bon, quand je fais un "service eibd status" avec l'interface IP/KNX débranchée, ça me sort ça...
● eibd.service - LSB: eibd initscript
Loaded: loaded (/etc/init.d/eibd; bad; vendor preset: enabled)
Active: active (exited) since mer 2017-01-18 07:36:18 CET; 6min ago
Docs: man ystemd-sysv-generator(8)
Process: 1108 ExecStart=/etc/init.d/eibd start (code=exited, status=0/SUCCESS)
jan 18 07:36:07 knx eibd[1108]: Segmentation fault (core dumped)
jan 18 07:36:07 knx eibd[1108]: find usb :
jan 18 07:36:07 knx eibd[1108]: -ne *** eibd: Autodetecting Interface FT1.2 /dev/ttyS0 .
jan 18 07:36:07 knx eibd[1108]: /etc/init.d/eibd: 78: /etc/init.d/eibd: setserial: not found
jan 18 07:36:07 knx eibd[1108]: -ne *** eibd: Autodetecting Interface IP.
jan 18 07:36:18 knx eibd[1108]: eth0: erreur lors de la recherche d'infos sur l'interface: Périphérique non trouvé
jan 18 07:36:18 knx eibd[1108]: -ne *** eibd: Autodetecting Interface FT1.2 /dev/ttyS1 .
jan 18 07:36:18 knx eibd[1108]: /etc/init.d/eibd: 129: /etc/init.d/eibd: setserial: not found
jan 18 07:36:18 knx eibd[1108]: -e *** eibd: Autodetect failed - exiting !
jan 18 07:36:18 knx systemd[1]: Started LSB: eibd initscript.
si je connecte l'interface IP, que je relance le service alors le status sort ça
Active: failed (Result: exit-code) since mer 2017-01-18 07:54:10 CET; 1min 53s ago
Process: 3540 ExecStop=/etc/init.d/eibd stop (code=exited, status=0/SUCCESS)
Process: 3559 ExecStart=/etc/init.d/eibd start (code=exited, status=1/FAILURE)
jan 18 07:54:10 knx eibd[3559]: eth0: erreur lors de la recherche d'infos sur l'interface: Périphérique non trouvé
jan 18 07:54:10 knx eibd[3559]: -e Found KNXnet/IP Router 00-0E-8C-01-4A-F2 on 192.168.1.6 with 0.0.0.0
jan 18 07:54:10 knx eibd[3559]: *** Starting EIB/KNX daemon: eibd using ip:192.168.1.6:3671 and args : /usr/local/bin/eibd -
jan 18 07:54:10 knx eibd[3559]: /usr/local/bin/eibd: invalid option -- 'D'
jan 18 07:54:10 knx eibd[3559]: Try `eibd --help' or `eibd --usage' for more information.
jan 18 07:54:10 knx eibd[3559]: ...fail!
jan 18 07:54:10 knx systemd[1]: eibd.service: Control process exited, code=exited status=1
jan 18 07:54:10 knx systemd[1]: Failed to start LSB: eibd initscript.
jan 18 07:54:10 knx systemd[1]: eibd.service: Unit entered failed state.
jan 18 07:54:10 knx systemd[1]: eibd.service: Failed with result 'exit-code'.
Par contre dans ce cas, eibd est actif sur la page de knxweb2... mais dans aucuns des cas, le bouton "Done" n'est clicquable....
Docs: man
ystemd-sysv-generator(8)Process: 1108 ExecStart=/etc/init.d/eibd start (code=exited, status=0/SUCCESS)
Docs: man
ystemd-sysv-generator(8)Process: 3540 ExecStop=/etc/init.d/eibd stop (code=exited, status=0/SUCCESS)
