KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx)
http://www.knx.org/knx-tools/falcon/description/
The Falcon Driver Library is the high performance DCOM based library
for Windows from KNX. DCOM (Microsoft Distributed Component Object
Model) allows the use of Falcon across the LAN. Falcon offers an API
(Application Program Interface) for sending and receiving telegrams
across the KNX network. Supported are the access through RS 232, USB
and Internet.
Especially programmers are exceptionally well served with the Falcon
Driver Library. It lays the tracks for the access to KNX. Aside from
the comfortable API, it offers access management for bus devices, for
telegrams (group address), physical addresses, device states and much
more. The bus access allows the programing of languages like Visual C+
+, Delphi, Visual Basic and others. Falcon is used as network
connection library for ETS 3 and EITT. Since version 1.23 Falcon
offers the IConectionManager, a simple and esay-to-use user interface
for the integrator to make and configure the conection between KNX and
other media.
For technical information, please download the pdf file. Available in
English.
Mais le lien vers le PDF ne fonctionne pas Sad.
Arnaud
KNX ASSO - Falcon Driver Library dispo (API permettant l'envoi et la réception des messages knx) - par chitloft - 09/03/2011, 12:11:49
