08/02/2025, 10:30:18
Voici comment j'ai testé de faire remonter les infos de ha sur le Knx (pour le moment les infos ne remonte pas sur le knx, mais dans la bulle sous le nœud KNX l'info est ok)
[{"id":"138c41c6c6e221d1","type":"trigger-state","z":"0b06ab17757846df","name":"Status de la batterie","server":"b5a327ea.126338","version":5,"inputs":0,"outputs":3,"exposeAsEntityConfig":"","entities":{"entity":["sensor.batterie_1_battery_running_status"],"substring":[],"regex":[]},"debugEnabled":false,"constraints":[],"customOutputs":[{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"always","comparatorPropertyValue":"","comparatorType":"is","comparatorValue":"","comparatorValueDataType":"str"}],"outputInitially":true,"stateType":"str","enableInput":false,"x":930,"y":1000,"wires":[["e6a1f26167457b28","e0842ab278cb333c"],[],[]]},{"id":"e6a1f26167457b28","type":"debug","z":"0b06ab17757846df","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1160,"y":960,"wires":[]},{"id":"e0842ab278cb333c","type":"knxUltimate","z":"0b06ab17757846df","server":"22d8c2b622a5dbd2","topic":"7/0/24","outputtopic":"","dpt":"1.006","initialread":"0","notifyreadrequest":false,"notifyresponse":false,"notifywrite":true,"notifyreadrequestalsorespondtobus":false,"notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized":"0","listenallga":false,"name":"Statut de la batterie","outputtype":"write","outputRBE":true,"inputRBE":true,"formatmultiplyvalue":1,"formatnegativevalue":"leave","formatdecimalsvalue":999,"passthrough":"no","x":1190,"y":1020,"wires":[[]]},{"id":"b5a327ea.126338","type":"server","name":"Home Assistant","addon":true},{"id":"22d8c2b622a5dbd2","type":"knxUltimate-config","host":"224.0.23.00","port":0000,"physAddr":"15.15.22","hostProtocol":"Multicast","suppressACKRequest":false,"csv":"","KNXEthInterface":"Auto","KNXEthInterfaceManuallyInput":"","stopETSImportIfNoDatapoint":"stop","loglevel":"error","name":"KNX Gateway","localEchoInTunneling":true,"delaybetweentelegrams":50,"delaybetweentelegramsfurtherdelayREAD":1,"ignoreTelegramsWithRepeatedFlag":false,"autoReconnect":"yes"}]
