05/05/2009, 11:50:59
Merci pour le patch, pour moi ça me conviens comme solution.
Par contre impossible de compiler, voici le config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by linknx configure 0.0.1.26, which was
generated by GNU Autoconf 2.60. Invocation command line was
$ ./configure
## Platform. ##
hostname = srvdomo-f3ade4
uname -m = i686
uname -r = 1.5.25(0.156/4/2)
uname -s = CYGWIN_NT-5.1
uname -v = 2008-06-12 19:34
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/X11R6/bin
PATH: /cygdrive/c/WINDOWS/system32
PATH: /cygdrive/c/WINDOWS/System32/Wbem
PATH: /cygdrive/c/Program Files/Sybase/Shared/PowerBuilder/
## Core tests. ##
configure:1809: checking for a BSD-compatible install
configure:1865: result: /usr/bin/install -c
configure:1876: checking whether build environment is sane
configure:1919: result: yes
configure:1984: checking for gawk
configure:2000: found /usr/bin/gawk
configure:2011: result: gawk
configure:2022: checking whether make sets $(MAKE)
configure:2043: result: yes
configure:2292: checking for g++
configure:2308: found /usr/bin/g++
configure:2319: result: g++
configure:2350: checking for C++ compiler version
configure:2357: g++ --version >&5
g++ (GCC) 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)
Copyright © 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There
is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
configure:2360: $? = 0
configure:2367: g++ -v >&5
Reading specs from /usr/lib/gcc/i686-pc-cygwin/3.4.4/specs
Configured with: /managed/gcc-build/final-v3-bootstrap/gcc-3.4.4-999/
configure --verbose --program-suffix=-3 --prefix=/usr --exec-prefix=/
usr --sysconfdir=/etc --libdir=/usr/lib --libexecdir=/usr/lib --
mandir=/usr/share/man --infodir=/usr/share/info --enable-
languages=c,ada,c++,d,f77,pascal,java,objc --enable-nls --without-
included-gettext --enable-version-specific-runtime-libs --without-x --
enable-libgcj --disable-java-awt --with-system-zlib --enable-
interpreter --disable-libgcj-debug --enable-threads=posix --enable-
java-gc=boehm --disable-win32-registry --enable-sjlj-exceptions --
enable-hash-synchronization --enable-libstdcxx-debug
Thread model: posix
gcc version 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)
configure:2370: $? = 0
configure:2377: g++ -V >&5
g++: `-V' option must have argument
configure:2380: $? = 1
configure:2403: checking for C++ compiler default output file name
configure:2430: g++ conftest.cpp >&5
configure:2433: $? = 0
configure:2479: result: a.exe
configure:2484: checking whether the C++ compiler works
configure:2494: ./a.exe
configure:2497: $? = 0
configure:2514: result: yes
configure:2521: checking whether we are cross compiling
configure:2523: result: no
configure:2526: checking for suffix of executables
configure:2533: g++ -o conftest.exe conftest.cpp >&5
configure:2536: $? = 0
configure:2560: result: .exe
configure:2566: checking for suffix of object files
configure:2592: g++ -c conftest.cpp >&5
configure:2595: $? = 0
configure:2618: result: o
configure:2622: checking whether we are using the GNU C++ compiler
configure:2651: g++ -c conftest.cpp >&5
configure:2657: $? = 0
configure:2664: test -z "$ac_cxx_werror_flag" || test ! -s
conftest.err
configure:2667: $? = 0
configure:2674: test -s conftest.o
configure:2677: $? = 0
configure:2691: result: yes
configure:2696: checking whether g++ accepts -g
configure:2726: g++ -c -g conftest.cpp >&5
configure:2732: $? = 0
configure:2739: test -z "$ac_cxx_werror_flag" || test ! -s
conftest.err
configure:2742: $? = 0
configure:2749: test -s conftest.o
configure:2752: $? = 0
configure:2882: result: yes
configure:2916: checking for style of include used by make
configure:2944: result: GNU
configure:2972: checking dependency style of g++
configure:3062: result: gcc3
configure:3127: checking for gcc
configure:3143: found /usr/bin/gcc
configure:3154: result: gcc
configure:3392: checking for C compiler version
configure:3399: gcc --version >&5
gcc (GCC) 3.4.4 (cygming special, gdc 0.12, using dmd 0.125)
is NO
PURPOSE.
