j'ai un probleme avec ETS (?) quand j'essaye d'ajouter un dimmer ABB UD/S 6.315.1 (ou 6197-14 500, c'est la meme chose). ETS me retourne l'erreur suivante et refuse de rajouter le device.
Une idee?
Knx.Ets.UI.UIFrameworkException: Add device '6197/xx-500 Universal Dimming Actuator, MDRC' to 'armoire principale' failed.
Operation partially succeeded. The following devices have been removed due to product specific software issues:
1.0.7 6197/xx-500 Universal Dimming Actuator, MDRC (ABB(6197/xx-500 Universal Dimming Actuator, MDRC)): System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {F7C734DF-C8BC-4A63-A2A0-C582E6806C0A} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
at a1q.a(Exception A_0)
at a1q.a(DomObject A_0)
at a1q.g(a74 A_0)
at aaa.a(DomObject A_0)
at bl3.a(DomObject A_0, n3 A_1, List`1 A_2, List`1 A_3) ---> Knx.Ets.UI.UIFrameworkException: Operation partially succeeded. The following devices have been removed due to product specific software issues:
at a1q.g(a74 A_0)
at Knx.Ets.UI.Deagle.Operations.CheckOperation(bfc errors, Boolean throwException, er operation)
at Knx.Ets.UI.Deagle.Operations.AddDevice(IProject project, IUIObject catalogItemOrTemplate, IUIObject projectLineBuildingPartOrTrade, UInt16 count, AddressAllocationStrategy strategy, UInt16 startAddress)
--- End of inner exception stack trace ---
at Knx.Ets.UserControls.ViewHandler.MetaOperations.Add(Type typeToAdd, Object destination, OperationArgs a, Boolean checkOnly)
at Knx.Ets.UserControls.ViewHandler.MetaOperations.DoDrop(OperationData data, OperationArgs a, DragDropEffects dragDropEffect)
at Knx.Ets.UserControls.ViewHandler.UIViewHandlerDragDrop.DropData.DoDrop(IDataObject dataObject)
merci.
Une idee?
at a1q.g(a74 A_0)
at a1q.g(a74 A_0)
merci.
![Angry Angry](https://www.knx-fr.com/images/smilies/angry.gif)
