Linknx sur un NAS QNAP.
#17
Ah voilà j'ai installé libcurl, j'avais oublier !!!
Ca fonctionne, ensin ca note :
Segmentation fault
Donc j'imagine que ca fonctionne.
Super merci beaucoup, reste juste à trouver comment starter eibd et
linknx automatiquement.
Merci encore.
Chrystof
On 23 juin, 21:01, Chrystof <i...@accessnight.ch> wrote:
> Salut,
> J'ai mon Ts-109 de QNAP, j'ai tout installé et voici ma config :
> [/] # dmesg
> 0 pages, LIFO batch:1
>   HighMem zone: 0 pages, LIFO batch:1
> Built 1 zonelists
> Kernel command line: console=ttyS0,115200n8 root=/dev/ram rw
> initrd=0x800000,0x3fffff
> PID hash table entries: 2048 (order: 11, 32768 bytes)
> Console: colour dummy device 80x30
> Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
> Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
> Memory: 128MB 128MB 0MB 0MB = 256MB total
> Memory: 251904KB available (2941K code, 447K data, 104K init)
> Calibrating delay loop... 332.59 BogoMIPS (lpj=1662976)
> Mount-cache hash table entries: 512
> CPU: Testing write buffer coherency: ok
> checking if image is initramfs...it isn't (no cpio magic); looks like
> an initrd
> Freeing initrd memory: 4095K
> NET: Registered protocol family 16
> CPU Interface
> SDRAM_CS0 ....base 00000000, size 128MB
> SDRAM_CS1 ....base 10000000, size 128MB
> SDRAM_CS2 ....disable
> SDRAM_CS3 ....disable
> PEX0_MEM ....base e0000000, size 128MB
> PEX0_IO ....base f2000000, size   1MB
> PCI0_MEM ....base e8000000, size 128MB
> PCI0_IO ....base f2100000, size   1MB
> INTER_REGS ....base f1000000, size   1MB
> DEVICE_CS0 ....no such
> DEVICE_CS1 ....base f4000000, size  16MB
> DEVICE_CS2 ....no such
> DEV_BOOCS ....base ff800000, size   8MB
> CRYPTO ENG ....base f0000000, size  64KB
>   Marvell Development Board (LSP Version 1.10.3_DB_NAS)-- RD-88F5182-
> NAS-2  Soc: 88F5182 A2
>  Detected Tclk 166666667 and SysClk 166666667
> Marvell USB EHCI Host controller #0: c0573560
> Marvell USB EHCI Host controller #1: c0573460
> mvPexTargetWinEnable: Win 1 should be in bar boundries
> mvPexInit: Can't enable window =1
> pci_init:Error calling mvPciIfInit for pciIf 0
> PCI: bus0: Fast back to back transfers enabled
> PCI: bus1: Fast back to back transfers enabled
> SCSI subsystem initialized
> usbcore: registered new driver usbfs
> usbcore: registered new driver hub
> QNAP RTC initializing....
> Initializing RTC is completed.
>  Detected Tclk 166666667, BASE_BAUD 10416666, Baud divisor 542
> qnap_pic_init: succeed to register misc device
> tsinfo: create proc systemp successfully
> Use the XOR engines (offloading) for enhancing the following
> functions:
>   o RAID 5 Xor calculation
>   o kernel memcpy
>   o kenrel memzero
>   o copy user to/from kernel buffers
> Number of XOR engines to use: 2
> cesadev_init(c0011b30)
> Fast Floating Point Emulator V0.9 © Peter Teichmann.
> inotify device minor=63
> VFS: Disk quotas dquot_6.5.1
> Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
> Installing knfsd (copyright © 1996 o...@monad.swb.de).