configure:3402: $? = 0
configure:3409: gcc -v >&5
Thread model: posix
configure:3412: $? = 0
configure:3419: gcc -V >&5
gcc: `-V' option must have argument
configure:3422: $? = 1
configure:3425: checking whether we are using the GNU C compiler
configure:3454: gcc -c conftest.c >&5
configure:3460: $? = 0
configure:3467: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:3470: $? = 0
configure:3477: test -s conftest.o
configure:3480: $? = 0
configure:3494: result: yes
configure:3499: checking whether gcc accepts -g
configure:3529: gcc -c -g conftest.c >&5
configure:3535: $? = 0
configure:3542: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:3545: $? = 0
configure:3552: test -s conftest.o
configure:3555: $? = 0
configure:3685: result: yes
configure:3702: checking for gcc option to accept ISO C89
configure:3776: gcc -c -g -O2 conftest.c >&5
configure:3782: $? = 0
configure:3789: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:3792: $? = 0
configure:3799: test -s conftest.o
configure:3802: $? = 0
configure:3822: result: none needed
configure:3842: checking dependency style of gcc
configure:3932: result: gcc3
configure:3992: checking for ranlib
configure:4008: found /usr/bin/ranlib
configure:4019: result: ranlib
configure:4050: checking how to run the C preprocessor
configure:4090: gcc -E conftest.c
configure:4096: $? = 0
configure:4134: gcc -E conftest.c
conftest.c:10:28: ac_nonexistent.h: No such file or directory
configure:4140: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "linknx"
| #define PACKAGE_TARNAME "linknx"
| #define PACKAGE_VERSION "0.0.1.26"
| #define PACKAGE_STRING "linknx 0.0.1.26"
| #define PACKAGE_BUGREPORT "linknx@ouaye.net"
| #define PACKAGE "linknx"
| #define VERSION "0.0.1.26"
| /* end confdefs.h. */
| #include <ac_nonexistent.h>
configure:4180: result: gcc -E
configure:4209: gcc -E conftest.c
configure:4215: $? = 0
configure:4253: gcc -E conftest.c
configure:4259: $? = 1
| /* confdefs.h. */
configure:4313: checking for GNU Pth
configure:4618: gcc -E -I/usr/local/include conftest.c
configure:4624: $? = 0
configure:4706: gcc -o conftest.exe -g -O2 -I/usr/local/include -I/
usr/local/include -L/usr/local/lib conftest.c -lpthsem -ldl >&5
configure:4712: $? = 0
configure:4719: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:4722: $? = 0
configure:4729: test -s conftest.exe
configure:4732: $? = 0
configure:4803: gcc -o conftest.exe -g -O2 -I/usr/local/include -I/
configure:4806: $? = 0
configure:4812: ./conftest.exe
configure:4815: $? = 0
configure:4931: result: version 2.0.7, installed under /usr/local
configure:4940: checking for grep that handles long lines and -e
configure:5014: result: /usr/bin/grep
configure:5019: checking for egrep
configure:5097: result: /usr/bin/grep -E
configure:5102: checking for ANSI C header files
configure:5132: gcc -c -g -O2 conftest.c >&5
configure:5138: $? = 0
configure:5145: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:5148: $? = 0
configure:5155: test -s conftest.o
configure:5158: $? = 0
configure:5254: gcc -o conftest.exe -g -O2 conftest.c >&5
configure:5257: $? = 0
configure:5263: ./conftest.exe
configure:5266: $? = 0
configure:5283: result: yes
configure:5307: checking for sys/types.h
configure:5328: gcc -c -g -O2 conftest.c >&5
configure:5334: $? = 0
configure:5341: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:5344: $? = 0
configure:5351: test -s conftest.o
