici ma config :
[/] # dmesg
0 pages, LIFO batch:1
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: console=ttyS0,115200n8 root=/dev/ram rw
initrd=0x800000,0x3fffff
PID hash table entries: 2048 (order: 11, 32768 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 128MB 128MB 0MB 0MB = 256MB total
Memory: 251904KB available (2941K code, 447K data, 104K init)
Calibrating delay loop... 332.59 BogoMIPS (lpj=1662976)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
checking if image is initramfs...it isn't (no cpio magic); looks like
an initrd
Freeing initrd memory: 4095K
NET: Registered protocol family 16
CPU Interface
SDRAM_CS0 ....base 00000000, size 128MB
SDRAM_CS1 ....base 10000000, size 128MB
SDRAM_CS2 ....disable
SDRAM_CS3 ....disable
PEX0_MEM ....base e0000000, size 128MB
PEX0_IO ....base f2000000, size 1MB
PCI0_MEM ....base e8000000, size 128MB
PCI0_IO ....base f2100000, size 1MB
INTER_REGS ....base f1000000, size 1MB
DEVICE_CS0 ....no such
DEVICE_CS1 ....base f4000000, size 16MB
DEVICE_CS2 ....no such
DEV_BOOCS ....base ff800000, size 8MB
CRYPTO ENG ....base f0000000, size 64KB
Marvell Development Board (LSP Version 1.10.3_DB_NAS)-- RD-88F5182-
NAS-2 Soc: 88F5182 A2
Detected Tclk 166666667 and SysClk 166666667
Marvell USB EHCI Host controller #0: c0573560
Marvell USB EHCI Host controller #1: c0573460
mvPexTargetWinEnable: Win 1 should be in bar boundries
mvPexInit: Can't enable window =1
pci_init:Error calling mvPciIfInit for pciIf 0
PCI: bus0: Fast back to back transfers enabled
PCI: bus1: Fast back to back transfers enabled
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
QNAP RTC initializing....
Initializing RTC is completed.
Detected Tclk 166666667, BASE_BAUD 10416666, Baud divisor 542
qnap_pic_init: succeed to register misc device
tsinfo: create proc systemp successfully
Use the XOR engines (offloading) for enhancing the following
functions:
o RAID 5 Xor calculation
o kernel memcpy
o kenrel memzero
o copy user to/from kernel buffers
Number of XOR engines to use: 2
cesadev_init(c0011b30)
Fast Floating Point Emulator V0.9 © Peter Teichmann.
inotify device minor=63
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Installing knfsd (copyright © 1996 okir@monad.swb.de).
Initializing Cryptographic API
Serial: 8250/16550 driver $Revision: 1.1.1.1 $ 4 ports, IRQ sharing
disabled
ttyS0 at MMIO 0x0 (irq = 3) is a 16550A
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
loop: loaded (max 8 devices)
Marvell Gigabit Ethernet Driver 'egiga':
o Ethernet descriptors in DRAM
o DRAM SW cache-coherency
o Checksum offload enabled
o Marvell ethtool proc enabled
o Loading network interface 'eth0'
STRIP: Version 1.3A-STUART.CHESHIRE (unlimited channels)
Intergrated Sata device found
Wait 15 seconds to initialize mvAdapter.
Spin up ...
scsi0 : Marvell SCSI to SATA adapter
scsi1 : Marvell SCSI to SATA adapter
Vendor: SAMSUNG Model: HD250HJ Rev: FH10
Type: Direct-Access ANSI SCSI revision: 03
SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3 sda4
Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0, type 0
physmap flash device: 800000 at ff800000
phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
0: offset=0x0,size=0x20000,blocks=64
cmdlinepart partition parsing not available
RedBoot partition parsing not available
Using physmap partition definition
Creating 6 MTD partitions on "phys_mapped_flash":
0x00780000-0x00800000 : "U-Boot"
0x00000000-0x00200000 : "Kernel"
0x00200000-0x00600000 : "RootFS1"
0x00600000-0x00700000 : "RootFS2"
0x00760000-0x00780000 : "U-Boot Config"
0x00700000-0x00760000 : "NAS Config"
ehci_platform ehci_platform.4523: EHCI Host Controller
ehci_platform ehci_platform.4523: new USB bus registered, assigned bus
number 1
ehci_platform ehci_platform.4523: irq 17, io mem 0x00000000
ehci_platform ehci_platform.4523: park 0
ehci_platform ehci_platform.4523: USB 0.0 initialized, EHCI 1.00,
driver 10 Dec 2004
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
ehci_platform ehci_platform.16781: EHCI Host Controller
ehci_platform ehci_platform.16781: new USB bus registered, assigned
bus number 2
ehci_platform ehci_platform.16781: irq 12, io mem 0x00000000
ehci_platform ehci_platform.16781: park 0
ehci_platform ehci_platform.16781: USB 0.0 initialized, EHCI 1.00,
driver 10 Dec 2004
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver
(PCI)
USB Universal Host Controller Interface driver v2.2
usb 2-1: new high speed USB device using ehci_platform and address 2
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
qh_schedule: frame=255, uframe=0, cmask=0x0, smask=0x1, period=256,
u_period=2048
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
NET: Registered protocol family 2
IP: routing cache hash table of 2048 buckets, 16Kbytes
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
NET: Registered protocol family 17
NET: Registered protocol family 5
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 104K
kjournald starting. Commit interval 5 seconds
EXT3-fs warning: maximal mount count reached, running e2fsck is
recommended
EXT3 FS on sda1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
recommended
EXT3 FS on sda4, internal journal
sysinfo: Module loaded.
