15/11/2010, 07:54:53
Merci pour l'info,
Mais pour moi c'est un BCU 2.
Et je ne vois pas comment je pourrais faire le master reset BCU 2.
1. Apply PEI-type 20
2. This is simply done by having a 0 ohm resistor on the PEI type
lines; (pins 5 and 6)
3. at the same time press the programming button;
4. at the same time, so while keeping the programming button
pressed and while having PEI-type 20 applied, reset the device
(disconnect from bus/connect again).
Je ne vois pas comment faire le "Apply PEI-type 20", pin 5 and 6 ????
Didier
Didier