configure:5354: $? = 0
configure:5367: result: yes
configure:5307: checking for sys/stat.h
configure:5307: checking for stdlib.h
configure:5307: checking for string.h
configure:5307: checking for memory.h
configure:5307: checking for strings.h
configure:5307: checking for inttypes.h
configure:5307: checking for stdint.h
configure:5307: checking for unistd.h
configure:5389: checking argp.h usability
configure:5406: gcc -c -g -O2 conftest.c >&5
configure:5412: $? = 0
configure:5419: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:5422: $? = 0
configure:5429: test -s conftest.o
configure:5432: $? = 0
configure:5443: result: yes
configure:5447: checking argp.h presence
configure:5462: gcc -E conftest.c
configure:5468: $? = 0
configure:5489: result: yes
configure:5522: checking for argp.h
configure:5529: result: yes
configure:5542: checking for library containing argp_parse
configure:5583: gcc -o conftest.exe -g -O2 conftest.c >&5
/cygdrive/c/DOCUME~1/ADMINI~1/LOCALS~1/Temp/cc8jr5j8.o: In function
`main':
/home/Administrateur/conftest.c:31: undefined reference to
`_argp_parse'
collect2: ld returned 1 exit status
configure:5589: $? = 1
| /* confdefs.h. */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char argp_parse ();
| int
| main ()
| return argp_parse ();
| return 0;
configure:5583: gcc -o conftest.exe -g -O2 conftest.c -largp >&5
configure:5589: $? = 0
configure:5596: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:5599: $? = 0
configure:5606: test -s conftest.exe
configure:5609: $? = 0
configure:5633: result: -largp
configure:5680: checking for cppunit-config
configure:5711: result: no
configure:5721: checking for Cppunit - version >= 1.9.6
configure:5846: checking for gawk
configure:5873: result: gawk
configure:5935: checking for curl-config
configure:5953: found /usr/local/bin/curl-config
configure:5965: result: /usr/local/bin/curl-config
configure:5976: checking for the version of libcurl
configure:5983: result: 7.19.2
configure:5990: checking for libcurl >= version 7.14.0
configure:6003: result: yes
configure:6044: checking whether libcurl is usable
configure:6087: gcc -o conftest.exe -g -O2 -I/usr/local/include
conftest.c -L/usr/local/lib -lcurl -largp >&5
configure:6093: $? = 0
configure:6100: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:6103: $? = 0
configure:6110: test -s conftest.exe
configure:6113: $? = 0
configure:6132: result: yes
configure:6145: checking for curl_free
configure:6201: gcc -o conftest.exe -g -O2 -I/usr/local/include
conftest.c -largp -L/usr/local/lib -lcurl >&5
configure:6207: $? = 0
configure:6214: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:6217: $? = 0
configure:6224: test -s conftest.exe
configure:6227: $? = 0
configure:6240: result: yes
configure:6327: checking for ANSI C header files
configure:6508: result: yes
configure:6536: checking fcntl.h usability
configure:6553: gcc -c -g -O2 conftest.c >&5
configure:6559: $? = 0
configure:6566: test -z "$ac_c_werror_flag" || test ! -s conftest.err
configure:6569: $? = 0
configure:6576: test -s conftest.o
configure:6579: $? = 0
configure:6590: result: yes
configure:6594: checking fcntl.h presence
configure:6609: gcc -E conftest.c
configure:6615: $? = 0
configure:6636: result: yes
configure:6669: checking for fcntl.h
configure:6677: result: yes
configure:6536: checking stddef.h usability
