11/12/2009, 10:04:06
Ragerdez sur les sites rainbird.fr, hunter.fr, toro.fr, irritrol.com
HUNTER IBV MODELS exemple :
IBV-101G – 1" brass globe valve
DIMENSIONS
• IBV-101G 4 1/2" H x 3 3/4" L x 5 1/4" W (11.4 cm H x 9.3 cm L x 13.1
cm W)
OPERATING SPECIFICATIONS
• Flow: 0.06 to 68.10 m3/hr; 0.9 to 1,135.5 l/min
• Pressure: 20 to 220 PSI (1.4 to 15.0 bars; 138 to 1500 kPa)
• Temperature: up to 150˚F (66˚C)
• Heavy-duty solenoid: 24VAC, 370mA inrush current, 190mA holding
current, 60 cycles; 475mA inrush current, 230mA holding current, 50
cycles
• Accu-Set: 20 PSI (1.4 bars, 138 kPa) minimum operating pressure.
Regulates from 20 to 100 PSI (1.4 to 7.0 bars; 138 to 689 kPa)
OPTIONS AVAILABLE
• Accu-Set pressure regulator
Les prix de vannes : entre 26 et ... € - il me semble d'être une
solution SIMPLE et PAS trés ONÉREUSE.
DIMENSIONS
cm W)
cycles
OPTIONS AVAILABLE