> Initializing Cryptographic API
> Serial: 8250/16550 driver $Revision: 1.1.1.1 $ 4 ports, IRQ sharing
> disabled
> ttyS0 at MMIO 0x0 (irq = 3) is a 16550A
> io scheduler noop registered
> io scheduler anticipatory registered
> io scheduler deadline registered
> io scheduler cfq registered
> RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
> loop: loaded (max 8 devices)
> Marvell Gigabit Ethernet Driver 'egiga':
>   o Ethernet descriptors in DRAM
>   o DRAM SW cache-coherency
>   o Checksum offload enabled
>   o Marvell ethtool proc enabled
>   o Loading network interface 'eth0'
> STRIP: Version 1.3A-STUART.CHESHIRE (unlimited channels)
> Intergrated Sata device found
>  Wait 15 seconds to initialize mvAdapter.
> Spin up ...
> scsi0 : Marvell SCSI to SATA adapter
> scsi1 : Marvell SCSI to SATA adapter
>   Vendor: SAMSUNG   Model: HD250HJ           Rev: FH10
>   Type:   Direct-Access                      ANSI SCSI revision: 03
> SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
> SCSI device sda: drive cache: write back
>  sda: sda1 sda2 sda3 sda4
> Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
> Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0,  type 0
> physmap flash device: 800000 at ff800000
> phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
>  Intel/Sharp Extended Query Table at 0x0031
> Using buffer write method
> cfi_cmdset_0001: Erase suspend on write enabled
> 0: offset=0x0,size=0x20000,blocks=64
> cmdlinepart partition parsing not available
> RedBoot partition parsing not available
> Using physmap partition definition
> Creating 6 MTD partitions on "phys_mapped_flash":
> 0x00780000-0x00800000 : "U-Boot"
> 0x00000000-0x00200000 : "Kernel"
> 0x00200000-0x00600000 : "RootFS1"
> 0x00600000-0x00700000 : "RootFS2"
> 0x00760000-0x00780000 : "U-Boot Config"
> 0x00700000-0x00760000 : "NAS Config"
> ehci_platform ehci_platform.4523: EHCI Host Controller
> ehci_platform ehci_platform.4523: new USB bus registered, assigned bus
> number 1
> ehci_platform ehci_platform.4523: irq 17, io mem 0x00000000
> ehci_platform ehci_platform.4523: park 0
> ehci_platform ehci_platform.4523: USB 0.0 initialized, EHCI 1.00,
> driver 10 Dec 2004
> hub 1-0:1.0: USB hub found
> hub 1-0:1.0: 1 port detected
> ehci_platform ehci_platform.16781: EHCI Host Controller
> ehci_platform ehci_platform.16781: new USB bus registered, assigned
> bus number 2
> ehci_platform ehci_platform.16781: irq 12, io mem 0x00000000
> ehci_platform ehci_platform.16781: park 0
> ehci_platform ehci_platform.16781: USB 0.0 initialized, EHCI 1.00,
> driver 10 Dec 2004
> hub 2-0:1.0: USB hub found
> hub 2-0:1.0: 1 port detected
> ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver
> (PCI)
> USB Universal Host Controller Interface driver v2.2
> usb 2-1: new high speed USB device using ehci_platform and address 2
> hub 2-1:1.0: USB hub found
> hub 2-1:1.0: 4 ports detected
> qh_schedule: frame=255, uframe=0, cmask=0x0, smask=0x1, period=256,
> u_period=2048
> usbcore: registered new driver usblp
> drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
> usbcore: registered new driver hiddev
> usbcore: registered new driver usbhid
> drivers/usb/input/hid-core.c: v2.01:USB HID core driver
> mice: PS/2 mouse device common for all mice
> NET: Registered protocol family 2
> IP: routing cache hash table of 2048 buckets, 16Kbytes
> TCP established hash table entries: 16384 (order: 5, 131072 bytes)
> TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
> TCP: Hash tables configured (established 16384 bind 16384)
> NET: Registered protocol family 17
> NET: Registered protocol family 5
> RAMDISK: Compressed image found at block 0
> VFS: Mounted root (ext2 filesystem).
> Freeing init memory: 104K
> kjournald starting.  Commit interval 5 seconds
> EXT3-fs warning: maximal mount count reached, running e2fsck is
> recommended
> EXT3 FS on sda1, internal journal
> EXT3-fs: mounted filesystem with ordered data mode.