configure:6594: checking stddef.h presence
configure:6669: checking for stddef.h
configure:6526: checking for stdlib.h
configure:6532: result: yes
configure:6526: checking for unistd.h
configure:6691: checking for struct tm.tm_gmtoff
configure:6720: gcc -c -g -O2 conftest.c >&5
conftest.c: In function `main':
conftest.c:38: error: structure has no member named `tm_gmtoff'
configure:6726: $? = 1
| /* confdefs.h. */
| #define HAVE_LIBCURL 1
| #define LIBCURL_PROTOCOL_HTTP 1
| #define LIBCURL_PROTOCOL_FTP 1
| #define LIBCURL_PROTOCOL_FILE 1
| #define LIBCURL_PROTOCOL_TELNET 1
| #define LIBCURL_PROTOCOL_DICT 1
| #define LIBCURL_PROTOCOL_TFTP 1
| #define HAVE_FCNTL_H 1
| #define HAVE_STDDEF_H 1
| #include <time.h>
| int
| main ()
| static struct tm ac_aggr;
| if (ac_aggr.tm_gmtoff)
| return 0;
| return 0;
configure:6777: gcc -c -g -O2 conftest.c >&5
configure:6783: $? = 1
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| if (sizeof ac_aggr.tm_gmtoff)
| return 0;
| return 0;
configure:6818: result: no
configure:6833: checking for struct tm.__tm_gmtoff
configure:6862: gcc -c -g -O2 conftest.c >&5
conftest.c:38: error: structure has no member named `__tm_gmtoff'
configure:6868: $? = 1
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| if (ac_aggr.__tm_gmtoff)
| return 0;
| return 0;
configure:6919: gcc -c -g -O2 conftest.c >&5
configure:6925: $? = 1
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| if (sizeof ac_aggr.__tm_gmtoff)
| return 0;
| return 0;
configure:6960: result: no
configure:6978: checking for mysql_config executable
configure:7008: result: not found
configure:8462: checking libesmtp.h usability
configure:8479: gcc -c -g -O2 conftest.c >&5
conftest.c:65:22: libesmtp.h: No such file or directory
configure:8485: $? = 1
| /* confdefs.h. */
| #include <stdio.h>
| #if HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #if HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #if STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # if HAVE_STDLIB_H
| # endif
| #endif
| #if HAVE_STRING_H
| # if !STDC_HEADERS && HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #if HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #if HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #if HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #if HAVE_UNISTD_H
| # include <unistd.h>
| #endif
| #include <libesmtp.h>
configure:8516: result: no
configure:8520: checking libesmtp.h presence
configure:8535: gcc -E conftest.c
conftest.c:32:22: libesmtp.h: No such file or directory
configure:8541: $? = 1
| /* confdefs.h. */
configure:8562: result: no
configure:8595: checking for libesmtp.h
configure:8602: result: no
configure:8626: checking whether to use libesmtp
configure:8655: result: no
configure:8662: checking for log4cpp-config
configure:8695: result: no
configure:8700: checking for log4cpp
configure:8711: result: yes
configure:8770: checking for pkg-config
configure:8803: result: no
configure:8843: checking for LOG4CPP
configure:8933: error: The pkg-config script could not be found or is
too old. Make sure it
is in your PATH or set the PKG_CONFIG environment variable to the full
path to pkg-config.
Alternatively, you may set the environment variables LOG4CPP_CFLAGS
and LOG4CPP_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
To get pkg-config, see <http://www.freedesktop.org/software/
pkgconfig>.
See `config.log' for more details.
