09/03/2011, 21:26:29
On 9 mar, 06:56, DaGGeR <dagger...@hotmail.com> wrote:
> Une fois que tu es dans le répertoire /tmp/config
> ( mount /dev/mtdblock5 -t ext2 /tmp/config et après cd /tmp/config )
> il faut taper la commande : vi autorun.sh Ce fichier n'existe
> pas, c'est toi qui le crée
Ah ! OK
Au démarrage de eibd, j'ai un message d'erreur
eibd: error while loading shared libraries: libpthsem.so.20: cannot
open shared object file: No such file or directory
Pourtant l'install de pthsem n'a pas donné d'erreur
[/] # ipkg -V 2 install libpth
pkg_info_preinstall_check: updating arch priority for each package
pkg_info_preinstall_check: update file owner list
Installing libpth (2.0.7-2) to root...
Downloading http://ipkg.nslu2-linux.org/feeds/optwar...-2_arm.ipk
Running script /opt/ipkg-nWrXTf/libpth-2HmsYa/preinst
installing maintainer scripts
installing data files
extracting data files to /
creating libpth.list file
creating //opt/lib/ipkg/info/libpth.list file for pkg libpth
resolving conf files
cleanup temp files
cleanup_temporary_files: pkg=libpth local_filename=/opt/ipkg-nWrXTf/
libpth_2.0.7-2_arm.ipk tmp_dir=/opt/ipkg-nWrXTf
Done.
Configuring unpacked packages
Configuring libpth
Running script //opt/lib/ipkg/info/libpth.postinst
writing status file
pkg_write_changed_filelists: saving changed filelists
Successfully terminated.
Ah ! OK
cleanup temp files
Done.
Configuring libpth
writing status file
