Proxmox et gestion des sauvegardes
#44
Code :
root@pve:/# dmesg | tail -n 30
[    5.808654] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    5.808687] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    5.808711] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    5.808735] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[    5.808760] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[    5.808783] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[    6.101209] audit: type=1400 audit(1652047777.034:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=1047 comm="apparmor_parser"
[    6.119773] audit: type=1400 audit(1652047777.054:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1049 comm="apparmor_parser"
[    6.122329] audit: type=1400 audit(1652047777.058:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1049 comm="apparmor_parser"
[    6.134737] audit: type=1400 audit(1652047777.070:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=1044 comm="apparmor_parser"
[    6.153384] audit: type=1400 audit(1652047777.086:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1048 comm="apparmor_parser"
[    6.154976] audit: type=1400 audit(1652047777.090:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1048 comm="apparmor_parser"
[    6.155842] audit: type=1400 audit(1652047777.090:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1048 comm="apparmor_parser"
[    6.174363] audit: type=1400 audit(1652047777.110:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/chronyd" pid=1050 comm="apparmor_parser"
[    6.207658] audit: type=1400 audit(1652047777.142:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="tcpdump" pid=1045 comm="apparmor_parser"
[    6.311081] audit: type=1400 audit(1652047777.246:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lxc-container-default" pid=1046 comm="apparmor_parser"
[    6.366021] softdog: initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[    6.366023] softdog:              soft_reboot_cmd=<not set> soft_active_on_boot=0
[    6.510068] vmbr0: port 1(eno1) entered blocking state
[    6.510852] vmbr0: port 1(eno1) entered disabled state
[    6.511631] device eno1 entered promiscuous mode
[    8.785967] bpfilter: Loaded bpfilter_umh pid 1504
[    8.786167] Started bpfilter
[    8.876139] e1000e 0000:00:1f.6 eno1: NIC Link is Up 10 Mbps Half Duplex, Flow Control: None
[    8.876692] e1000e 0000:00:1f.6 eno1: 10/100 speed: disabling TSO
[    8.878204] vmbr0: port 1(eno1) entered blocking state
[    8.878767] vmbr0: port 1(eno1) entered forwarding state
[    8.880341] IPv6: ADDRCONF(NETDEV_CHANGE): vmbr0: link becomes ready
[   19.651244] L1TF CPU bug present and SMT on, data leak possible. See CVE-2018-3646 and https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/l1tf.html for details.
[43096.392051] perf: interrupt took too long (2503 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
root@pve:/#
Cela donne ceci:
Je serais absent jusqu'à samedi, désolé si je répond pas avant
Cordialement
Proxmox et gestion des sauvegardes - par richardpub - 21/01/2022, 11:52:21
RE: Proxmox et gestion des sauvegardes - par Nitro24 - 22/01/2022, 10:15:07
RE: Proxmox et gestion des sauvegardes - par filou59 - 22/01/2022, 11:56:58
RE: Proxmox et gestion des sauvegardes - par filou59 - 25/01/2022, 07:53:03
RE: Proxmox et gestion des sauvegardes - par filou59 - 25/01/2022, 18:23:36
RE: Proxmox et gestion des sauvegardes - par filou59 - 06/05/2022, 07:02:36
RE: Proxmox et gestion des sauvegardes - par filou59 - 06/05/2022, 10:21:52
RE: Proxmox et gestion des sauvegardes - par filou59 - 07/05/2022, 12:28:45
RE: Proxmox et gestion des sauvegardes - par filou59 - 08/05/2022, 11:16:50
RE: Proxmox et gestion des sauvegardes - par filou59 - 08/05/2022, 13:55:05
RE: Proxmox et gestion des sauvegardes - par filou59 - 08/05/2022, 18:47:21
RE: Proxmox et gestion des sauvegardes - par richardpub - 09/05/2022, 11:17:56
RE: Proxmox et gestion des sauvegardes - par filou59 - 14/05/2022, 15:31:21
RE: Proxmox et gestion des sauvegardes - par filou59 - 15/05/2022, 18:55:03
RE: Proxmox et gestion des sauvegardes - par filou59 - 24/05/2022, 11:11:56
RE: Proxmox et gestion des sauvegardes - par filou59 - 24/05/2022, 22:13:59
RE: Proxmox et gestion des sauvegardes - par filou59 - 25/05/2022, 13:29:01
RE: Proxmox et gestion des sauvegardes - par filou59 - 28/05/2022, 12:47:38
RE: Proxmox et gestion des sauvegardes - par filou59 - 29/05/2022, 18:31:47
RE: Proxmox et gestion des sauvegardes - par filou59 - 30/05/2022, 01:23:12
RE: Proxmox et gestion des sauvegardes - par filou59 - 30/05/2022, 09:45:37
RE: Proxmox et gestion des sauvegardes - par filou59 - 30/05/2022, 10:19:43
RE: Proxmox et gestion des sauvegardes - par filou59 - 30/05/2022, 11:15:24
RE: Proxmox et gestion des sauvegardes - par filou59 - 01/06/2022, 11:55:26
RE: Proxmox et gestion des sauvegardes - par filou59 - 01/06/2022, 13:19:37
RE: Proxmox et gestion des sauvegardes - par filou59 - 01/06/2022, 13:36:17
RE: Proxmox et gestion des sauvegardes - par filou59 - 01/06/2022, 14:35:34
RE: Proxmox et gestion des sauvegardes - par filou59 - 03/06/2022, 20:39:43
RE: Proxmox et gestion des sauvegardes - par filou59 - 03/06/2022, 23:08:29
RE: Proxmox et gestion des sauvegardes - par filou59 - 04/06/2022, 00:35:12
RE: Proxmox et gestion des sauvegardes - par filou59 - 04/06/2022, 15:55:52
RE: Proxmox et gestion des sauvegardes - par filou59 - 05/06/2022, 11:25:08
RE: Proxmox et gestion des sauvegardes - par filou59 - 05/06/2022, 15:40:55
RE: Proxmox et gestion des sauvegardes - par filou59 - 13/06/2022, 11:38:04
RE: Proxmox et gestion des sauvegardes - par filou59 - 29/07/2022, 20:59:07
RE: Proxmox et gestion des sauvegardes - par Ives - 08/12/2022, 17:12:06
RE: Proxmox et gestion des sauvegardes - par R4v3n - 09/12/2022, 10:54:16
RE: Proxmox et gestion des sauvegardes - par Ives - 09/12/2022, 11:16:36
RE: Proxmox et gestion des sauvegardes - par filou59 - 09/12/2022, 11:06:56
RE: Proxmox et gestion des sauvegardes - par filou59 - 09/12/2022, 11:30:41
RE: Proxmox et gestion des sauvegardes - par Ives - 09/12/2022, 12:35:18
RE: Proxmox et gestion des sauvegardes - par Ives - 10/12/2022, 14:05:13
RE: [TUTO] Proxmox Install - par richardpub - 11/06/2022, 18:08:20
RE: [TUTO] Proxmox Install - par filou59 - 12/06/2022, 13:49:48
RE: [TUTO] Proxmox Install - par richardpub - 12/06/2022, 17:00:24
