A vendre: Merten 6750 01
Acheté par erreur:
Merten 6750 01 Panel control REG-K/12x24
Prix: 60€ ou meilleure offre
Prière de "répondre à l'auteur"
-----------------extrait de la doc ---------------------------------
The panel control REG-K/12x24 has 12 independent channels
and is used for switching incandescent lamps in display
panels. Ohmic, inductive and capacitive loads can also be controlled
(the control of relays e.g. art. no. 682729 and the control
of a PLC or logic modules is possible). The outputs are
short-circuit-proof. In addition to the supply from the bus, the
device requires an external auxiliary supply for operation. The
device can be operated within a very wide voltage range. Depending
on the load, operation between 12 and 36 V is possible.
It is therefore possible e.g. for both 12 V and 24 V lamps
(loads) to be connected. A check of the connected incandescent
lamps/loads can be carried out with a push-button on the
lamp test inpu
Changement de prix: 35€ plus port
