[eibd] Routing server
J'ai une question concernant le mode 'Routing Server' de eibd. Dans la doc, il est noté :
Citation :Additionally, eibd can acts as limited EIBnet/IP Tunneling and/or Routing Server. The limitation is, that only one KNX address can be used as source address of EIBnet/IP Clients. This address is shared between multiple possible routing or tunneling connections. To the EIBnet/IP client, the address 0.0.0 is used, to the EIB/KNX bus the address of the interface device is used. eibd maps between these addresses (like NAT for TCP/IP).
Quelqu'un comprend-il ce que ça signifie ?
Pour info, avec un bête socket de type multicast bindé à l'adresse ("224.0.23.12", 3671), l'activité sur le bus est bien reçue, via une trame cEMILData. Par exemple, lorsque j'allume une lumière, je reçois (log du framework) :
Code :
UDP receiver::UDPTransceiver._receiverLoop(): inFrame='\x06\x10\x050\x00\x11)\x00\xbc\xd0\x11\x1e1\x01\x01\x00\x81'
UDP receiver::UDPTransceiver._receiverLoop(): KNXnetIP header=<KNXnetIPHeader(service='routing.ind', totalSize=17)>
UDP receiver::UDPTransceiver._receiverLoop(): frame=bytearray(b')\x00\xbc\xd0\x11\x1e1\x01\x01\x00\x81')
UDP receiver::UDPTransceiver._receiverLoop(): cEMI=<CEMILData(mc=0x29, priority=low, src=1.1.30, dest=6/1/1, npdu=bytearray(b'\x01\x00\x81'))>
UDP receiver::L_DataService.putInFrame(): cEMI=<CEMILData(mc=0x29, priority=low, src=1.1.30, dest=6/1/1, npdu=bytearray(b'\x01\x00\x81'))>
LinkLayer::L_DataService.run(): cEMI=<CEMILData(mc=0x29, priority=low, src=1.1.30, dest=6/1/1, npdu=bytearray(b'\x01\x00\x81'))>
LinkLayer::N_GroupDataService.dataInd(): cEMI=<CEMILData(mc=0x29, priority=<Priority('low')>, src=<IndividualAddress('1.1.30')>, dest=<GroupAddress('6/1/1')>, npdu=bytearray(b'\x01\x00\x81'))>
LinkLayer::T_GroupDataService.groupDataInd(): src=1.1.30, gad=6/1/1, priority=low, tPDU=bytearray(b'\x00\x81')
LinkLayer::A_GroupDataService.groupDataInd(): src=1.1.30, gad=6/1/1, priority=low, aPDU=bytearray(b'\x00\x81')
LinkLayer::Group.groupValueWriteInd(): src=1.1.30, gad=6/1/1, priority=low, data=bytearray(b'\x01')
LinkLayer::GroupObject.onWrite(): src=1.1.30, data=bytearray(b'\x01')
LinkLayer::FuntionalBlock.notify(): dp=state, oldValue=Off, newValue=On
LinkLayer::Notifier.datapointNotify(): dp=state, oldValue='Off', newValue='On'
LinkLayer::Notifier.datapointNotify(): trigger method stateChanged() of <LightTimerFB('light_timer')>
LinkLayer::LightTimerFB.stateChanged(): event={'oldValue': 'Off', 'newValue': 'On', 'dp': 'state', 'event': 'datapoint'}
On voit bien que l'adresse source du device est transmise. Mais si j'essaye d'envoyer quelque chose, en construisant une trame cEMI du genre :
Code :
Thread-15::A_GroupDataService.groupValueWriteReq(): gad=6/0/1, priority=low, data=bytearray(b'\x00'), size=0
Thread-15::T_GroupDataService.groupDataReq(): gad=6/0/1, priority=low, tSDU=bytearray(b'\x00\x80')
Thread-15::N_GroupDataService.groupDataReq(): gad=6/0/1, priority=low, nSDU=bytearray(b'\x00\x80')
Thread-15::L_DataService.dataReq(): cEMI=<CEMILData(mc=0x11, priority=low, src=0.0.0, dest=6/0/1, npdu=bytearray(b'\x01\x00\x80'))>
UDP transmitter::UDPTransceiver._transmitterLoop(): transmission=<Transmission(payload=<CEMILDataFrame(mc=0x11, addIL=0, ctrl1=0xbc, ctrl2=0xe0, src=0x0, dest=0x3001)>, waitConfirm=True, result=0)>
UDP transmitter::UDPTransceiver._transmitterLoop(): frame= bytearray(b'\x06\x10\x050\x00\x11\x11\x00\xbc\xe0\x00\x000\x01\x01\x00\x80')
UDP transmitter::UDPTransceiver._transmitterLoop(): transmission=<Transmission(payload=<CEMILDataFrame(mc=0x11, addIL=0, ctrl1=0xbc, ctrl2=0xe0, src=0x0, dest=0x3001)>, waitConfirm=False, result=0)>
Rien n'est transmis au bus (eibd lancé en vbusmonitor2 ne sort rien).
Une idée de ce qui merdoie ? J'ai essayé d'autres adresses source, sans succès. Mais, comme dit, la phrase plus haut n'est pas du tout clair quant à la restriction sur ces adresses sources...
Pour info, eibd et lancé avec la commande suivante :
$ eibd --daemon=/var/log/eibd.log --pid-file=/var/log/eibd.pid --eibaddr=0.0.1 -D -S --Tunnelling --Routing --listen-tcp=6720 ipt:192.168.0.148:3671
Merci d'avance pour vos lumières.
Frédéric
Bon, j'ai trouvé le problème. Le Message Code à utiliser pour la requète est MC_LDATA_IND, au lieu de MC_LDATA_REQ. Là, je ne pige absolument pas pourquoi, mais le fait est que ça fonctionne...
Frédéric
