18/01/2017, 09:04:13
		pour le service linknx, j'ai ça
● linknx.service - LSB: linknx initscript
Loaded: loaded (/etc/init.d/linknx; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since mer 2017-01-18 08:58:40 CET; 1min 39s ago
Docs: man ystemd-sysv-generator(8)
Process: 1877 ExecStart=/etc/init.d/linknx start (code=exited, status=1/FAILURE)
CGroup: /system.slice/linknx.service
└─1950 /usr/local/bin/linknx --config=/var/www/html/knxweb2/linknx.xml -p/var/run/linknx.pid -d/var/log/linknx.log -w
jan 18 08:58:37 knx systemd[1]: Starting LSB: linknx initscript...
jan 18 08:58:38 knx linknx[1877]: *** Starting service: linknx using /usr/local/bin/linknx and args : --config=/var/www/html/knxweb2/linknx.xml -p/var/run/linknx.pid -d/
jan 18 08:58:40 knx systemd[1]: linknx.service: Control process exited, code=exited status=1
jan 18 08:58:40 knx systemd[1]: Failed to start LSB: linknx initscript.
jan 18 08:58:40 knx systemd[1]: linknx.service: Unit entered failed state.
jan 18 08:58:40 knx systemd[1]: linknx.service: Failed with result 'exit-code'.
alors que sur la page knxweb2 il est OK...
Donc si je résume....
service eibd en route mais pas OK
service linknx pas en route mais OK
il y aurais pas comme une merde quelque part.... ?
Docs: man
ystemd-sysv-generator(8)Process: 1877 ExecStart=/etc/init.d/linknx start (code=exited, status=1/FAILURE)
