10/04/2011, 11:18:30
ca fait 3 h que je cherche !
et puis voila , il manquait
#apt-get install pkg-config
Dsl.
Arnaud
On 10 avr, 12:16, chitloft <arnaud.cogn...@laposte.net> wrote:
> salut
> j'ai 1 soucis sur mon Dockstar avec debian squeeze
> # dpkg -l
> lua5.1 5.1.4-5
> Simple, extensible, embeddable programming language
> # ./configure --without-log4cpp --with-lua --with-mysql=/usr/bin/
> mysql_config
> checking for LUA... no
> checking for LUA... configure: error: in `/home/install/
> linknx-0.0.1.28':
> configure: error: The pkg-config script could not be found or is too
> old. Make sure it
> is in your PATH or set the PKG_CONFIG environment variable to the full
> path to pkg-config.
> Alternatively, you may set the environment variables LUA_CFLAGS
> and LUA_LIBS to avoid the need to call pkg-config.
> See the pkg-config man page for more details.
> To get pkg-config, see <http://pkg-config.freedesktop.org/>.
> See `config.log' for more details.
> Any idea ?
> Merci.
> Arnaud
Dsl.
Arnaud
> salut
> # dpkg -l
> lua5.1 5.1.4-5
> mysql_config
> linknx-0.0.1.28':
> old. Make sure it
> path to pkg-config.
> Any idea ?
> Merci.
> Arnaud
