Salut
Oui pour l'IP je vais surement faire comme toi directement depuis la box. Mais bon j'aurai aimé savoir comment faire ;-) donc si quelqu'un peut m'aiguiller.
Par contre pour le password je pige pas le problème.... Car après reboot je garde ma config....sauf ces p.... de passwords mais aussi l'adresse http://openhabianpi:8080 qui n'est pas accessible... alors qu'en entrant l'IP cela fonctionne. strange.
Mon log de first boot
Code :
2018-03-13_22:53:42_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:42_UTC [openHABian] Storing configuration... OK
2018-03-13_22:53:42_UTC [openHABian] Changing default username and password... OK
2018-12-25_20:38:39_UTC [openHABian] Setting up Ethernet connection... OK
2018-12-25_20:38:39_UTC [openHABian] Ensuring network connectivity... OK
2018-12-25_20:38:40_UTC [openHABian] Waiting for dpkg/apt to get ready... OK
2018-12-25_20:38:58_UTC [openHABian] Updating repositories and upgrading installed packages... OK
2018-12-25_20:43:24_UTC [openHABian] Installing git package... OK
2018-12-25_20:43:50_UTC [openHABian] Cloning myself... OK
2018-12-25_20:43:52_UTC [openHABian] Executing 'openhabian-setup.sh unattended'...
2018-12-25_20:43:52_UTC [openHABian] Checking for root privileges... OK
2018-12-25_20:43:52_UTC [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2018-12-25_20:43:52_UTC [openHABian] Setting timezone based on IP geolocation... OK (Europe/Paris)
2018-12-25_21:44:55_CET [openHABian] Setting locale based on openhabian.conf... OK
2018-12-25_21:45:19_CET [openHABian] Setting hostname of the base system... OK
2018-12-25_21:45:19_CET [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2018-12-25_21:45:19_CET [openHABian] Enabling Audio output... OK
2018-12-25_21:45:19_CET [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2018-12-25_21:45:59_CET [openHABian] Installing additional needed packages... OK
2018-12-25_21:46:10_CET [openHABian] Installing additional bluetooth packages... OK
2018-12-25_21:46:15_CET [openHABian] Adding slightly tuned bash config files to system... OK
2018-12-25_21:46:15_CET [openHABian] Adding slightly tuned vim config file to system... OK
2018-12-25_21:46:15_CET [openHABian] Downloading and setting up FireMotD... OK
2018-12-25_21:46:33_CET [openHABian] Installing Zulu Embedded OpenJDK... OK
2018-12-25_21:48:07_CET [openHABian] Installing or upgrading to latest openHAB release (stable)... OK
2018-12-25_21:48:36_CET [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... OK
2018-12-25_21:48:37_CET [openHABian] Adding openHAB syntax to vim editor... OK
2018-12-25_21:48:37_CET [openHABian] Adding openHAB syntax to nano editor... OK
2018-12-25_21:48:38_CET [openHABian] Adding openHAB scheme to multitail... OK
2018-12-25_21:48:38_CET [openHABian] Preparing openHAB folder mounts under /srv/... OK
2018-12-25_21:48:38_CET [openHABian] Applying file permissions recommendations... OK
2018-12-25_21:48:39_CET [openHABian] Applying miscellaneous system settings... OK
2018-12-25_21:48:39_CET [openHABian] Setting up Samba network shares... OK
2018-12-25_21:49:15_CET [openHABian] Installing Node.js (prerequisite for other packages)... OK
2018-12-25_21:49:44_CET [openHABian] Installing the openHAB Log Viewer (frontail)... OK
2018-12-25_21:50:13_CET [openHABian] Adding an openHAB dashboard tile for 'frontail'... OK
2018-12-25_21:50:13_CET [openHABian] Execution of 'openhabian-setup.sh unattended' completed.
2018-12-25_21:50:13_CET [openHABian] Waiting for openHAB to become ready... OK
2018-12-25_21:50:48_CET [openHABian] Visit the openHAB dashboard now: http://openHABianPi:8080
2018-12-25_21:50:48_CET [openHABian] To gain access to a console, simply reconnect.
2018-12-25_21:50:48_CET [openHABian] First time setup successfully finished.
