25/01/2012, 16:26:35
(25/01/2012, 16:18:27)chtiloft a écrit : export LD_LIBRARY_PATH=/usr/local/lib
Merci mais rien n'y change
root@sheeva:/etc/apt# export LD_LIBRARY_PATH=/usr/local/lib
root@sheeva:/etc/apt# cd /home/linknx/knx/
root@sheeva:/home/linknx/knx# ./configure --without-log4cpp --with-lua --with-mysql=/usr/bin/mysql_config --enable-smtp
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... no
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... none
checking dependency style of g++... none
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... none
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking for GNU Pth... *FAILED*
| Unable to locate pthsem in any system-wide location (see $PATH).
| Please specify the correct path to either a pthsem installation tree
| (use --with-pth=DIR if you used --prefix=DIR for installing pthsem in
| the past) or to a pthsem source tree (use --with-pth=DIR if DIR is a
| path to a pthsem-X.Y.Z/ directory; but make sure the package is already
| built, i.e., the "configure; make" step was already performed there).
