20/01/2017, 08:16:25
Bon.... ce n'est pas de la mauvaise volonté hein :-D lol
Voilà, mise à jour comme dis plus haut.... pareil :-(.
Je joint la nouvelle capture...
Donc pareil que avant, DONE grisé, eibd pas ok et linknx ok.... sauf que....
eibd.service - LSB: eibd initscript
Loaded: loaded (/etc/init.d/eibd; bad; vendor preset: enabled)
Active: active (exited) since ven 2017-01-20 08:08:02 CET; 10s ago
Docs: man
ystemd-sysv-generator(8)
Process: 2472 ExecStop=/etc/init.d/eibd stop (code=exited, status=0/SUCCESS)
Process: 2490 ExecStart=/etc/init.d/eibd start (code=exited, status=0/SUCCESS)
jan 20 08:07:50 knx eibd[2490]: Segmentation fault (core dumped)
jan 20 08:07:50 knx eibd[2490]: find usb :
jan 20 08:07:50 knx eibd[2490]: -ne *** eibd: Autodetecting Interface FT1.2 /dev/ttyS0 .
jan 20 08:07:50 knx eibd[2490]: /etc/init.d/eibd: 78: /etc/init.d/eibd: setserial: not found
jan 20 08:07:50 knx eibd[2490]: -ne *** eibd: Autodetecting Interface IP.
jan 20 08:08:00 knx eibd[2490]: eth0: erreur lors de la recherche d'infos sur l'interface: Périphérique non trouvé
jan 20 08:08:00 knx eibd[2490]: -e Found KNXnet/IP Router 00-0E-8C-01-4A-F2 on 192.168.1.6 with 0.0.0.0
jan 20 08:08:00 knx eibd[2490]: *** Starting EIB/KNX daemon: eibd using ip:192.168.1.6:3671 and args : /usr/local/bin/eibd --daemon=/tmp/eibd.log --eibaddr=1.1.100 -c -i
jan 20 08:08:02 knx eibd[2490]: ...done.
jan 20 08:08:02 knx systemd[1]: Started LSB: eibd initscript.
linknx.service - LSB: linknx initscript
Loaded: loaded (/etc/init.d/linknx; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since ven 2017-01-20 08:09:05 CET; 10s ago
Docs: man
Process: 3025 ExecStart=/etc/init.d/linknx start (code=exited, status=1/FAILURE)
CGroup: /system.slice/linknx.service
└─1369 /usr/local/bin/linknx --config=/var/www/html/knxweb2/linknx.xml -p/var/run/linknx.pid -d/var/log/linknx.log -w
jan 20 08:09:05 knx systemd[1]: Starting LSB: linknx initscript...
jan 20 08:09:05 knx linknx[3025]: *** Starting service: linknx using /usr/local/bin/linknx and args : --config=/var/www/html/knxweb2/linknx.xml -p/var/run/linknx.pid -d/
jan 20 08:09:05 knx systemd[1]: linknx.service: Control process exited, code=exited status=1
jan 20 08:09:05 knx systemd[1]: Failed to start LSB: linknx initscript.
jan 20 08:09:05 knx systemd[1]: linknx.service: Unit entered failed state.
jan 20 08:09:05 knx systemd[1]: linknx.service: Failed with result 'exit-code'.
Si je conclu bien de ça.... eibd est ok et linknx est HS....ça me perturbe un peu :-D lol
Docs: man
ystemd-sysv-generator(8)Process: 2472 ExecStop=/etc/init.d/eibd stop (code=exited, status=0/SUCCESS)
Docs: man
ystemd-sysv-generator(8)Process: 3025 ExecStart=/etc/init.d/linknx start (code=exited, status=1/FAILURE)
