Merten MTN680329 and Somfy animeo KNX 4 AC Motor Controller WM 220-240V V2.0
I have installed ETS5.5.2 on Windows 10 with 6GB RAM and high end laptop.
I have 10 installed devices, of Which I have full access using MTN680329 IP router but I can not communicate with Somfy controller using the same IP router.
Firstly I have contacted KNX Org and then Somfy to realize, that the problem is only with the IP router. The communication Could be established with USB interface (test Conducted at Somfy).
I can download the physical address on Somfy controller only once after reset. After that no communication "device info: failed The device does not respond in appropriate time Connection: KNX / IP router REG-K (192.168.1.70:3671) Start: 10:45:05 AM End: 10:45:30 AM"
If anyone have an idea I appreciate. Thank you.