> recommended
> EXT3 FS on sda4, internal journal
> sysinfo: Module loaded.
> Initializing USB Mass Storage driver...
> usbcore: registered new driver usb-storage
> USB Mass Storage support registered.
> create proc entry succeed!
> fuse init (API version 7.8)
> fuse distribution version: 2.7.3
> eth0: mac address changed
> recommended
> Adding 530136k swap on /dev/sda2.  Priority:-1 extents:1
> EXT3 FS on sda3, internal journal
> EXT3-fs: mounted filesystem with writeback data mode.
> EXT3-fs: file extents enabled
> scsi: unknown opcode 0x0c
> eth0: link down
> eth0: link up<5>, full duplex<5>, speed 1 Gbps<5>
> rule type=0, num=0
> Ensuite sur le QNAP TS-109 j'ai le message suivant quand je démarre
> linknx :
> [/] # linknx
> linknx: error while loading shared libraries: libssl.so.0.9.8: cannot
> open shared object file: No such file or directory
> Une idée ?
> Chrystof
Linknx sur un NAS QNAP. - par Chrystof - 19/06/2009, 13:19:10
Linknx sur un NAS QNAP. - par jef2000 - 20/06/2009, 08:53:47
Linknx sur un NAS QNAP. - par Chrystof - 21/06/2009, 16:42:20
Linknx sur un NAS QNAP. - par jef2000 - 21/06/2009, 22:35:21
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 06:40:06
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 08:19:36
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 08:51:29
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 15:05:04
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 18:02:03
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 19:43:39
Linknx sur un NAS QNAP. - par Chrystof - 22/06/2009, 21:04:41
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 21:56:03
Linknx sur un NAS QNAP. - par jef2000 - 22/06/2009, 22:57:46
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 12:53:40
Linknx sur un NAS QNAP. - par jef2000 - 23/06/2009, 15:19:20
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 20:01:51
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 20:08:56
Linknx sur un NAS QNAP. - par Vincent Aaron - 23/06/2009, 20:51:39
Linknx sur un NAS QNAP. - par Chrystof - 23/06/2009, 21:07:44
Linknx sur un NAS QNAP. - par Chrystof - 24/06/2009, 05:51:38
Linknx sur un NAS QNAP. - par jef2000 - 24/06/2009, 08:48:21
Linknx sur un NAS QNAP. - par Chrystof - 24/06/2009, 12:58:41
Linknx sur un NAS QNAP. - par jef2000 - 24/06/2009, 20:05:12
Linknx sur un NAS QNAP. - par Chrystof - 24/06/2009, 20:38:55
Linknx sur un NAS QNAP. - par jef2000 - 24/06/2009, 22:11:52
Linknx sur un NAS QNAP. - par Chrystof - 25/06/2009, 05:59:23
Linknx sur un NAS QNAP. - par Chrystof - 25/06/2009, 07:30:27
Linknx sur un NAS QNAP. - par Chrystof - 29/06/2009, 17:15:27
Linknx sur un NAS QNAP. - par jef2000 - 30/06/2009, 21:45:20
Linknx sur un NAS QNAP. - par Chrystof - 01/07/2009, 06:10:50
Linknx sur un NAS QNAP. - par jef2000 - 01/07/2009, 08:31:28
Linknx sur un NAS QNAP. - par Chrystof - 01/07/2009, 14:32:40
Linknx sur un NAS QNAP. - par jef2000 - 02/07/2009, 12:31:26
Linknx sur un NAS QNAP. - par Chrystof - 02/07/2009, 16:46:00
Linknx sur un NAS QNAP. - par Chrystof - 06/07/2009, 08:05:03
Linknx sur un NAS QNAP. - par jef2000 - 06/07/2009, 19:13:15
Linknx sur un NAS QNAP. - par seb@leon - 31/07/2009, 06:35:26
Linknx sur un NAS QNAP. - par Chrystof - 31/07/2009, 07:02:33
