Amélioration/ajouts avec la norme KNX: version 2.1
Publication reçu par l'association KNX :
4 années de développements depuis la v2.0...
- KNX Data Security and Security at KNXnet/IP level;
- New Profiles for the true support of Radio Frequency in ETS
- Making KNX RF more robust and future proof via the Multi extension
- New standardized KNX Datapoint Types for new application domains (e.g. DPT Prioritized Scene Control for load management)
- Flexible E-Mode Channels – an innovative way of allowing to extend the current E-Mode Channels with additional group objects and parameters;
- Functional Block Profiles, introducing the possibility for manufacturers to choose between different flavors of common application descriptions;
- Master Reset and Configuration Signature, allowing manufacturers to reset their devices to predefined factory states respectively allowing a counter to keep track of changes in device settings;
- Bringing existing mask versions to the IP level (e.g. Mask 57B0h)
- A completely overhauled Coupler 2.0 model, of which forthcoming KNX Tp1/RF Media couplers will be the first realizations;
Texte intégral sur : https://plus.google.com/1063646755569088...bjAXUrqLJP
