linknx - pb compile avec lua
salut
j'ai 1 soucis sur mon Dockstar avec debian squeeze
# dpkg -l
lua5.1 5.1.4-5
Simple, extensible, embeddable programming language
# ./configure --without-log4cpp --with-lua --with-mysql=/usr/bin/
mysql_config
checking for LUA... no
checking for LUA... configure: error: in `/home/install/
linknx-0.0.1.28':
configure: error: The pkg-config script could not be found or is too
old. Make sure it
is in your PATH or set the PKG_CONFIG environment variable to the full
path to pkg-config.
Alternatively, you may set the environment variables LUA_CFLAGS
and LUA_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
To get pkg-config, see <http://pkg-config.freedesktop.org/>.
See `config.log' for more details.
Any idea ?
Merci.
Arnaud
ca fait 3 h que je cherche !
et puis voila , il manquait
#apt-get install pkg-config
Dsl.
Arnaud
On 10 avr, 12:16, chitloft <arnaud.cogn...@laposte.net> wrote:
> salut
> # dpkg -l
> lua5.1                                 5.1.4-5
> mysql_config
> linknx-0.0.1.28':
> old.  Make sure it
> path to pkg-config.
> Any idea ?
> Merci.
> Arnaud