## Cache variables. ##
ac_cv_c_compiler_gnu=yes
ac_cv_cxx_compiler_gnu=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LOG4CPP_CFLAGS_set=
ac_cv_env_LOG4CPP_CFLAGS_value=
ac_cv_env_LOG4CPP_LIBS_set=
ac_cv_env_LOG4CPP_LIBS_value=
ac_cv_env_LUA_CFLAGS_set=
ac_cv_env_LUA_CFLAGS_value=
ac_cv_env_LUA_LIBS_set=
ac_cv_env_LUA_LIBS_value=
ac_cv_env_PKG_CONFIG_set=
ac_cv_env_PKG_CONFIG_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_exeext=.exe
ac_cv_func_curl_free=yes
ac_cv_header_argp_h=yes
ac_cv_header_fcntl_h=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_libesmtp_h=no
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stddef_h=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=yes
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=yes
ac_cv_member_struct_tm___tm_gmtoff=no
ac_cv_member_struct_tm_tm_gmtoff=no
ac_cv_objext=o
ac_cv_path_CPPUNIT_CONFIG=no
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path__libcurl_config=/usr/local/bin/curl-config
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP='gcc -E'
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_ac_ct_CXX=g++
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_make_make_set=yes
ac_cv_search_argp_parse=-largp
am_cv_CC_dependencies_compiler_type=gcc3
am_cv_CXX_dependencies_compiler_type=gcc3
libcurl_cv_lib_curl_usable=yes
libcurl_cv_lib_curl_version=7.19.2
libcurl_cv_lib_version_ok=yes
## Output variables. ##
ACLOCAL='${SHELL} /home/Administrateur/missing --run aclocal-1.9'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/Administrateur/missing --run tar'
AUTOCONF='${SHELL} /home/Administrateur/missing --run autoconf'
AUTOHEADER='${SHELL} /home/Administrateur/missing --run autoheader'
AUTOMAKE='${SHELL} /home/Administrateur/missing --run automake-1.9'
AWK='gawk'
CC='gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS='-g -O2'
CPP='gcc -E'
CPPFLAGS=''
CPPUNIT_CFLAGS=''
CPPUNIT_CONFIG='no'
CPPUNIT_FALSE=''
CPPUNIT_LIBS=''
CPPUNIT_TRUE='#'
CXX='g++'
CXXDEPMODE='depmode=gcc3'
CXXFLAGS='-g -O2'
CYGPATH_W='cygpath -w'
DEFS=''
DEPDIR='.deps'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT='.exe'
GREP='/usr/bin/grep'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
LDFLAGS=''
LIBCURL='-L/usr/local/lib -lcurl'
LIBCURL_CPPFLAGS='-I/usr/local/include'
LIBOBJS=''
LIBS='-largp '
LOG4CPP_CFLAGS=''
LOG4CPP_CONFIG=''
LOG4CPP_LIBS=''
LTLIBOBJS=''
LUA_CFLAGS=''
LUA_LIBS=''
MAKEINFO='${SHELL} /home/Administrateur/missing --run makeinfo'
OBJEXT='o'
PACKAGE='linknx'
PACKAGE_BUGREPORT='linknx@ouaye.net'
PACKAGE_NAME='linknx'
PACKAGE_STRING='linknx 0.0.1.26'
PACKAGE_TARNAME='linknx'
PACKAGE_VERSION='0.0.1.26'
PATH_SEPARATOR=':'
PKG_CONFIG=''
PTH_CFLAGS='-I/usr/local/include'
PTH_CPPFLAGS='-I/usr/local/include'
PTH_LDFLAGS='-L/usr/local/lib'
PTH_LIBS='-lpthsem -ldl'
RANLIB='ranlib'
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
VERSION='0.0.1.26'
_libcurl_config=''
ac_ct_CC='gcc'
ac_ct_CXX='g++'
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE='#'
am__fastdepCXX_TRUE=''
am__include='include'
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build_alias=''
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host_alias=''
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='/home/Administrateur/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='NONE'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
configure: exit 1
On 5 mai, 06:01, sam974 <s...@wanhoi.org> wrote:
> Bonjour,
> Merci pour le PoC patch!
> Ne serait-il pas intéressant de pouvoir faire :
> <admin><notification><register/></notification></admin>
> afin de recevoir tous les changements?
