01/07/2008, 13:53:57
On 30 juin, 19:38, Marc Assin <raym...@warichet.com> wrote:
> J'ai posé ma question au support Merten.
Réponse du support Merten
" if you want to connect the smoke detectors to one another then you
can do this per wire or per Radio module. Not with the relay module.
the relay module is only to be used for an external Alarm"
Ce qui ne répond pas à la question posée, qui était:
"I'll network 5 smoke detector 663460, with the relay module
Suppose a smoke detector in the middle of the chain will trigger an
alarm, will the other smoke detector's relay work ?
The doc says: "the LED will not flash", OK, but will the relay work,
on all other detectors ???"
C'est quand même vrai que j'ai du mal à m'exprimer ;-)
