18/05/2020, 17:10:33
(18/05/2020, 06:39:10)filou59 a écrit : -Pour l'accès au log, j'en avais parlé ici : http://www.knx-fr.com/showthread.php?tid...9#pid32239
-Pour l'utilisation du script, un exemple ici : http://www.knx-fr.com/showthread.php?tid...9#pid43499
Tof et Kev vous avez résolu vos problèmes ?
Je viens d'avoir accès au log voici la copie (j'ai pas réussi a rentré via putty avec le mot de passe et username habopen) :
openhab> ./things2item.sh KNX.things
Command not found: ./things2item.sh
openhab> log:tail
16:57:22.393 [INFO ] [.ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
16:57:22.440 [INFO ] [bpanel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
16:57:22.471 [INFO ] [.openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
16:57:22.534 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:device:5f1968dd' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
16:57:22.534 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:ip:171ff328bd7' changed from UNINITIALIZED to INITIALIZING
16:57:22.549 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:ip:171ff328bd7' changed from INITIALIZING to UNKNOWN16:57:22.549 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:device:5f1968dd' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
16:57:22.549 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:device:5f1968dd' changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE)
16:57:22.596 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:account:6ca89a89' changed from UNINITIALIZED to INITIALIZING
16:57:22.659 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:account:6ca89a89' changed from INITIALIZING to OFFLINE (CONFIGURATION_PENDING): Wait for login
16:57:22.659 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:account:6ca89a89' changed from OFFLINE (CONFIGURATION_PENDING): Wait for login to OFFLINE (CONFIGURATION_PENDING): Please login in through web site: http(s)://<YOUROPENHAB>:<YOURPORT>/amazonechocontrol/6ca89a89
16:57:22.659 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:echo:51bd5a50' changed from UNINITIALIZED to INITIALIZING
16:57:22.659 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'amazonechocontrol:echo:51bd5a50' changed from INITIALIZING to UNKNOWN
16:57:22.674 [INFO ] [e.googletts.internal.GoogleTTSService] - Using cache folder C:\openHAB2\userdata\cache\org.openhab.voice.googletts
16:57:22.690 [ERROR] [e.googletts.internal.GoogleTTSService] - Missing service account key configuration to access Google Cloud TTS API.
16:57:23.596 [INFO ] [.io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 4813291e-3f4e-45ee-a2ff-b42c064e9b70, base URL = http://localhost:8080)
16:58:02.596 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:ip:171ff328bd7' changed from UNKNOWN to ONLINE
16:58:02.596 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:device:5f1968dd' changed from OFFLINE (BRIDGE_OFFLINE) to UNKNOWN
16:58:04.760 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'knx:device:5f1968dd' changed from UNKNOWN to ONLINE
17:02:23.566 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:23.719 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:23.882 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:24.051 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:24.220 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:24.383 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:24.589 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:24.737 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:24.922 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:25.084 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:25.251 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:25.423 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:25.602 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:25.786 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:25.939 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:26.109 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:26.287 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:26.456 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:26.610 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:26.772 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:26.941 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:27.110 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:27.273 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:27.442 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:27.611 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:27.774 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:27.974 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:28.128 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:28.290 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:28.460 [WARN ] [calimero.mgmt.MC 192.168.50.230:3671 ] - problem reading property (response 43 d6 00 4e 00 01): property access OI 0 PID 78 failed/forbidden
17:02:30.649 [INFO ] [smarthome.event.ThingUpdatedEvent ] - Thing 'knx:device:5f1968dd' has been updated.
Voit tu un probleme pour mon fichier things ?