> On 5 mai, 03:52, jef2000 <jef2...@ouaye.net> wrote:
> > Bonjour,
> > Je viens de tenter une solution.http://www.ouaye.net/linknx/other/object-value-notification-patch.txt
> > Avec le patch ci dessus, on peut faire ceci:
> > Requête :<admin><notification><register id='dim_value_salon'/></
> > Réponse:<admin status='success'/>
> > Ensuite, lorsque la valeur change, on reçoit:
> > <notify id='dim_value_salon'>64</read>
> > <notify id='dim_value_salon'>128</read>
> > Et on peut le désactiver comme ça:
> > Requête :<admin><notification><unregister id='dim_value_salon'/></
> > Ce n'est pas encore complètement terminé. Par exemple, si tu supprimes
> > un objet sans avoir envoyé d'abord le "unregister", ça va probablement
> > exploser...
> > Mais ça donne déjà une idée de la solution pour voir si ça convient.- Masquer le texte des messages précédents -
$ ./configure
## Platform. ##
uname -m = i686
/bin/arch = i686
PATH: /usr/bin
PATH: /bin
## Core tests. ##
is NO
PURPOSE.
Thread model: posix
conftest.err
conftest.err
is NO
PURPOSE.
Thread model: posix
| /* confdefs.h. */
| /* confdefs.h. */
`main':
`_argp_parse'
| /* confdefs.h. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char argp_parse ();
| int
| main ()
| return 0;
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| return 0;
| return 0;
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| return 0;
| return 0;
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| return 0;
| return 0;
| /* confdefs.h. */
| #include <time.h>
| int
| main ()
| return 0;
| return 0;
| /* confdefs.h. */
| #include <stdio.h>
| #endif
| #if HAVE_SYS_STAT_H
| #endif
| #if STDC_HEADERS
| #else
| # if HAVE_STDLIB_H
| # endif
| #endif
| #if HAVE_STRING_H
| # endif
| #endif
| #if HAVE_STRINGS_H
| #endif
| #if HAVE_INTTYPES_H
| #endif
| #if HAVE_STDINT_H
| #endif
| #if HAVE_UNISTD_H
| #endif
| /* confdefs.h. */
path to pkg-config.
pkgconfig>.
ac_cv_env_CCC_set=
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CPP_set=
ac_cv_env_CXX_set=
ac_cv_exeext=.exe
ac_cv_objext=o
ac_cv_prog_AWK=gawk
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AWK='gawk'
CC='gcc'
CFLAGS='-g -O2'
CPP='gcc -E'
CPPFLAGS=''
CPPUNIT_CFLAGS=''
CPPUNIT_CONFIG='no'
CPPUNIT_FALSE=''
CPPUNIT_LIBS=''
CPPUNIT_TRUE='#'
CXX='g++'
CXXFLAGS='-g -O2'
DEFS=''
DEPDIR='.deps'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT='.exe'
LDFLAGS=''
LIBOBJS=''
LIBS='-largp '
LOG4CPP_CFLAGS=''
LOG4CPP_CONFIG=''
LOG4CPP_LIBS=''
LTLIBOBJS=''
LUA_CFLAGS=''
LUA_LIBS=''
OBJEXT='o'
PACKAGE='linknx'
PATH_SEPARATOR=':'
PKG_CONFIG=''
RANLIB='ranlib'
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
VERSION='0.0.1.26'
_libcurl_config=''
ac_ct_CC='gcc'
ac_ct_CXX='g++'
am__leading_dot='.'
am__quote=''
build_alias=''
dvidir='${docdir}'
exec_prefix='NONE'
host_alias=''
htmldir='${docdir}'
pdfdir='${docdir}'
prefix='NONE'
psdir='${docdir}'
target_alias=''
## confdefs.h. ##
configure: exit 1
> Bonjour,
> > Bonjour,
> > exploser...