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
create proc entry succeed!
fuse init (API version 7.8)
fuse distribution version: 2.7.3
eth0: mac address changed
recommended
Adding 530136k swap on /dev/sda2. Priority:-1 extents:1
EXT3 FS on sda3, internal journal
EXT3-fs: mounted filesystem with writeback data mode.
EXT3-fs: file extents enabled
scsi: unknown opcode 0x0c
eth0: link down
eth0: link up<5>, full duplex<5>, speed 1 Gbps<5>
rule type=0, num=0
Ensuite sur le QNAP TS-109 j'ai le message suivant quand je démarre
linknx :
[/] # linknx
linknx: error while loading shared libraries: libssl.so.0.9.8: cannot
open shared object file: No such file or directory
Une idée ?
Chrystof
Linknx sur un NAS QNAP. - par Chrystof - 19/06/2009, 13:19:10
Linknx sur un NAS QNAP. - par jef2000 - 20/06/2009, 08:53:47
Linknx sur un NAS QNAP. - par Chrystof - 21/06/2009, 16:42:20
Linknx sur un NAS QNAP. - par jef2000 - 21/06/2009, 22:35:21
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 06:40:06
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 08:19:36
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 08:51:29
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 15:05:04
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 18:02:03
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 19:43:39
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 21:04:41
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 21:56:03
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 22:57:46
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 12:53:40
Linknx sur un NAS QNAP. - par jef2000 - 23/06/2009, 15:19:20
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 20:01:51
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 20:08:56
Linknx sur un NAS QNAP. - par Vincent Aaron - 23/06/2009, 20:51:39
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 21:07:44
Linknx sur un NAS QNAP. - par Chrystof - 24/06/2009, 05:51:38
Linknx sur un NAS QNAP. - par jef2000 - 24/06/2009, 08:48:21
Linknx sur un NAS QNAP. - par Chrystof - 24/06/2009, 12:58:41
Linknx sur un NAS QNAP. - par jef2000 - 24/06/2009, 20:05:12
Linknx sur un NAS QNAP. - par Chrystof - 24/06/2009, 20:38:55
Linknx sur un NAS QNAP. - par jef2000 - 24/06/2009, 22:11:52
Linknx sur un NAS QNAP. - par Chrystof - 25/06/2009, 05:59:23
Linknx sur un NAS QNAP. - par Chrystof - 25/06/2009, 07:30:27
Linknx sur un NAS QNAP. - par Chrystof - 29/06/2009, 17:15:27
Linknx sur un NAS QNAP. - par jef2000 - 30/06/2009, 21:45:20
Linknx sur un NAS QNAP. - par Chrystof - 01/07/2009, 06:10:50
Linknx sur un NAS QNAP. - par jef2000 - 01/07/2009, 08:31:28
Linknx sur un NAS QNAP. - par Chrystof - 01/07/2009, 14:32:40
Linknx sur un NAS QNAP. - par jef2000 - 02/07/2009, 12:31:26
Linknx sur un NAS QNAP. - par Chrystof - 02/07/2009, 16:46:00
Linknx sur un NAS QNAP. - par Chrystof - 06/07/2009, 08:05:03
Linknx sur un NAS QNAP. - par jef2000 - 06/07/2009, 19:13:15
Linknx sur un NAS QNAP. - par seb@leon - 31/07/2009, 06:35:26
Linknx sur un NAS QNAP. - par Chrystof - 31/07/2009, 07:02:33
