probleme d'ajout ABB UD/S xxxx
Sad
j'ai un probleme avec ETS (?) quand j'essaye d'ajouter un dimmer ABB UD/S 6.315.1 (ou 6197-14 500, c'est la meme chose). ETS me retourne l'erreur suivante et refuse de rajouter le device.
Une idee?
Knx.Ets.UI.UIFrameworkException: Add device '6197/xx-500 Universal Dimming Actuator, MDRC' to 'armoire principale' failed.
Operation partially succeeded. The following devices have been removed due to product specific software issues:
1.0.7 6197/xx-500 Universal Dimming Actuator, MDRC (ABB(6197/xx-500 Universal Dimming Actuator, MDRC)): System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {F7C734DF-C8BC-4A63-A2A0-C582E6806C0A} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
at a1q.a(Exception A_0)
at a1q.a(DomObject A_0)
at a1q.g(a74 A_0)
at aaa.a(DomObject A_0)
at bl3.a(DomObject A_0, n3 A_1, List`1 A_2, List`1 A_3) ---> Knx.Ets.UI.UIFrameworkException: Operation partially succeeded. The following devices have been removed due to product specific software issues:
at a1q.g(a74 A_0)
at Knx.Ets.UI.Deagle.Operations.CheckOperation(bfc errors, Boolean throwException, er operation)
at Knx.Ets.UI.Deagle.Operations.AddDevice(IProject project, IUIObject catalogItemOrTemplate, IUIObject projectLineBuildingPartOrTrade, UInt16 count, AddressAllocationStrategy strategy, UInt16 startAddress)
--- End of inner exception stack trace ---
at Knx.Ets.UserControls.ViewHandler.MetaOperations.Add(Type typeToAdd, Object destination, OperationArgs a, Boolean checkOnly)
at Knx.Ets.UserControls.ViewHandler.MetaOperations.DoDrop(OperationData data, OperationArgs a, DragDropEffects dragDropEffect)
at Knx.Ets.UserControls.ViewHandler.UIViewHandlerDragDrop.DropData.DoDrop(IDataObject dataObject)
merci.Angry
est ce que quelqu'un pourrait charger ce composant UD/S 6.315.1 (ou 6197-14 500) dans ETS4 (.07) , le rajouter a un projet et me dire s'il rencontre le meme probleme?
le fichier database est: AP_UNIVERSALDIMMAKTOR_6197_12 6197_13 6197_14 6197_15_ABB_PT2_V13.VD5
merci.
BONJOUR TILI77
J'ai le même souci que vous.
Avez-vous eu la solution depuis ?
J'ai écrit ce jour à ABB j'attend un retour de leur pars.
Cordialement kerselec
Bonjour TIJI77
J'ai la solution pour l'ajout du 6197/14-101-500
Il faut installé powertool pour avoir les paramètrages du produit.
Je viens de l'installer et c'est concluant
Cordialement Kerselec
Non je n'avait pas trouvé de solution. Est ce que powertools permet de gerer les parametres a partir D'ets?
Bonjour TIJI77
Vous ajoutez le participant comme d'habitude,
ensuite dans la fenetre de parametrage il faut cliqué sur le lien qui apparait à la place des parametres.
Vous vous retrouvez sur powertool, vous pouvez modifier les parametres ensuite vous quittez powertool et la fenetre ets reviens en quittant.
Ensuite vous avez les groups objects correcpondant comme avec les autres participants.
En espèrant vous avoir bien répondu.
Cordialement Kerselec.
